Question about Exercise & Fitness
Nordictrack elliptical just clicks when turned on
Just put it together and turned it on and it just clicks inside where the balance wheel is. The display does not come on either. Any ideas?
  • 20 Answers
Hey Terry,
i think you have a busted bearing in the pedal crank... to be sure you can check the pedal for any play (shaking), then you would need to remove the casing and disassemble the pedals and check the bearings...
get it replaced and it should be good.
Hope this helped...
Enjoy
Posted on Apr 20, 2014
My cx1055 elliptical resistance is not working how it should. Once I get to resistance lever 4 or higher it starts out with the resistance but then it slips as you step into it. Any suggestions?
Nordic Track Nordictrack Cx1055 Elliptical Incline Motor For ...
www.fixya.com/search/p3944353-nordic...cx1055_elliptic/resistance
Nordic Track Nordictrack Cx1055 Elliptical Incline Motor For Model Number 285090, ...the bolts that secure the magnet4=if there are slips, the resistance will . ... my schwinn 460 elliptical resistance cannot be changed When I increase the ... Every time I increase the resistance it will go to that level of resistance but within a ...
Need someone to install a new resistance motor on a Nordic ...
www.shopyourway.com > Manage My Life > Questions
Aug 10, 2013 - I bought a CX 1055 Nordick Track elliptical at a garage sale. I noticed that the resistance doesn't really change between levels. ... 100 dollars, but how much would it cost to have someone come out and do the replacement for me? ... I wonder if maybe something shifted when I brought it to my apartment?Missing: slips
[PDF]View Manual in PDF Format - NordicTrack
https://service.nordictrack.com/.../pdfDownload.do?...2...
NordicTrack4. Place the elliptical exerciser on a level sur- face, with a mat beneath it to protect the... The CX 1055 elliptical exerciser is an ... 1055 elliptical exerciser features adjustableresistance ..... press the Odometer button again; the words "My.
Jan 05, 2016 | Exercise & Fitness
Nordictrack elliptical asr 700
Hi There,
There may be a problem with a power wire inside the machine.
Ring Icon Fitness to repair.
Aug 24, 2014 | Exercise & Fitness
NordicTrack ASR 630 Elliptical Console isn't working
1) replace new batteries with the same type, and o.k polarity.
2) clean the contacts batteries with c.cleaner and retight the spring with plier for a GOOD contact.
3) adjust the REED swtich, test it , clean it and tight the plugs
4) tight the ribbon cable inside for a good contacts keypads.
God bless you
Nov 27, 2012 | Nordic Track Nordictrack Asr 630...
My NordicTrack E5.7 Elliptical is making a grinding sound
Hi Liz,
The only way to assess is to take the covers off. There are a few reasons for this type of problem.
Nov 07, 2012 | Nordic Track NordicTrack E5.7 Elliptical
NordicTrack CX 1055 Elliptical ramp pedal wheels
Hi, You can find them easily on amazon, click here ant take a look: Amazon com Elliptical ramp pedal wheels. Wish you best of luck. Cheers
Jun 22, 2012 | Exercise & Fitness
NordicTrack SL710 pedals slip and make a clicking noise?
Kneelnext to the left side of the elliptical's base. Use the Phillips screwdriver totighten the two screws located in the center of the left pedal.2
Use theAllen wrench to remove the bolt securing the left pedal arm to the pedal legand body arm. Use the Phillips screwdriver to remove the screw securing therear end of the pedal leg to the crank arm.3
Pull theend of the pedal leg free of the crank arm. Wipe the crank arm clean, thenapply a fresh coating of machine grease or silicone lubricant. Replace the endof the pedal leg back onto the crank arm and use the previously removed screwto secure it back into place.4
Join thefront end of the left pedal arm to the ends of the pedal leg and body arm. Usethe previously removed bolt to connect the pieces together.5
Move to the right side of the elliptical and repeatthe above steps on the right pedal arm
Oct 31, 2011 | Nordic Track NordicTrack Treadmill, A2550
Reebok Spacesaver RL is VERY loud...
I had the same problem. Put vasoline on the wheel handle.
No more noise!
Jan 27, 2009 | Reebok RL1500 Elliptical
Exercise & Fitness Logo
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
