I have 4 YE DATA YD 645C-1545C drives, any replacement or repair likelihood?
The "in use" light do not come on, when we use the drive to boot our precious computer. Was to that the drives are bad. Replacement drives make more sense.
    Novelist:
  • 242 Answers
Sure.. buy another one.. it is just a flopppy drive. Check it on another computer though to be sure it is not a cable issue or power cable issue.. floppies are everywhere cheap.
Posted on May 29, 2014
2 Suggested Answers
  • 10406 Answers
SOURCE: YE DATA PN 134526-41 FLOPPY DRIVE
Go to any computer-store, with your current floppy-drive,
and ask them to sell you a compatible replacement.
Or, browse through "Thrift Stores" for a "pre-owned" one.
Posted on Aug 23, 2010
FDD Y-E Data YD-380B Repair RFQ
I have a YE Data YD-380B disk drive. I/O error is appeared when it try to read floppy. How can I solve this problem
thanks
mehrdad
Jun 12, 2013 | Ye Data - yd-380b - Yd-380b 1.2mb 5.25...
We have a IBM SCSI hard disk, Type: DGHS, P/N: 59H6761, 9.1GB. At boot time, we got error: SCSI ID %: Fail. after that, the system can not identify the SCSI hard disk. Anyone know to identify/fix that...
In all likelihood, your drive has reached the end of its lifespan. You may be fortunate enough to be able to read it just long enough to recover important data, but doing a full copy of the hard drive may be out of the question.
Data recovery, in general, is tricky and not something that can be done by just anyone. The simplest way I would suggest trying to cover some of this data is to take it to a computer repair shop and have them try to read it and let them know what the important data on it is. You could try to access it yourself by either connecting it to a friend's machine or, if you're a bit more savvy, to boot up using a Linux LiveCD and read the disk that way.
In any case, with most SCSI drives being over 10 years old in some instances, I would expect that your drive has just failed.
Apr 01, 2011 | IBM DGHS09Y (dghs-09y) 9.10 GB Hard Drive
S.m.a.r.t. says my hard drive is bad and needs repair
IF you can still boot, backup as much data as you can.
If you cant boot from it, you need to replace the hard drive, you can then either connect the damaged HD as a second drive and save your data, or fit it in an enclosure or docking station.
Once you have saved your data, you can reformat the drive, run scandisc to attempt a repair it, you may then be able to use it as a spare/second drive.
I have had a few drives fail as system/bootable drives, but have been perfectly ok to use as a second data disc
Sep 12, 2010 | ASUS Computers & Internet
After f2 boot no hard drive
You might get lucky if you detach and reattach the hard drive, but your odds of that working are about 1%. The 99% likelihood is that your hard drive is dead and needs replacement.
Oct 31, 2009 | Computers & Internet
IE DATA 702 fdd
Hello
I beleave it uses a HD/DD type of disk
Abbr.
Floppy Disk Type
Capacity
Info
SS/SD or 1S/1D
Single Sided, Single Density
100 K
First generation. Capacity varies
SS/DD or 1S/2D
5-1/4 inch Single Sided, Double Density
180 K
DD/DD or 2D/2D
5-1/4 inch Double Sided, Double Density
360 K
Most common type in the early 1980's
DD/HD or 2D/HD
5-1/4 inch Double Sided, High Density
1.2 Mb
DD
3.5 inch Micro Floppy, Double Density
720 K
Hard plastic case
HD
3.5 inch Micro Floppy, High Density
1.44 Mb or
2.88 Mb
Hard plastic case
May 05, 2008 | Ye Data YD-702D (850416000107) Internal...
ASUS A7N8X-X RESET SWITCH
Hi roatan. That helps. So as I mentioned in your other post. Hook up the Maxtor. Since it's a single drive in a newer case the hard drive should not have a jumper on it. Before the system asked for a boot disk. The reason you got that message is because either the boot.ini is corrupted or Windows XP start-up files are corrupted. (A virus/worm could also messed up things).
If you can not get your drive into another PC to back up your data to either a CD/DVD drive than you have no choice but to re-install windows.
Re-installing windows will over write the old windows & replace other folders. Some personal data will be erased. If this is what you want than continue! If you want to save all personal data than you will need to buy another drive. Install the new drive & setup windows complete. When your all done. connect the Maxtor drive. Check the white sticker in the Maxtor drive & change the jumper so the Maxtor is set to a slave drive.
Now you can copy all your personal data to your new drive.
Thats it. Continue to use the Maxtor drive a back up.
Once done copying your data to the new primary drive you can use windows to format the Maxtor & continue using it as a back-up drive.
Here is a very good drive for the money & it comes with a five year warranty.
http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=117009
Happy St. Patrick's Day!
Mar 17, 2008 | ASUS A7N8X-X Motherboard
Floppy drive problem
Here's a link to where on ebay you can find low priced 3.5 inch floppy drives.. http://search.ebay.co.uk/search/search.dll?from=R40&_trksid=m37&satitle=3.5+in+floppy+drive
Jay
Video Transfer Services - Beta and VHS to DVD
Dec 16, 2007 | Ye Data (YD8V07) Internal Floppy Drive
Nov 09, 2007 | Ye Data (YD8V07) Internal Floppy Drive
Computers & Internet Logo
122 people viewed this question
David Payne
David Payne
