Question about Home
Jacuzzi Select model 10 years old. Motor
Jacuzzi Select model 10 years old. Motor circulates water at low pressure, no high pressure. Water is 102 degrees, light works, but no high velocity water flow or pressure
  • Anonymous Mar 19, 2014
    Possibly limescale?? Live in high limescale Area
    Scholar:
  • 80 Answers
Sounds like the high speed relay is stuck or not working at all, It is in the main contol box, and can be manually tripped to see if this is indeed the problem. Unless you are a skilled repair tech, this job is better left to a pro.
Posted on Aug 19, 2009
Have a jacuzzi model H25000, z150/350. It won't get to high temperature only temp up to 90 degrees. What can I do?
This usually relates to one thing: a dirty filter. Here's why: pump tries to such enough water through the filter. It can't because it's dirty so the water pressure is too low to allow the heater to come on. So, it keeps running trying to heat. Pull out your filter and leave out for a day/ your temp should go up..if it does not then you will need to look at the pressure switch isn't closing. The switch can be adjusted for a very temporary fix. The permanent fix is replacement. Hope this helps Happy New Years Tim
Jan 02, 2017 | Cars & Trucks
Taco 007 not working
If the motor is getting warm I would suggest replacing the Cartridge assuming all the air is out.
Jan 23, 2014 | Taco Cartirdige Circulator Model 007
Water not pumping
Is the pump running? If so I would say you lost your impeller. If not running I would check for a circuit breaker for the motor.
Apr 10, 2013 | Intex Automatic Salt Water System for ...
I have an above ground pool with a jacuzzi pump. (1.5 hp). I just replaced the sand in the sand filter. I also put on a new o-ring on the jacuzzi pump cover. When I turn on the filter, the pump fills up...
I think you have a air leak. A 1.5 hp motor is very strong and should vacuum well. Be careful to not over tighten the top of your pump housing.
Is your impeller in good shape? It may be worth your while to remove the pump motor from the pump. While you have it apart, replace all the seals (there is a kit for this). Inspect the impeller and all parts of the housing - any junk inside? Remove it. After you complete the rebuild, reinstall the motor, fill the pump housing with water, secure the top and start the pump.
Let me know what happens ...
thanks for your interest in FixYa.com
Jul 03, 2011 | Jacuzzi Pool & Spa
I Have a Jacuzzi Magnetak pump. I do not know the horse power. 115 volt, 12.4 amps, 3450 rpm. It is attached to a DE filter sstem. The pump is at least 6 years old. It runs well and pumps well for 1-3...
The earth filter is in need of a good cleaning. You may even need to acid wash it. Welcome to the high-maintenance draw-backs of a DE filter! Once cleared your system should go back to operating normally.
Jul 30, 2010 | Jacuzzi Cyget In Ground Pool Pumps
Apparently no water pressure to upper washing arm.
Hi sounds like there is a blockage in the circulation pump which causes low water pressure as it cannot push the water around. You would have to remove the unit and turn on it's side and remove the circulation pump to clear the blockage.
Also check all the holes in your spray arms for any blockages. Best to remove each arm and clean in the sink. Any blockages causes the arms not to turn.
Jan 24, 2010 | Frigidaire Dishwashers
I have a Jacuzzi laser sand filter. The system worked fine until I noticed that the circulating motor was extremely hot when running. The pump and motor were very old and in poor shape. So I replaced the...
this sounds like a supply power problem. The motor is not getting enough power. Check the line to see how many amps you're getting. The motor will tell you how many amps you need on the data plate. When a motor heats up and trips it's internal high limit, it's usually due to insufficient supply power. Heat is a byproduct of inefficiency. Also, if this is running on 220v, make sure both legs of 110 have power. Sometimes motors can attempt to run even though half the volts are missing.
Oct 30, 2009 | Jacuzzi Cyget In Ground Pool Pumps
I have a jacuzzi 1/2 hp submersible well pump. Does this need any regular maintainance to keep it happy.
No preventative maintenance is necessary. However, a happy pump always has water above it and should not pump sand. If the water level in the well is below the pump/motor they will overheat. If this is a problem your local pump company can install a module to protect your pump from this type of event.
Please rate this answer.
Jul 03, 2009 | Jacuzzi Brothers 1/2 Hp 8gpm 2 Wire...
Jacuzzi hot tub will not shut off
I take it for granted that you know when the tub is in cycle mode for water circulation, ( the tub will do this every 4 to 8 hours unless programed otherwise). If it is truly going into the low speed on the pump, the problem lies in the circuit board. The double click you hear is the relay for the pump turning off and then on again. This is a costly problem to diagnose as circuit boards start at 200.00 and go up. If it is the relay, the only way to replace one is to replace the circuit board.
Jul 03, 2009 | Jacuzzi EH0 / EH1 / EG9 Fuzion 6666 Corner...
Home Logo
364 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
