Question about Solis Palazzo Espresso Machine
.Flashing triangle light and coffee scoop and coffee buttons lit.
The dealing light is flashing and the coffee scoop and big coffee cup are lit. It won't respond to anything. Have tried unplugging.
3 Suggested Answers
  • 1089 Answers
SOURCE: the machine is still turning on however the light
HI I would suspect the thermostat on top of the boiler. it is 2 red wires with a little thermal couple on the end. Could be broken or bad. Goes to the board.
Posted on Oct 04, 2010
  • 1089 Answers
SOURCE: i am trying to descale my solis palazzo, I did as
Hi Descaling the Palazzo: The Palazzo is programmed to descale the boilers on its own, when set in the correct mode. You program the machine to descale it's self, do the following. With the machine turned on, push and hold the left 2 buttons (clean and pre-ground). This should light the top right red indicator light. Mix your descaling crystals in 32 to 48 oz in your water tank. Stir until they are completely dissolved in the water. Next, have a container that can handle about 2 quarts of water under the steam wand, or have the machine positioned next to a sink. Next open the steam knob on the right side of the machine. You should hear the pump turn on and pump about 2 to 3 oz's. of water through the wand into the container. The pump should turn off and there will be a wait of about 2 minutes. The pump should turn on again and more water will come out. It will do this until it has completely drained the water tank. Do not interrupt this cycle until the machine has stopped on its own. When it does stop, all lights on the bottom will flash. Rinse out the water tank and refill with fresh water. Place the water tank on the machine again, and then close, and then open the steam knob again and let the water just flow through the boilers until it is emptied by the machine. Don't turn off anything until the machine stops on its own. This will clear the descale light. Refill the water tank again with fresh water and push the water button on the right. It will light(very dim), then open the steam knob again/ The red light will go out and it will start to heat and your ready to go.
Posted on Jul 06, 2011
Red triangle will not stop flashing even after I descale
I have the Illy coffee maschine x7.1 and I'm trying to do the descaling (since the litle triangle sign is flashing), but power button doesn't start flashing after I push the coffee and steam button together (as indicated in the manual). Any suggestions what I should do, that the on/off button would start flashing?
Jan 25, 2014 | Illy Francis Francis X7.1 iperEspresso...
Gaggia unica red triangle flashing at same time as green cup
Hi there My experience tells me that when a red light flashes on a coffeemaker it is one of three things: It needs water to be able to make more coffee The "bowl" that the compressed coffee goes in ids full and needs emptying It needs cleaning I would start filling the waterholder, Then emptying the compressed coffee holder If neither works, then start the cleaning prosess Best of luck and enjoy your coffee Kolbrun
Sep 18, 2013 | Gaggia Brera Coffee Maker
Why are all lights flashing on my keurig kcup maker
lights are flashing because you need to decide how big of a 'cup' you want to brew. When you push one of the flshing brew buttons, the unit will brew and the lights will then stay on steady until you reopen and add a new K-cup.
Apr 15, 2013 | Keurig Platinum B70 Coffee Maker
Light never stops flashing in my 36 cup farberware urn...what could be the problem/
Light tells you the coffee is ready and will stay on un till you unplug it. Ron. PS don't mind the flashing, some do and some don't.
Sep 28, 2012 | Faberware 12-55 Cup Coffee Urn
My light won't go out and I descaled it then one light on the cups only lit up and it only gives a little water it's the kuerig i don't know the model
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Aug 08, 2011 | Keurig B60 Coffee Maker
How much coffee do I need tomake 20 cups of coffee
It takes 1 scoop of coffee for ever 2 cups of coffee, so 10 scoops of coffee is what you need. :)
Hope this helps!
Remember to Thumb me Up! :D
May 29, 2011 | Faberware 12-55 Cup Coffee Urn
Just purchased the Elite Keurig and followed the setup instructions. On step 8 it says to press the flashing blue light, both lights are lit up with a solid blue, neither are flashing. I went ahead and...
This should be a relatively simple solution. 1. Ensure that water is in the tank and filled to the top. 2. Raise the lid of the machine with the silver handle and insert a K Cup or just raise and close for hot water. 3. Blue light should now be flashing to indicate the machine is ready for use.
Apr 29, 2011 | Keurig Elite B40 Coffee Maker
How many scoops per cup?
Hi. normal is 2 scoops of coffee for 3 cups of coffee, then adjust from there for your taste. Good luck.
May 23, 2010 | Faberware FCP280 Coffee Maker
How do I make coffee in a Farberware 'superfast' percolator coffee pot, specifically, how do you know when it's done?
Hi 2 scoops of coffee to 3 cups. Then work it from there, to get it to your taste. It is done when it stops perking. When that happens the keepwarm element takes over until you unplug it. Good luck. Ron
Apr 11, 2010 | Faberware Coffee Makers & Espresso...
The on/off red light keeps flashing and won't work when pressed. I cannot get anything to happen. It won't turn off, won't make my coffee. It just keeps flashing
I have a Blender whose light flashes. Im not sure why? however, if you unplug for 10 mins starts up again. maybe you should try this
Feb 16, 2010 | Cuisinart Grind and Brew 10 Cup Coffee...
Solis Palazzo Espresso Machine Logo
Top Solis Coffee Makers & Espresso Machines Experts
graybeard32301
Colin Stickland
Colin Stickland
AZBen
AZBen
Are you a Solis Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
