Question about Farmall International Tractor 140 Radiator
140 international tractor when turn motor off the motor runs backwards
The problem is when you turn the motor off the motor runs backwards. will the timing cause the motor to run backwards when it is cut off
    Problem Solver:
  • 18 Answers
It is called dieseling. Could be carbon on the plugs or in the combustion chamber. Carbon gets hot enough to cause fuel to keep igniting after ignition is turned off.
Posted on Apr 18, 2014
Blades turning in wrong direction on 48"zero turn 18 hp husqvarna.Any solution
Yes take it to the dealer and have them check the pump since it uses hydraulic motors, it sounds very much like the pump is running backwards or is it possible the blades are on upside down
Oct 10, 2016 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Transmission
is the lever pulled out that allows you to push it when its not running?the one on the rear of the mower above the hitch point some you need to remove the trans to fill them
Sep 30, 2012 | Craftsman Garden
Hayward Super ll Pump - shaft spins opposite direction when it is running, what can cause this?
The only way a motor for these units can run backwards is if the internal lead connections of the winding are reversed. On some rare occasions I have seen a failed start cap cause a motor to start in reverse but turning it off and on would fix that. If your start cap checks out OK and the motor is truly running 'backwards' you will need to replace it.
If on the other hand the flow is not going the correct way look into the valves and filter(s) for issues.
John
Jan 22, 2011 | Hayward 1HP Super Pump II Inground Pool...
NEED TO KNOW HOW TO TIGHTING STEERING ON 140 tractor
if all tie rods are tight the steering box has a philips screw with a jam nut loose nut turn screw in until it stops, back out a little tighten jam nut. that takes slack out of worm gear. hope this helps
Aug 01, 2010 | Farmall International Tractor 140 Radiator
Wiring diagram for ignition switch farmall 140 tractor
FOUND YOU A WEB SITE FOR WIRING DIAGRAM
CARTER & GRUENEWALD CO. INC.
IF THAT DOSN'T WORK LOOK UNDER FARMALL 140 WIRING DIAGRAMS AND THE SITE WILL BE LISTED THIS SITE WON'T LET ME COPY AND PASTE TO YOU
Sep 16, 2009 | Computers & Internet
Farmall International Tractor 140 Radiator Logo
97 people viewed this question
Top Farmall Garden Experts
Dennis Key
Dennis Key
john h
Colin Stickland
Colin Stickland
Are you a Farmall Garden Expert? Answer questions, earn points and help others
