Question about Epson Office Equipment & Supplies
Epson Discproducer pp-100 ink pad reset
I'm getting the message "Ink Pad Nearly Full". How do you reset the ink pad counter?
  • John Smith
    John Smith Jun 01, 2015
    You can reset waste ink counters in PP-100 by WIC reset utility
    Filmmaker:
    Uploaded 5 video answers.
  • 22 Answers
You can reset PP-100 by WIC utility
Posted on Jun 29, 2015
  • 341 Answers
You have to replace the ink pad assemble to reset it.
Posted on Apr 18, 2014
5 Suggested Answers
SOURCE: Need To Replace The Waste Ink Pad on my Epson Stylus C66
I modified a little what Worldvet had done. I opened the door as if to change the ink cartridges. I first used a pair of needle nosed pliers and carefully took out the sponge type pad which is along bottom of the printhead travel lane. One will see the two center plactic guides within this lane. The sponge is very delicate, so be very gentle in removing it. It has ink residue in it so use gloves if necessary and upon removal place the sponge on a paper towel folded in triplicate so the ink does not bleed through the towel. Remember to what position it was before removal, so there is no problem when you try to replace the sponge after cleaning.
The second sponge I removed as follows: With the power on, I pressed the ink cartridge removal light (red) (far left) once. This moved the print head to the "far left", before the position to change cartridges. With the power still on and the printhead to the far left, I was able to very gently (with the same needlenose Pliers) remove the sponge under where the printhead was parked. It too is very delicate and be careful not to rip it. It too, one will find, has two plastic slots on the botton which the sponge will have to be returned into. I then turned the printer off, which caused the printer head to return to the parked position.
I took both sponges, and with Alcohol (Pharmacy type), I placed the sponges in a disposable plastic bowl and filled it with the alcohol. I gently used the needle nosed pliers (Closed) as a device to gently press on the sponges which were submerged into the alcohol. I continued to alternate up and down the sponge pads, causing the alcohol to dilute and clean the pads. When the alcohol became saturated with the ink from the pads, I took the pads out of the alcohol bowl and placed the pads on a triple folded paper towel so the remaining ink would not bleed through anything.
I then took the bowl of alcohol/ink and while I flushed the toilet and the water was going down, I emptied the alcohol down the middle of the water spout as the toilet water was completing its flush. This keeps any ink from touching any porcelion.
I then refilled the plastic bowl again with fresh alcohol and resubmersed the pads, just incase there was any ink still left in them. Upon pressing on the pads and the alcohol remained clear (indicating all the ink was removed) I again used another set of paper towels, trippled, and placed the pads onto the paper towels, and squezzed them dry. I disposed of the alcohol the same as before.
I then, first replaced the large pad onto the printhead travel lane, back into the same position, being careful that the holes and slots fits back into its proper position and the edges are tucked under the proper hooks (little plastic hooks attached to the side of the travel lane).
Upon reinstallation I pressed gently on the pad to make sure it was secure.
Replacing the second pad, I again turned on the printer and pressed the ink replacement light (red), same as before, causing the printhead to travel to the far left as before. I then very carefully replaced the second pad into the slot from which it came from.
After I made sure the second pad was secure in its proper position, I pressed the ink replacement light twice, causing the printhead to return back to the parking position. I had already reset the counter, so that was not neccessary. I returned to the computer and printed a test page to make sure the printer was working properly, at which time it was, so I therefore returned to what I was doing and the Service Warning was cleared. My fingers got a little ink; but what the heck, soap will take care of that! Good for another 20,000 pages. Hope this helps, not as bad a it sounds.
Posted on Mar 26, 2009
  • 5 Answers
SOURCE: EPSON 2200 - Waste Ink Pad Replacement
You can replace the pads yourself.... I wouldn't really mess with it though. There are other ways Google search "Waste Ink Epson 2200" to see how to setup an external tank.. I have mine setup this way and its been no problem.... If you're set on taking them out remove the screws from the sides and middle and the bottom will drop away and reveal the pads.
Posted on Apr 16, 2009
websnail
  • 419 Answers
SOURCE: reset ink-pad counter on epson stylus photo 1400
The simplest way to do this is to grab a copy of the A10_IPR utility that Epson distribute to their customers...
