Question about Kenmore 2.1 cu. ft. Compact Portable Top-Load Washing Machine 4472
Kennmore 4472 don't accept hot watter...
Valve is open only two lights on hot and cold if u chosee hot the machine never get hot watter inside..
ginko
  • 19396 Answers
SOURCE: ty for being here. I have a kenmore stack washer
Inside the machine you have a valve called inlet.
The inlet water valve will collect the cold and hot water lines, and open alternatively one or the other during cycle.
To access the inlet valve you need to take apart the machine, and that is not an easy task.
If you DIY remember to unplug power, there is high voltage running inside your appliance.
Below the inlet valve for your model:
1014350
Posted on Mar 05, 2009
SOURCE: no cold water going into tub, valve is open
make sure the hoses are not kinked and check the screens inside the valve inlet and make sure they are not clogged
Posted on May 25, 2009
blueextc3221
  • 15935 Answers
SOURCE: Kenmore HE3t Hot water valve opens even when COLD/COLD selected
It appears your timer/controller board has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 13, 2010
blueextc3221
  • 15935 Answers
SOURCE: cold water into tub of wash machine
For low water volume - or "Trickling" effect...
1. Turn off the water supply to both hoses.
2. Remove hoses (one at a time so you don't get them confused)
3. On the washer side - look for a removeable screen inside wher you just removed the hose.
4. Using a small screwdriver - pop out the screen and reverse-flush it/clean it. It will likely be full of sediment and calcium deposits from your pipes.
5. Replace the inlet screens.
6. Re-fit the hose to the machine.
7. Turn on water supply valves.
8. re-try.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!
Posted on Sep 14, 2010
blueextc3221
  • 15935 Answers
SOURCE: cold water feed into tub seems somewhat pluged.
8. re-try.
Admiral heavy duty AK40 doesn't take hot watter
(the following is pre-typed but it's worth checking both hot AND cold filters!)
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve. Sorry but it needs a service call and a check that it isn't the control PCB ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
Aug 22, 2011 | Admiral Washing Machines
We can only use hot water in our Whirlpool 7.5kg WFE1070BD 1000RPM - how to we shut off the hot water and use cold water? We have tried only cold but the machine will not operate. Please help. Many...
Turn off the water to the machine. Disconnect the cold water hose from the back of the machine and put it in a large bucket. Turn on the water to see if you get full-pressure cold water from the hose. If not, the shut-off valve or other plumbing has a problem.
If you do get cold water from the hose, check the strainer inside the hose fitting on the back of the washer. Clean it if it is clogged. If you still don't get cold water in the machine, you have a problem with either the solenoid valve or the cold water fill contacts in the timer (the timer won't start until the tub is up to the selected level, but if the valve isn't opening or the supply line is otherwise blocked, the machine will never fill). Sometimes in this case you can hear the solenoid valve humming (normally the sound is masked by the running water).
If the problem is a clogged strainer, clean out the hot water strainer also.
I find I get better wash results with warm water (runs both hot and cold for the wash cycle). The soap is more active than in cold water, so I don't need quite so much, and the machine doesn't take as long to finish a cycle since it fills faster. Of course, the cold water has to be running to get the energy savings compared to hot only.
Jun 06, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
I have a Maytag (FAV6800AWW) top load washer. The cold water won't shut off except at the valve. The cycle will run properly with hot water but if you have the cold on it just runs until it...
the water valve is bad in the rear area inside the machine,its controlled by electrical solenoids and the valve is stuck open even with the unit shut off,replace the valve combo hot and cold as these dont repair
May 29, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Cold water will barely flow into machine....already cleaned out strainer on incoming cold hose, water flows fine...however, once it hits the machine, it barely drips to fill up the washer. Hot water is...
bad water valve,the stuff you cleaned out of the screen most likely got inside the valve,another thing that can happen if you don't change the valve is that the valve can get stuck in an open position and it won't shut off and flood out your house.call the parts store give them the model number and they will sell you the right valve.next time send the model number and brand name,good luck.
Apr 30, 2011 | Washing Machines
Washing Machine Rinse and Spin lights are on
its the problem of drum getting blocked by any clothes getting tucked up.also try to move the drum manually with the machine off.if it makes any noise its the faulty motor.or drum has lost its alignment.it needs to be reseated properly in that case. -------------- The water fill valve - The water fill valve is a mechanical and electrical part, the coils on the valve need electricity to mechanically open the valve to allow the water to flow into the washer....myth....the washer pumps water into itself...no, it does not. The fill valve opens and the house water pressure pushes the water into the washing machine.
No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can test a fill valve live for 120 volts, power to a fill valve coil and no fill = a bad fill valve. You can also test the coils for continuity, no continuity = a bad fill valve. Some Maytag washers have a fuse in the fill valve circuit, if this fuse let go the washer will not fill. Fill valves can also from time to time stick open and not stop filling. If you have to shut off the fill valves to stop the water from filling in the washer, you have a bad fill valve and you will have to replace it.
Jul 23, 2009 | Tricity Bendix AW1400W Front Load Washer
No cold water going into tub, valve is open
May 25, 2009 | Kenmore Washing Machines
No hot water going into wash tub. Hot water else where in house.
on the back inside the washer are two solenoid operated valves that control the hot and cold water flow. your hot valve has ceased to function...and needs replacement.  also make sure your hot water valve is open fully and that the screen inside it isn't clogged.
Apr 03, 2009 | Kenmore 22422 Top Load Washer
My whirlpool front load washing machine accept hot water and no cold water entering on the machine.
Apr 01, 2009 | Whirlpool GHW9400 Front Load Washer
Ty for being here. I have a kenmore stack washer
1014350
Mar 05, 2009 | Kenmore Washing Machines
Cold water no flow on Kenmore front load washer
Check cold hose to see if it is clogged or the filter in the end of it is. Make sure water freely coming out from the tap. If that is all ok then replace the watter control valve on the cold side.
Dec 31, 2008 | Kenmore 43142 Front Load Washer
Kenmore 2.1 cu. ft. Compact Portable Top-Load Washing Machine 4472 Logo
13 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
