Question about Kenmore Washing Machines
Kenmore elite ast2 is shaking and moving around on the floor in spin dry cycle.it is level,floor is clean.machine tries to ajust but still jumps around.
It seems to me that the four shocks are not doing there job,but have no reference to verify or compare with
    Problem Solver:
  • 7 Answers
Try leveling it. First, put a level on top of it. Adjust one of the two front feet until it is balanced. (The front feet screw up and down.) Be sure you level it in place; don't move it out of the spot where you will use it.
Posted on Aug 06, 2014
pumpkinman
  • 1144 Answers
SOURCE: shaking in spin cycle and tub moves too easily in washing machine
the tension springs on the tub mite have came loose during moving
Posted on Jul 01, 2009
  • 254 Answers
SOURCE: Kenmore Whasher shakes on spin cycle
unfortunetly this is common , these new frontloads spin fast even with no pedestal these things move...
make sure the locking nuts for the legs on the pedestal are screwed securely up to frame on pedestal, also could be a floor issue depending on where it is, slooping or not solid floor.
Posted on Jan 28, 2010
  • 2468 Answers
SOURCE: spin cycle shakes whole washing machine
have you tightened the jamb nuts on the legs after leveling the machine so they can't move from where you set them initially when you leveled the unit?
Posted on Mar 21, 2010
hwy505
  • 7 Answers
SOURCE: Washer makes knocking noise while in spin cycle.
Check your front and rear counter-weights. They are made of concrete and start to chip away. More so the rear than the front. When you open it up look on the base and see if you have chips or chunks of concrete. I had that problem as well - also make sure you spray lube inside,check your "Spider" wheel, and belt.
Posted on Aug 11, 2010
blueextc3221
  • 15935 Answers
SOURCE: Kenmore Elite Oasis HE 27072. Keep getting UL
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 26, 2010
Spin cycle shakes whole washing machine
Mar 21, 2010 | Kenmore HE2 Plus Front Load Washer
Kenmore Elite Model 44836
Check that the feet are level to the floor as this may cause the vibration. Also set the machine to wool mode this then knows what material you are putting in the machine then should cycle to that material.
Thanks J
Feb 17, 2008 | Kenmore Elite 45986 Front Load Washer
Jan 28, 2010 | Kenmore Elite 45986 Front Load Washer
Can not keep the HE 3 washer from jumping around on the spin cycle. Floor is level and machine is level with legs locked in place. Have lowered leveling legs to the base and locked them tight with the...
these machines can have this problem when placed on a pedestal and/or the floor may be level but not solid. a "bouncy" floor will amplify any movements. remember, these machines are much heavier and spin much faster than top-loaders. just because it doesn't jiggle doesn't mean the floor is level. you may have to brace to floor or foundation somehow
Sep 24, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore start shaking very hard on every spin cycle why does this happen?
because you are putting to many close in or load is unbalanced move the cloths around and don't put so much in the machine
Aug 30, 2009 | Kenmore Elite 21086
Our washer shakes & wobbles durring the spin cycle I have the kenmore smartwash quiet pak 9. THE FEET ARE ALL FLAT ON THE FLOOR BUT WE JUST MOVED AND CAN NOT FIX THIS PROBLEM. ANY IDEAS?
ahh but is the floor level?
use a spirit level to see that the floor is actually level and distribute the clothes around the drum to stop it going out of balance. Of course you know that last bit you have been washing for years,but check the floor
Aug 30, 2009 | Washing Machines
Shaking in spin cycle and tub moves too easily in washing machine
Jul 01, 2009 | Washing Machines
Washplate problem Kenmore Elite Calypso washer
Hello genny2626
Welcome,
You said,your 6 year old Kenmore elite top loader's wash plate doesn't seem to go through its proper motions. When the lid is closed and the washer has filled and the agitating cycle begins, you can hear a vibrating noise as if the plate is trying to move on the gentle cycle, but when the lid is opened, nothing has moved at all. The drain and spin work fine, and the machine goes through an entire cycle without error messages, but the clothes aren't clean. You said, you have heard a lot of horror stories of how expensive these washers are to repair, so would like an idea of what's wrong beforehand.
Here are a list of common vibration noises
Noisy, vibrating, off-balance
 Is the washer level? Does the washer rock when pushed
against the corners?
The washer must be level. The front and rear feet must be in
firm contact with the floor. Check that the locknuts are
tightened. See “Level the Washer.”
 Is the floor flexing, sagging or not level?
Flooring that flexes or is uneven can contribute to noise and
vibration of the washer. A ³⁄₄" (1.9 cm) piece of plywood under
the washer will reduce the sounds. See “Location
Requirements.”
 Is the load balanced?
Evenly distribute the load in the washer basket and make
sure the height of the load does not exceed the top row of
basket holes. See “Starting Your Washer.”
 Do you hear clicking or other noises when the cycle
changes from washing to draining or spinning?
When the drive system shifts or the washer basket settles
between cycles you may hear noises that are different from
your previous washer. These are normal washer noises.
 Is the washer gurgling or humming?
Is the washer level? The wash load
should be balanced and not overloaded. The washer must be
level. The front feet should be properly installed and the nuts
tightened. Reset the rear leveling legs (if needed). See the
Installation Instructions.
Did you completely remove the yellow shipping strap with
cotter pins? See the Installation Instructions.
• Are the gears engaging after the drain and before spin, or
is the upper part of agitator clicking during wash? These
Let me know if any of these are the solution!
Huuum
Oct 13, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite shaking during spin cycle
Moved a Kenmore Elite and when we put it back in place it vibrates loudly. We tried leveling it and that has not worked. Any ideas?
Sep 27, 2008 | Kenmore 24032\24036 Top Load Washer
Front loader vibrates and moves
You shd check the front legs - they shd be a maximum screwed up, that is the machine shd be tilting forwards. Then you adjust acccording to your floor level. The machine should not shake a bit when off, & you try to shake it with both your hands.
A little vibration is normal when the spin starts. Don't forget to rate me nice............
May 24, 2008 | Kenmore 46462 Front Load Washer
Washing Machines Logo
77 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
