Question about IK Multimedia Production SampleTank 2 XL
Sampletank2 authorization code lost
Just ran across my old sampletank2 installation disc but i seem to have lost my authorization code.is it possible to recieve another?
How do i copy shows which i have recorded on DVD-R with my philips (DVDR 3305 player/ DVD recorder) to my Macbook pro (I'm using Mac OS X Tiger). The recorded DVD seems to play fine in the philips DVD...
well..the 'shows' you are referring to, may in fact, carry encryption code, making it impossible to play without a license...that's one sure way to make them unplayable, anywhere outside of the DVD player..
Mac's use a different file format than PC compatibles, so that may also be the reason.
Mar 30, 2008 | Televison & Video
I have lost my disc for my f20 navman how do i install it
Visit the official site at Navman.com, click on support,choose your device,every possible solution for old & new gps devices are there.. downloads for drivers & maps...most, if not all are free...sorted,panic over.
Jan 18, 2012 | Navman F20 GPS Receiver
Where do i get parts for a ingersoll rand model b tp5252 I have this old air compressor and it is not working properly I need some knowlage on how to fix it and where to get parts from.thank you.
First with out knowing what part of the country you are in I would recommend searching the internet for the closest authorized IR distributor. They can tell you if parts are available for your compressor or if it is to old. They will need the model and serial number . I have ran across a few old IR compressors that parts were no longer available. They can also get you a manual if available
Jun 23, 2011 | Ingersoll Air Tools & Compressors
Its dvd rw segarome and wont let me install the game. I have a acer 5920 and i installed the original just fine but the old version doesn't work. Its almost like there is nothing in the disk.
It usually wont work to install from a burned disc you need the original disc to install than you can run the game off the back up disc. you should check your EULA to make sure that you are authorized to make a copy of the disc however.
Mar 21, 2011 | Sega Rome Total War Alexander for Windows
My 2 yr old put 2 disc inside we took them out but now it is not reading any disc. says error check manual we unplug to possibly reset and nothing keeps saying same thing.
Depending on how your 2 year old put the discs into the Wii it is quite possible that either the loading mechanism or the laser itself has been damaged. As there are a large number of things that could be wrong the only way to ensure the correct diagnosing is to take the Wii to your local authorized repair center and have them do a complete check of the system.
Mar 11, 2010 | Nintendo Wii Console
An eror occured whwn burning disc Error code
Not sure if this will help but make sure you do not have two dvd-authoring programs on your computer, this might be causing the error you are seeing. There could be an issue with the media you are burning to, sometimes you have to experiment and find discs that work well with your burner. Burn speed may also be an issue, some discs say that you can burn at 4x speed, when in fact that disc may only be able to accomodate 2x - so try reducing the authoring speed to half the maximum the disc says.
I looked on the GoCyberlink website and was not able to see that error code listed in their support pages. Another possibility though not as likely, you could have a damaged operating system or there is a problem with your dvd burner. Wish I could help more.
Oct 09, 2009 | Video Cameras
Lost disc to install printer
ok..take out old software from hard drive(uninstall)
get fresh drivers at www.usacanon.com
re install
do a test page
clean and calibrate the heads
try it again
http://tinyurl.com/6qcpgy
Jul 29, 2008 | Canon MX300 Office All-In-One Printer
FAILURE OF CD READ/WRITE UNIT SONYCD-RWCRX140E
THERE IS A HARDWARE PROBLEM IN THIS, GET IT REPAIRED FROM SONY AUTHORIZED PERSON WITH SONY ORIGINAL PARTS. THINK THERE MUST ME PROBLEM IN LENS OF YOU DRIVE.
Nov 19, 2007 | Sony (CRX230E1/10S) CD-RW/DVD-ROM Combo...
Computers & Internet Logo
Top IK Multimedia Production Computers & Internet Experts
Dan Shibata
Dan Shibata
JonSnell Electronic
JonSnell Electronic
Are you an IK Multimedia Production Computer and Internet Expert? Answer questions, earn points and help others
