Question about Taylor 2001 754 Air Cooled Soft Serve Frozen Yogurt Ice Cream Machine 100%
Product comes out frozen after all night on standby in a 754 taylor
    Scholar:
    New Friend:
  • Taylor Expert
  • 35 Answers
Bingo! Here's a link to that part. X31602 Barrel Probe Thermistor Stand bye
Posted on May 24, 2017
    New Friend:
  • 3 Answers
The same thing happened to my Taylor 8756 and it was the thermistor probe. The probe is a thin copper tube that is near the freeze cylinder. It cost me about $20 for the part and $200 for the labor to have a technician put it in. Hope this helps and good luck.
Posted on May 09, 2014
Does the taylor model 8756 put out a substantial amount more product than the 754?
Absolutely! The Taylor 754 and Taylor 794's are capable of 284 3 1/2oz. servings per side / per hour. The 8756 is capable of 426 of the same 3.5oz. servings. The 8756 packs more air into the product making it easier to freeze and reducing recovery time.
Soft Serve Parts Taylor Machines
May 07, 2017 | Taylor Ice Cream Makers
Taylor 8756-33. Which components operate in standby mode?
In standby mode, the machine just wants to keep the product refrigerated until it goes back into auto.
So, the mix cabinet needs to keep the product cool in the bottom of the machine, that requires the mix compressor and fans to run. The mix cabinet temperature is read by a thermistor probe and regulated by the (left side) logic board.
The product in the cylinders should go back to liquid form in standby, but we still have to maintain that safe food temperature, the motor and compressor will run periodically. If the machine is air-cooled a fan will run anytime the compressors run. If it is water cooled, water will flow through the machine when the compressor runs. The temperature in the freezing cylinders is read by a different thermistor probe and regulated by the logic boards.
Here is a link to all of the parts in a Taylor 8756.
http://www.softserveparts.com/c-1335911-parts-8756.html
Jul 20, 2015 | Taylor Ice Cream Makers
Standby keeps turning on when in standby but auto works turns itself on and off fine. Both sides of unit
I don't think you have a problem... I have a Taylor 8756p-27. In standby mode with my unit the beater motor turns on for about 15 seconds every 15 minutes and the compressor turns on as needed to keep the mix at a safe temperature. This is what standby mode is supposed to do. If you don't want it to turn on and off so much in standby mode, perhaps leave it in AUTO mode and it will turn off and on as it needs to to keep your product at the proper temperature.
May 06, 2015 | Taylor 754-33 Ice Cream Machine Soft Serve...
I bought a Taylor soft serve ice cream model #754-33 and serial #k1126268 I need to know how to set it and make ice cream?
too hard to explain online, you need to contact your local taylor dist. or a local service company who might install or know about them.
Feb 19, 2015 | Taylor Ice Cream Makers
On the soft Serve side of my Taylor ice cream machine it is freezing up and not letting any product come out pump still works don't know what the problem is I take everything apart clean it put it back...
if the product is frozen in the barrle for sure then you have a bad micro switch that is telling the compressor to keep running, but that product would be super frozen and come out in the shape of the barrel. if it is the consistancy of ice cream then your pump gasket might be bad and not properly pressurizing your barrel and giving you the impression of a frozen barrel.
Why is my taylor 8756 - 27 freezing the chocolate side and will not dspense?
This seems like it could be many things. Is the pump coming on when you try to dispense? Can you stick a thin wire up through the feed holes in the chocolate side when you try to dispense to help free the product?
May 04, 2014 | Taylor 754-33 Ice Cream Machine Soft Serve...
My Taylor c713 is on "R Beater Overload", I came into the shop to find it had done this over night.. I emptied the ice cream out of the machine and cleaned it, upon pushing the reset button and trying to...
That is most likely the stand by probe. The standby thermistor probe measures the temperature of product, in this case in the freezing cylinder, while the machine is in standby. Usually when the thermistor fails, you come in in the morning to find that the product is liquid and the reset has been tripped. The motor should be nowhere near the overload setting in standby as the product should be liquid. Thermistor probe C712 C713 Barrel Stanbye Probe
Oct 12, 2013 | Taylor 632-33 Ice Cream Maker
I purchased a used taylor 754 about 6months ago i never try to use it...last month i passed the city and health inspection...i unwraped the used taylor 754 machine and plug to the outlet and light...
That's a low mix light. It tells you that you don't have very much ice cream mix left in the hopper. There is a sensor in there that when no mix is touching it, it turns that light on.
Jul 24, 2017 | Taylor 632-27 Ice Cream Maker
Taylor 770 soft serve
754-27 Taylor soft serve machine Beater motor not running - compressor not engaging - Power to beater relay but not out of relay.
May 18, 2008 | Ice Cream Makers
Taylor 2001 754 Air Cooled Soft Serve Frozen Yogurt Ice Cream Machine 100% Logo
339 people viewed this question
Top Taylor Ice Cream Makers Experts
Dennis Boxerman
Andrew Taylor
Andrew Taylor
Gil Shultz
Are you a Taylor Ice Cream Maker Expert? Answer questions, earn points and help others
