Question about HP Computers & Internet
DV8309 power up problem: blue lights on for few seconds then off
Problem with Laptop: HP Pavilion DV8309, AMD Turion 64 processor, 17'' monitor, Windows XP Professional, Ver 5.1, service pack 2 build 2600, bios updated to F.54, ATI xpress 200 video card 128 Memory. I have reinstalled the driver for it.
Computer does not power on properly: when power button is pushed,the blue light comes on, the screen shows HP logo both for may be 2-3 seconds and then power shuts off. This happens with battery only (now that the battery cannot be charged, systgem does not do anything with battery only), battery plus mains, mains only without battery. Battery is brand new.
The other problem is that battery does not charge. If i leave the main power plugged in, computer off, battery in computer: the battery blue light starts blinking within a few minutes after plugging, indicating problem with charging.
Now, I accidentally discovered something: With battery out, main power plugged in, i connected the external monitor to this laptop,)if i push the little pin switch behind the power button (which turns the laptop's display panel off), I turn the computer power on,, computer works fine. As soon as I let the pin switch go, computer turns off. So I put some weight on the pin switch to keep it pressed in and the computer continues to work indefinitely untill i turn it off.
The above thing does not work if I insert battery in, perhaps because the battery is totally dead. Occasionally the charging has worked.
Even though the panel is off, no image on it, i think the computer still sees it because if i have it set as one of the two monitors, things are present on it even though i cannot see them( with the pin switch off)
An extension of the above phenomenon: In the ''display setup'' i changed the primary monitor to be the external monitor and the panel turned off. Turned on the computer, it works fine.
This is the whole story. So, please, what is your diagnosis? I don't know anything about computers. I think it has something to do with the laptop display panel and not the mother board.
Thanks for the help.
  • 157 Answers
The inverter inside the lcd panel is most likely your problem. Try removing the whole lcd screen from the laptop if you are capable and run it with the external screen to confirm. leave the lcd switch off (this lcd switch above the power button turns the lcd inverter on and off)
Posted on Jun 19, 2009
What is the best processor to get for upgrade?
Here is the Fastest processor that will physically fit Turion 64 X2 TL-68, but this will use more power and generate a lot more heat. The best I would advise is the Turion 64 X2 TL-60 This draws the same power and will increase the speed to 2Ghz on 2 cores. So the extra heat produced should be minimal and your battery life should be very similar.
Aug 02, 2013 | HEWLETT-PACKARD HP Pavilion DV6325US AMD...
Amd turion 64 ml-32 processor driver
what the is it a problem with the dvd or the processor
http://download.cnet.com/intel-chipset-driver-7/3000-2122_4-162211.html
if this driver is not rig
http://download.cnet.com/2000-20_4.html
on the home page you should see a search tab just type in what you are looking for
you might have to try a few times to get it right
hope it helps
Jun 25, 2012 | HP Pavilion dv8000 Series Laptop DVD Drive...
Describe your HP Pavilion dv6000z 15.4" Notebook Laptop PC (AMD Turion 64 X2 Duo Core TL-50 1.60GHz, 1GB RAM, 100G... (d6000z) PC Notebook Problem SCREEN WONT TURN ON LED LIGHTS OF POWER BUTTON...
The dv6000 series was commonly affected by the video card heating up and reseating itself. This was usually a soldering issue. You have a few options, You can either replace the motherboard, or have the motherboard reflowed. Unfortunately the video card itself is not detachable or individually replaceable.
I personally would recommend the second option as purchasing another dv6000 board will likely end you up in the same situation a year or 2 later.
A repair / reflow services on ebay
Dv6000 Repair
This repair tech only does amd processor models, Not intel.
Hope this helps.
Aug 29, 2011 | HP Pavilion dv6000z Notebook
Will a turion 64x2 processor from a av7170 interchange with a sempron processor in a 7115-eh1?
Processor Type 754-pin (uPGA); 638-pin (uPGA)*
Support Processor
AMD Turion64 X2 Dual Core
Processor,
AMD Turion64 Processor
(25/35W series),
Mobile AMD
Sempron™ (25W series)
Those are the ones that your laptop supports
Dec 17, 2010 | Averatec AV7170-EC1 Notebook
My HP dv9208nr laptop screen is black after I power it on.
Hi:
I am sorry to tell you that this series of HP laptops has a known problem with the video chip on the motherboard. There are thousands of complaints to HP about the DV9000 seriies laptop, and yours has the same sympoms that others have reported. HP extended the warranty on some, but most people lost their shirts. There are a few people who have had mixed success in repairing the motherboards, but often they have to get replaced. If you did a google search on yor laptop problem, you will find lots of info.
The bottom line is that your laptop is expensive to fix, and it is a known problem!
Feb 03, 2010 | HP Pavilion dv9208nr Turion 64 X2 DC TL-50...
Amd turion x2 rm70 vs intel core 2 duo t5750!!!!
I read this and don't believe you - yes the AMD dual core gets hot - yes AMD processor are HOT processors - is intel better - no there on par with AMD - the thu put rate is so close it doesn't matter - now vista basic is just that BASIC - if you want to bump it up - home premium 32 or 64 but ultimate 64 should get it going.
Oct 30, 2008 | HP Pavilion DV5234US Notebook Laptop
Computers & Internet Logo
352 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
