Question about Roper Dryers
Wont spin dryer wont spin - will turn on and heat
    Top Expert:
  • Roper Master
  • 51,494 Answers
Could be a broken belt
Posted on Mar 13, 2015
4 Suggested Answers
SOURCE: the dryer wont spin
Most likely problem is a broken tub belt. Need to take off fron of dryer to investigate.
Posted on Apr 28, 2009
hunter19_46m
  • 7482 Answers
SOURCE: the dryer hasower but barrel wont spin heat is
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Sounds like your problem may be a broken belt, or the belt may have slipped off of the motor pulley, or idler arm pulley. If you have to replace your drum belt and if you have a front loading machine. Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch. Then remove the top of the dryer. Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum. Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn. While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them. I will include these two websites for parts and further help: http://www.partselect.com/ http://www.appliancepartspros.com/index.aspx Both also have chat assistance 24/7. Good luck, I hope this helps
Posted on Nov 19, 2009
SOURCE: maytag dryer wont spin
I have a Maytag Centennial Commercial Technology model#MEDC300XW0 electric dryer in heats but drum won't turn.
Tonya
Posted on Jul 03, 2013
Dryer will turn on and count down but will not start to spin or heat up, model med6600tqo
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Apr 28, 2011 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
The dryer in my trailor tub wont turn I have Heat but the tub wont spin.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Mar 08, 2011 | Dryers
Dryer wont heat up just spins keeps spinning with timer set. replaced heat element and still wont dry
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
l;
Jan 03, 2011 | Roper RGX4634KQ Gas Dryer
My dryer wont spin.It heats up and comes on but wont spin.Model # 96320100
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
heatman101
Nov 07, 2010 | Kenmore Dryers
Maytag dryer wont spin It makes heat,but the dryer wont spin
Sounds like the drum belt is broken or off the pulley of the motor
Sep 25, 2009 | Maytag Dryers
Power on but it won't spin.
You have a broken drive belt. To access the belt you have to remove the back metal cover.
The no heat problem could be a heating element or safety thermostat. These are also located under the back metal cover.
Jun 02, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dryer will not heat but turns on and spins but no heat.
check breaker first it will run with the breaker tripped but it wont heat so turn off and on then check dryer for heat.dryers have a thermal fuse when they go bad it wont heat they are located on the element cage and are smaller than the thermostats.and if that is good then most likely element.but it usually helps to know what brand?
Mar 11, 2009 | Dryers
Dryers Logo
44 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Roper Dryer Expert? Answer questions, earn points and help others
