Question about Panasonic CQ-DF203U CD Player
Every Button Switches Between Radio and CD
It's strange, it started out of nowhere, but suddenly every button I push switches the player from CD mode to Radio, then back again. For example, I'm listening to the radio, I try to switch the station, so I press the #2 preset. Presto! It switches to CD mode. I'm listening to a CD and I decide to skip to the next track, so I press the next button. Holy ****! It switched back to Radio mode. It's driving me insane because I can literally only listen to one radio station and I can't ever switch tracks. Buttons that do work? Volume, Power, Eject. I have a feeling I may have pressed some button and messed something up, since I am new to this car stereo (just bought this car) but I've been playing with everything, trying to fix it, reading up on the manual, but I can't figure it out. Anyone got any ideas?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 103 Answers
Reset the radio by pressing a sharp object (pin, pen, etc.) into the small reset hole on or behind the face. If it doesn't have one, disconnect the negative cable from the battery for two minutes and reconnect. If you still have this problem, the radio is bad.
Posted on Apr 18, 2014
5 Suggested Answers
SOURCE: CD player that doesn't play
I had the same problem.
I cut the orange wire which went into the black connecter block
and WOW I had sound...
brilliant
thanks a lot
Andy - North Yorkshire, England
Posted on Feb 24, 2009
messstat
  • 365 Answers
SOURCE: Panasonic CQ-C700U
Sorry, there's no way to repair the CD, if faulty. Try looking for a "reset" a VERY tiny hole somewhere behind the "door", on the face of the radio chassis...Using a paper clip end push into the tiny hole for a few seconds, ignition/radio on...If you can't find a reset...take it to a friendly local car stereo shop and ask them to diagnose the problem ($40).
Good Luck
Posted on Jun 23, 2009
kenw392
  • 2226 Answers
SOURCE: Turns on but won't turn
It sounds to me like you may have a bad volume control switch. Unless you are good at unsoldering and soldering, I would suggest you have it repaired by a professional. Either that or see if you can find a replacement face at a pawnshop or something like that.
Posted on Sep 08, 2011
logosc75
  • 625 Answers
SOURCE: Won't remember settings
Your memory wire(12volt constant) and accessory (12volt switched) are in opposite positions. I have seen this happen with aftermarket wiring harnesses for european vehicles (mercedes,audi and VW). Switch the wires.
Posted on Aug 13, 2012
Trying to record but when I push the "record"
Get the manual...
http://tascam.com/product/cd-rw750/downloads/
Record READY switches the unit into a Monitor mode so you can set your levels for when you finally initiate recording.
Jul 28, 2011 | Tascam CD-RW750 CD Recorder
I have a AIWA X204 CD in my car.I don,t know what I did, but the player doesn't answer to any comand. i push every one of button, but he don;t start to play.The screen it's light up,, and...
I think that's Demo mode.
I got stuck there too.
This is what worked for me:
  1. Power the radio off (hold the power button in top left corner in for several seconds)
  2. Remove face plate
  3. Hold in reset 10 seconds
  4. Press push-menu dial/button 3 or 4 times
  5. Insert cd and hit source to switch to tuner before cd starts
Not all of these steps may be necessary.
I suspect having the power off before the reset button was the important part.
Jul 26, 2011 | Aiwa CDC-X204 CD Player
I have a cd stuck in my factory cd player, i have an 05 dodge ram 1500, the cd will play but wen i push the eject button the cd switches to the radio and does not eject out
the cd mechanism is probably bad. the only way to repair it is to replace the cd mechanism. it probably has a clarion cd mechanism.
Feb 17, 2011 | Car Audio & Video
Cant adjust the time o the clock
  1. Select Clock Adjustment item during Menu mode (In Standby mode see below for standby mode explained). Select the "Clock Adjust" display.
  2. Enter Clock adjustment mode. Press and hold the control knob for at least one second. The clock will blink.
  3. Adjusting the clock. Push the control knob towards the left or right to select hours or minutes. To adjust each item turn the control knob or push it towards up or down.
  4. Exit clock adjustment mode. Press the (FNC) button.
  • Turn on the power.
  • When the power is ON, select a source.
  • SRC Select mode 1: PRess the (SRC) button and then turn the Control nob or push it toward left or right.
  • To determine the selected source, press the Control knob.
  • SRC Select mode 2: Pressing this button each time switches between sources.
  • Turner ("Turner"), USB or iPOD ("USB" or "iPod"), CD ("Compact Disc"), Auxiliary input ("AUX"), and Standby ("STANDBY")
  • Press at least 1 second to turn off the power
Nov 10, 2010 | Kenwood KDC-MP538U Car CD/ MP3 Player
Mode button unresponsive in my 2006 dodge dakota radio.
After sitting all day in the parking lot at work, I started the truck to go home and everything seemed back to normal. There must be some sort of time related reset. I have not tried pushing the MODE button again and probably won't until I need to.
Nov 04, 2008 | 2006 Dodge Dakota
Driving along and radio stopped working, the word "ocer" came across face of radio. Now, radio and cd player both will not work. Help!
I pushed the reset button and "standby" mode appeared. I proceeded to hit the source button and switched to tuner and cd player with no problems.
Jul 02, 2008 | Kenwood Car Audio & Video
Changing channels with XM radio
Push the button just to the right of present number 1 and this switches the setting between scan and scroll while in XM mode.
Jul 02, 2008 | Alpine CDA-9883 CD Player
Pioneer xc-f10
switch the unit off
With the unit off press the menu button
The Unit now switches on and
you will now be presented with DEMO mode on the Screen
Press the + on the remote
The screen will now display Sensor Mode
Press Set
Press + twice until Sensor Off is displayed
Press Set
Unit switches off
Jun 15, 2008 | Audio Players & Recorders
CDC-X304 in permanent DEMO mode
I HAVE SAME PROBLEM. AFTER I REPLACED MY DEAD BATTERY MY AIWA CDC-X304 IS STUCK IN THE DEMO MODE. ONLY CD WORKS BUT ALL BUTTONS ON FACING DO NOT RESPOND. ANY SUGGESTIONS HOW TO RESET.
Jan 16, 2008 | Aiwa CDC-X304 CD Player
Panasonic CQ-DF203U CD Player Logo
109 people viewed this question
Top Panasonic Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Panasonic Car Audio and Video Expert? Answer questions, earn points and help others
