Question about Sangean RCR10 Clock Radio
No Display My clock radio suddenly had an unreadable display. I changed the backup batteries, and now it has no display, although the sound still works. What can i do?
Why does my nelsonic nlc690 am/fm alarm clock radio display 18:88 and not allow me to set the time?
Sounds like it is broken!
Unplug it and remove the backup battery if it has one. Count to 10 and put the battery back in and plug back in.
If that doesn't work, just buy another one as they are cheap enough!
Nelsonic Led AM FM alarm clock radio NLC690 AWESOME CONDITION
Jan 13, 2016 | Audio Players & Recorders
The display is suddenly filled with information (sometimes unreadable). Everything has now stopped working.
From the sounds of it the microprocessor is scrambled, this can be caused by a power surge or thunderstorm, unplug unit, press and hold power button for 60 seconds in an attempt to clear the processor, if this fails this will be a job for a Bose factory trained technician.
Sep 16, 2012 | Bose Wave Radio
After a power outage of approximately 45 minutes i have no display
Hello
There is a Lithium battery inside your clock to get a backup even the power is interrupted for a long time. This battery may last up to 3 years eventhough there is no power to the device. If this has gone weak, the backup fucntion will not be. so check this battery.
Just reset the device. It will make it work properly. To reset the clock after total memory loss; do the folloing.
[1] Connect the radio to your AC outlet and let the clock set itself.
[2] Depress the MONTH/DATE and TIME buttons together. The display will change
from 'Time'to 'Year'
While holding the MONTH/DATE and TIME buttons, press the SET + button
to set the display to the correct Year, then release the buttons
OK.
Jul 24, 2011 | Emerson Smartset Clock Radio
My Philips AJ3980 radio suddenly has no sound. Also, the band "MW" appears in the display and I'm unable to tune AM stations. The clock seems okay. Thanks for your help!
1. Press the RADIO button to switch on the radio.
- Radio touch screen controls appears throughout
radio operation
- The radio frequency and waveband appears in the
display for 10 seconds before reverting back to the
clock display.
2. Press the BAND button to select your waveband FM/AM.
3. Tune to your station manually or automatically
by using up / down.
Here is a figure to help find the control buttons:
Please change waveband to FM.
Thanks.
gylacz
Jun 20, 2011 | Philips AJ3980 Clock Radio
Which the voltage of the transformer to be replaced
Hello
Your clock has a backup battery. Battery is for time backup only.
The clock and alarm memory will
be retained during a power
interruption. During battery
backup operation, the display
will not light up, but the correct
time will be maintained internally
The mains transformer inside it will be of 10.2vAC secondary to 120VAC primary. OK.
May 13, 2011 | GPX CRCD2806 Clock Radio
Radio worked fine......then I was trying to find another channel by turning the tuner knob and all of a sudden it just locked and when I turn the tuner knob it won't change stations. Nothing works but the...
This may help: If you take off the front of the radio (don't forget 2 screws in back!) you will notice a set of black and red wires running from the 2 AA backup batteries to the digital display circuit board. The wires plug into the board with a little white plug. If you unplug this the display will fade to nothing. If you plug it back in it will display an unset digital clock format. This seems to reset the radio, after which it should work.
Feb 08, 2011 | Dewalt DC011 AM/FM Radio
CRA108: I can not set the time. I hold in the time button down while pushing the hour and/or minute button but nothing happens. The clock actual is displaying a time that is not proper. It currently...
My Coby CRA108 starting doing this after 6 months of use. Although I described the display as 1P:C8 since there is no key to properly display the character (hybrid of a G & C). I've left it unplugged and changed the backup battery with hopes it would reset. No luck so far. Anyone have success???
Jan 07, 2011 | Coby CRA108 Clock Radio
My dewalt stopped giving any sound
Try this if the display seems stuck on the same station: If you take off the front of the radio (don't forget 2 screws in back!) you will notice a set of black and red wires running from the 2 AA backup batteries to the digital display circuit board. The wires plug into the board with a little white plug. If you unplug this the display will fade to nothing. If you plug it back in it will display an unset digital clock format. This seems to reset the radio, after which it should work.
Nov 11, 2010 | Dewalt DC011 AM/FM Radio
Insignia clock radio goes to 12:00 after turning off power
I found this solution by reading some reviews. A reviewer said it was caused by a weak backup battery that powers the display. He said to change the lithium backup battery of the main unit with the backup battery in the remote. I tried it and now it works. I can turn the unit on and off and it doesn't reset my memory. But this hasn't solved my problem with setting the alarm.
Nov 23, 2008 | Insignia Digital Clock Radio with Apple...
Flickering and faded display
Have same problem. Cheap company, no POC phone number in handbook, no address.
Aug 02, 2008 | Cambridge Soundworks CD-740 Clock Radio
Sangean RCR10 Clock Radio Logo
42 people viewed this question
Top Sangean Audio Players & Recorders Experts
Mark Schmit
Mark Schmit
Are you a Sangean Audio Player and Recorder Expert? Answer questions, earn points and help others
