Question about Kenmore Elite 45986 Front Load Washer
Washer starts filling but stops
The washer starts filling then stops. The time continues to count down, but the drum never moves. It will start to fill again, and then stop periodically.
  • 979 Answers
There are a host of things it could be. I would start with the solenoid first. This is what allows the water in and then is told to stop after a set period of time. F your washer is much older than 7-8 years old, then I would consider replacing because you may be seeing the beginning of the end for your washer. The monies you put in will only buy a little time and. Have a tech that is qualified will help you determine this. This is what I would recommend.
Posted on May 07, 2014
  • 1314 Answers
SOURCE: Kenmore 80 Series Model 110.20862990 Type 111
no the timer doesn't control the water fill the pressure switch does you have three possibility's either the pressure switch is malfunctioning or a water valve is hanging open or the pressure switch pressure hose is leaking or off the tub the pressure switch is connected to the knob that lets you select the water level in the tub if you back out the two screws on the front or back of the end caps depending on the model you can pull the control panel forward and tilt it back to access the pressure switch its gold in color and has a clear latex hose attached to it also take the hose loose and blow through it to make sure its clear with the washer empty of course lol if you need more info just reply to me be glad to help water can also leak out from the pressure switch hose if a mouse has chewed through it or its come loose from the tub
Posted on Mar 18, 2008
duby1990
  • 370 Answers
SOURCE: Kenmore 70 series washer model 82870120 will not stop filling
you need to replace the water valve. This is a common problem and a very easy fix. You can order the part at sears.com via model number and also see a breakdown of the machine and how to put it in.
Posted on Mar 03, 2009
  • 1122 Answers
SOURCE: Washer filled with water then stopped. Kenmore 110.25842400
first check the lid switch-mike
Posted on May 12, 2009
SOURCE: washer starts to fill then stops /now warsher wont wash
I too was having the same problem and I almost paid to have it repaired, which would have cost a few hundred dollars, thanfully I called the recall line after reading some of the other post on here and my machine was elgible for a upgraded on the control panel so didn' t cost anything for us. Sears told us that the F1 code is a miscommunication in the control panel, basically the machine is confused and don't know what to do so it stops and gives that code. Hope it helps!
Posted on Jun 23, 2010
blueextc3221
  • 15935 Answers
SOURCE: Kenmore Washer 48102 starts filling then stops
the pressure switch should be tested for failure.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
Affinity top loader
Good Afternoon Friend,
I understand that your Affinity washer starts to fill with water and stops, while the counter continues counting down. I also see that nothing is happening while this is going on. I suggest resetting your appliance, by either unplugging it or shutting the power off at the circuit breaker, for 3-5 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully.
-Best Regards-
WP
Jun 21, 2014 | Frigidaire Washing Machines
Start wash program, fills with water, then drum does not turn.. Tried rinse progam, water ,does not turn.. Can hear relays clicking but nothin moving. But the time carries on counting down. It does drain...
If the motor is not spinning, you may have a burnt out motor or faulty Motor Control Board. Else, if the motor is spinning, fix the belt from the motor to the drum.
Oct 29, 2011 | Bosch Exxcel WFX 3267 Front Load Washer
My washer continually fills with water
your fill valve is stuck open replace fill valve
Sep 28, 2009 | Kenmore Elite 45986 Front Load Washer
Wash cycle and spin
you need to check a simple button called " no spin" may you will see it marked "aspiral shap" and has "x" over
good work !
Jul 05, 2009 | Zanussi ZWF1430W Front Load Washer
Timer dosent count down
HI, this is a simple fix here, you will need to replace the timer/control module. this will fix this issue. this specific device is ruined and, unable to initiate the wash cycle correctly due to circuit damage.
May 18, 2009 | Whirlpool Calypso GVM9959K Top Load Washer
1999 Neptune washer stopped in middle of cycle
sounds like the belt from the ele. motor to the wash drum broke. This can happen from over loading the washer or just wear and tear (lots of loads). Did you save the owners manual? It will give you a break down of the machine and contacts to get parts.
Apr 24, 2009 | Washing Machines
Noise when stopping after spin cycle or open lid (after moving)
check hub nut, it is likely loose, its under the agitator. top pops off agitator and bolt hold agitator down.
Jan 04, 2009 | Whirlpool Inglis IP4400 Washer
Washer fills with water and thats it
Possible a bad motor control board. Depending on the age of the washer, you may need to replace the motor control board and the motor as a kit. Also be sure to test that the motor control board is getting power, I've seen cases of the motor/ motor control failing and taking out the main control also. The tech sheet is in the console and should walk you through the steps.
Jul 18, 2008 | Maytag Neptune MAH5500B Front Load Washer
Calypso - water goes straight to drain hose-not drum
the hose may still be filled from last cycle. try to put machine in final spin mode where all water from previous wash will be spun out the drain hose. once a siphon is started it can only be stopped by introducing air into the drain hose.
Sep 16, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore Elite 45986 Front Load Washer Logo
61 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