The utility is available to North American customers if you register no this site page http://www.epson.com/ipr/
The utility is also know to be available in the wild if you search for "waste ink ipr".
Just remember to scan any download using a virus and malware scanner before you attempt to use it as some utilities contain trojans or similar nasties.
Hope that helps.
Posted on May 12, 2009
SOURCE: Epson 750 waste ink pad full
Dear Hugh Slaven,
You will need to go to the support section for Epson, and read their troubleshooter, but I reckon you will have to manually remove the cartridges and then clean/ change them, then clean the printer, try then re-calibrating after that and see how you go.
I hope this is the fixya for you and look forward to hearing how you get on.
yours sincerely
Ouszen
Posted on Feb 07, 2012
How do I reset the waste ink pad on my Epson Discproducer PP-100
The most easy way to reset Epson PP-100 Waste Ink Pads is to use WIC Reset Utility and reset waste ink counters by Yourself.
There is video tutorial on Youtube - How to reset Epson PP-100 Waste Ink Pads Counters:
Jul 03, 2014 | Epson Office Equipment & Supplies
Reset counter on epson pp100
go to PP-100.com site - there is full solution for epson pp-100 reset
Feb 20, 2014 | Epson DiscProducer Disc Publishing System...
Ink pad counter reset
I'm not sure from your post exactly what the issue is? Please explain problem in more detail!
Jan 16, 2014 | Epson DiscProducer Disc Publishing System...
Epson discproducer pp-100 ink pad
If You want to reset Epson PP-100 Discproducer Waste Ink Counter You can use WIC Reset Utility and reset it in few clicks.
You can watch video how to reset PP-100 waste ink counters -
Jan 16, 2014 | Epson Office Equipment & Supplies
Replace Ink Pad in Epson Discproducer pp-100AP
Previous answer has no relation to PP-100.
It is for desctop printers.
But for Epson PP-100 reset you have to use WIC Reset Utility and reset Waste Ink Pad Counters in Epson PP-100 Disc producer by 3 clicks.
Here is video tutorial how to reset waste ink pad counters in PP-100 - http://pp-100.com/reset.shtml
Nov 01, 2012 | Epson Office Equipment & Supplies
How to troubleshoot epson stylus T13 ink pad?
Epson t13 all problem solved EPSON T13 WITHOUT CHIP , INK LEVEL ALWAYS FULL,
NO NEED TO RESET INK LEVEL EACH TIME .
INK LEVEL AUTO RESET WHEN PRINTER SHUT OFF.
INK LEVEL LEVEL ALWAYS SHOW 100 %
NO WASTE INK PAD COUNTER MORE
NO NEED TO WORRY WHILE PRINTING MORE PRINT JOBS
watch video here
http://www.youtube.com/watch?v=CouogJKjXuY
Jun 06, 2011 | Epson Computers & Internet
EPSON STYLUS T13 printer's ink pads are at the end of their service life HOW TO RESET FREE
Apr 26, 2011 | Epson Printer
I have a problem with my printer epson stylus C90. may i know what todo when parts of my printer are near the end of their life service.?how can i fix it?
It means waste ink pad full or nearly full. Reset waste ink counter using SSC ver 4.30. Find at indoreset.blogspot.com. Don' forget to replace pad, washing or extend outlite pipe to outside of printer.
Jul 23, 2009 | Epson Office Equipment & Supplies
Printer won't printer as message says parts are
Part are end life cycle : waste ink pad full. Need to reset waste ink counter. SSc ver 4.3 support RX 620 and 640. U can try using printer model RX 640. Menu Protection Counter, Show current value for checking. Reset protection counter. Or Try to find RX630 adjusment at indoreset,blogspot.com. Don't forget to replace or wash the pad. Or extend outlet waste ink pipe to outside.
Jun 28, 2009 | Epson RX620 All-In-One InkJet Photo...
I have a warning that my ink pad is saturated and needs replacing contack dealer for assistance (help)
Ink means pad for waste ink nearly full. Epson program read and count all waste ink from head cleaning and ink charge. Next, you need reset waste ink counter, and replace or washing pad. You can extend outlet pipe to outside of printer, so next time you don't need replace pad again.
Jun 27, 2009 | Epson Printer
364 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
