Question about Maytag MES5870A Electric Kitchen Range
1/2 of burner works
Hi, we've got a MES5870AAB and the front burner has a switch that makes it small or large. Right now only the small portion is working. We can't make it a "big" burner. Any suggestions?
Thanks, Jerry
  • 473 Answers
Re: 1/2 of burner works
The burner is bad and needs replaced. Broken coil in the burner causes this. Check your owners manual because most come with a 5 year warranty on the burners.
Posted on Nov 03, 2007
0 characters
3 Points
Frigidaire stove front large/small burner combination. Large burner works but the small burner in the centre of the large burner does not come on at all with any heat. ??
This is a inner/outer burner type assembly? Sounds like a glass top.
Either way, your switch for that burner or the burner needs to be replaced.
If you are able and it is possible, inter change switches to see if it makes a difference. Interchange Large with large, small with small.
If yous switches are connected as one unit, you will not be able to do this. Sorry, I have not looked up your wiring diagram.
Oct 23, 2013 | Frigidaire Gallery GLEFM397DS Electric...
Right front burner only works on "small element". Large element will not come on. Do i need a new burner?
Hi Will Lawler - If the small element turns on but the large element does not, then more than likely, the range has a faulty burner or switch. If I was in your position, I would personally contact a professional for an accurate diagnosis and to assist with the repairs.
Mar 10, 2013 | Frigidaire Gallery GLEFM397DS Electric...
Why doesn't my double burner work?
i wouldnt be surprised if its not the resistance for the lower temperature ,now as to if its in the knob or a electronic controlled resistance i would have no idea ,its not the element i wouldnt have thought as it should have a resistance but yes its possible the element has two windings in it best thing to do is to ask in the spares shop as they will know straight away
Jan 19, 2012 | Kitchen Ranges
Burner on stovetop is out
good day,
hope this link below will solve your problem.
kitchen appliances
Sep 28, 2009 | GE Spectra JBP78 Electric Kitchen Range
Burner dosent get as hot as the others
If you saw a spark from the burner chances are that the burner has shorted out and is in need of replacement.
Apr 06, 2009 | GE Spectra JBP78 Electric Kitchen Range
Small burner of dual surface(right front) stopped working.
Does yours have the (small large burner switch)? If so, try switching it back and forth. It could be defective or your small burner element is bad.
Mar 11, 2009 | GE Spectra JBP78 Electric Kitchen Range
Kenmore glass top range left front large burner out
check the burner socket, it is likely that contact is being lost where the burner connects to the hardwired portion of the system (the socket). It is not unusual for the socket to "burn up" when there is a poor connection to the burner resulting in the burner being replaced and the new burner not working or working intermittently.
Please take the time to rate this solution
Jan 29, 2009 | Kenmore 95002 / 95004 Electric Kitchen...
Burner on range will not turn off
Look at the back of your range there should be schemetic for your power control board. look for defective burner wire going into relay. There should be 5 relays in rows. Realy is the problem. I had the same problem with my front left burner stuck on high.
After replacing everything works okay.
Apr 07, 2008 | LG LRE30755 Electric Kitchen Range
Maytag MES5870A Electric Kitchen Range Logo
109 people viewed this question
Top Maytag Kitchen Ranges Experts
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
