Question about Husqvarna Lth 130 Riding Mower Illustrated Parts List
LTH 130 shifts hard
It grinds gears and bogs when full throttle
  • Zachary Parsons
    Zachary Parsons Apr 18, 2014
    A spring is also detached and is loosely on the shift rod, shifter also seems loose.. It also seems to have a pulsating bog like it also does when it is full throttle.
    Problem Solver:
  • 11 Answers
If it doesn't go, than it doesn't need brakes or a shifter. First concentrate on the running and/or power of the machine. Pulsating or bog sounds like it falters under load. And that sounds like lack of fuel. Or an air leak. Unmetered air entering the system that makes it too lean of mixture. Physical inspection to make sure all is where it's supposed to be and in good shape. Then take float bowl off and inspect for foreign matter. Water, rust old varnished fuel, etc. ... More probable is a passage is plugged/clogged. Typical carb replacement can run $100.00 and more just for the carb plus labor. Since it doesn't work correctly now, you can't hardly make it worse. Patience and watch closely how it comes apart. CLEAN CLEAN CLEAN Spray carb cleaner thru every presumed orifice till flow is achieved. This may take more than one attempt. Air compressor and blow gun is all but a must. P.S. Be very careful of your eyes. Carb cleaner in the eye is more painful than you'ld think.
Posted on Apr 24, 2014
How do I fix the steering on My Husquvarna Model LTH 130 riding lawn mower?
Go to bing.com search husqvarna Lth 130 and you should come up with a 50 page manual on the mower that might help with problem.
Oct 28, 2017 | Garden
1998 Kawasaki VN 1500 Vulcan Classic transmission shifts hard in first gear
Hi, Catalin and the usual suspects are:
1. Clutch not adjusted properly.
2. Primary chaincase overfilled with lubricant.
3. Corners wore off shifter clutch dogs.
4. Shifter return spring bent or broken.
5. Bent shifter rod.
6. A loose shift lever on shifter shaft.
7. Shifter forks sprung.
8. Shifter pawl needs adjusting.
9. Heel/toe shifter coming in contact with the floorboard.
10. Transmission oil too heavy.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
http://www.kawasakimotorcycle.org/forum/mechanics-corner/4833-1997-vulcan-classic-1500-shifting-problem.html
hard shift first to second Kawasaki Vulcan Forum Vulcan Forums http://www.vulcansabs.com/wp-content/uploads/2016/04/Kawasaki-Vulcan-VN1500-Nomad-Classic-Tourer-1998-1999-Service-Manual.pdf
OEM Parts for Kawasaki
1998 Kawasaki Vulcan 1500 Classic Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Dec 25, 2013 | 1998 kawasaki VN 1500 Vulcan Classic
Need a belt diagram for my 2000 LTH 130 Lawn tractor
Look in your manual. If need one, go Goggle husqvarna lth 130 manual.
Sep 08, 2012 | Husqvarna Garden
94 Accord Ex 2.2l Vtec will not engage passing gear
Sounds like it could be a problem something to do with the clutch perhaps? If the clutch or other components of the tranny are malfunctioning then it could very well be the source of quite a few elusive problems, and unfortunately the transmission on Honda's are known for hard-shifting, so i would have the transmission diagnosed just to see if everything checks out A-OK. Let me know how it goes!
Jan 06, 2010 | 1994 Honda Accord
94 Accord Ex 2.2l Vtec AT Will not engage passing gear.
check coolant level, sounds like it's low,...
Grinding when in reverse and tries bogging down at lights
stop shifting so hard. your reverse gear is the same exact gear as your first, so if you shift hard and grind that gear a little then reverse will be harder to get into. you probably need your transmission rebuilt the harder your engine has to work the more its going to bogg down
May 14, 2009 | 1987 Ford Ranger
Honda V1100 Jumps out of gear on full throttle acceleration
More likely it is a slightly bent shift fork not fully engaging into second. The clutch and bearings are not suspect. Remove your foot from the shift lever then go full throttle in 2nd. Those new riding boots may be doing the magic unconsciously. Adjust the shift lever height if that is the problem.
Apr 30, 2009 | 1994 Honda VT 1100 C Shadow
1996 honda ciciv automatic transmission
that could be a result of your clutch being worn.....or worn gears. have it checked by a professional
Jul 28, 2008 | 1996 Honda Civic
Husqvarna Lth 130 Riding Mower Illustrated Parts List Logo
48 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
