Question about Sewing Machines
Singer futura ce 150 bobbin won't spin to load thread
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 23 Answers
Do you have the handwheel pulled out and the spool moved to the right?
Posted on May 04, 2014
sweetpea53
SOURCE: while sewing on singer quantum
Mine did this and it seemed impossible to fix. My problem was a tiny bit of thread stuck in the bobbin cover (but it could be anywhere in the thread route). I ran dental floss through the path the thread follows and also in the bobbin cover and poof out came a small piece of thread that all my looking missed. Hope this helps.
Posted on Dec 28, 2008
  • 10 Answers
SOURCE: the bobbin thread shows
This may or may not help, but perhaps you should check that your bobbin is wound correctly, and that you have it inserted into the bobbin case properly. I find that these are usually the 2 main reasons why the bobbin thread show through.
It could be the design, does it do it on all designs?
Posted on Nov 05, 2009
mark24354
  • 776 Answers
SOURCE: Bobbin thread
Not completely sure on your model but you have to adjust (loosen) the tension on the top thread to match the tension on the bottom thread. Usually there is a wheel on the upper right of the machine. the tension adjust is the knob inside that wheel. Turn counter clockwise about 1/8 turn. Then try and repeat until it works. Check owners manual for top thread tension adjustment if needed.
Good luck.
Please rate me.
Posted on Nov 21, 2009
  • 64 Answers
SOURCE: I have a Singer Futura CE-150 and it keeps
Either upper thread is not passing through thread sensor area or sensor is broken.
Second possible reason is that if design is not optimized the sporadic speed change provides thread breakage error even if the thread is not broken physically. Make sure your software is updated to optimize it automatically (Futura main menu->Help->Live Update).
Posted on Dec 22, 2009
  • 49327 Answers
SOURCE: why bobbin thread showing top embroidery singer ce 150 futura
adjust the needle thread tension and adjust the bobbin thread tension. They have to be adjusted for different thread thicknesses.
Posted on May 26, 2013
I have a futura ce 150 and my bobbin thread won't catch
Are you able to bring the bobbin thread to the top of the needle plate, but it's skipping stitches, or you can't "catch" the bobbin thread to start sewing at all.
If you can't "catch" it at all, your machine's hook is no longer synchronizing, and you will need to have it retimed by a technician. The good news is, timing is not something that is unique per manufacturer, which means ANY sewing machine technician should be able to do it.
Sep 25, 2014 | Singer CE-100 Futura Computerized Sewing...
Why bobbin thread showing top embroidery singer ce 150 futura
May 26, 2013 | Sewing Machines
Bobbin won't wind on Singer futura CE-100
My singer hasn't wound bobbins for years and I don't care because I use a Side Winder bobbin winder. It's much easier than takining the thread off the machine anyway. Available from Hancock, Jo Ann or even Wal Mart for about $30.
Sep 09, 2012 | Singer CE-100 Futura Computerized Sewing...
I have a singer Futura CE-250. I am having problems with the tension I think. While embroidering the top thread is showing completely on the underside of the material. In other words the bobbin thread...
One of the things they don't really tell you about embroidering with the singer machines is that you really do need to use the same color in both the bobbin and the top. No matter how much you adjust the tension, you will still end up with some of the thread from both showing through on the other side, unlike with most other machines.
I found this out from a Singer technician about 3 years ago when I had the same problem with my CE 150 and was going nuts! He worked with both Singers, Vikings and Huskvarna's. and saved my sanity after demonstrating a lot of technical stuff that basically showed me why Singers did this.
Save your sanity-just bite the bullet and use the same thread in the bobbin as you do in the top.
May 27, 2011 | Singer CE-100 Futura Computerized Sewing...
I have a Singer Futura CE-150 and it keeps stopping due to "Thread break error" but the thread and bobbin seem okay what could it be?
Dec 20, 2009 | Singer CE-100 Futura Computerized Sewing...
Can't thread the bobbin on a singer futura CE 150
Be sure the bobbin thread is coming off from the left. There is a picture on my Futura bed that shows the correct way to insert the bobbin. If the thread is comming off from the right you will have the problem you described.
Good luck,
Beth
Jun 29, 2009 | Singer CE-100 Futura Computerized Sewing...
Bobbin/threading
Could be acouple of things. The tension on the thread or the bobbin. The needle not in all the way. Wrong type of needle for the thickness of the material. My problem was always trying to pull or push the fabric with the needle in the material - cause a bend, then the tip snags the side of the bobbin hole. Snap it's gone.
As your friend suggested, check the threading of the bobbin, the click she/he might be talking about it the first rotation of the bobbin, then being snagged by the needle thread. Good luck!
Jan 19, 2009 | Singer CE-100 Futura Computerized Sewing...
While sewing on singer quantum futura ce-200 sewing machine, thread bunchedup on underside of fabric and bobbin case flew out more than once.
Dec 27, 2008 | Singer CE-200 Quantum Futura Computerized...
I have a Futura CE 150 and it has been working great. I just started using it again, and now when I stitch it out on the edges it has the bobbin thread on it.. I threaded the bobbin right, and also the...
This has worked for me.
1. Make sure the tension dial is set at E.
2. Remove the bobbin case with thread in it.
3. Tape three quarters to the end of the thread.
4. Hold the bobbin case up. Given your problem, the quarters should be dropping to the ground.
5. Tighten the tension screw until the quarters are just a tiny bit away from dropping. You don't want it tighter than that because it will be too tight.
6. Put the bobbin in and test embroider.
This fix came from Jim at the Futura Yahoo group. It is a group well worth joining.
Aug 12, 2008 | Singer CE-100 Futura Computerized Sewing...
Singer futura CE-200 Can not wind the bobbin thread
In embroidery mode, you have to send a design to the machine before the bobbin winder will work.
Jan 30, 2008 | Singer CE-200 Quantum Futura Computerized...
Sewing Machines Logo
50 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
