Question about Homelite Consumer Products Tiller Attachment
Hi there, I have a polaris sportmans 500 h.o for which i had to replace the pullrope, i disassembled the spring and put it back in, then the new rope and rope wheel, and put the cap back on top of the rope wheel with a screw. The problem is that my pullrop works fine, comes out and goes back in, but there seems to be no connection with the flywheel, it just spins out and back in, i don't get it... i did notice that on the rope wheel there is a little plastic pin that sticks out and on the flywheel there are a few little holes about the same size, are these meant to connect or
    Sergeant:
  • 337 Answers
Nick the pins are supposed to line up also the little lugs inside the pully. When the rope is pulled fast the lugs come out and catch the fly wheel. Make sure all the springs are correct.
Posted on Apr 19, 2014
How to replace starter rope on 1993 polaris indy 500
Good luck! This model usually requires the muffler being removed,the right side of the engine disassembled.... A hint! do not remove the recoil spring unless it is broke. Turn the rope pulley clockwise about 6 times alaign the rope hole in the pulley and the starter housing , push the rope through, it helps to melt the rope ends.after the new knot is tied and pulled tight,gently release the pulley.
May 13, 2014 | Winter Sports
Need to obtain a new belt and pull rope for my Tiller
you can get a pull rope at wal-mart.measure the belt and any parts store or place that sells lawnmower belts should have one.if the rope broke close to the end knot just pull the end knot with some needle nose pliers.once you have all the old rope out lay the old rope pieces on the ground and cut the new rope to match it as far as length.turn the pulley that the pull rope goes in six turns counerclockwise.then turn the slot the knot was in to the hole the pullrope goes thru and fish it thru then pull it up and out with apaiar of needlnose have someone hold the pulley until you tie a small knot in the end of the pullrope the hold the pullrope and let it pull it in.you might have to cut some off at the handle if its still too long.to do this pull some rope out and tie a quick knot so the rope can't slip back if you let it go.
May 27, 2010 | Mtd Products Yard Machines 158CC Tiller
My 2007 polaris sportman x2 500 fan is not coming on and it says HOT check engine
I have the same problem on a 2006 X2. When the HOT check engine display is on the engine is not hot, when the fan does come on the HOT display clears, but soon returns.
Apr 21, 2010 | Polaris ATV
Fixing a Polaris Indy 400 snowmobile pull cord - I took it apart and cant get it back together
hello usually on any pull start, you have to wind the spring inside,the cover, on my atv i put the rope on the pulley burn the end of the rope and make a point on the end of the rope. put the pulley back in the case, turn the pulley backwards untill you get a lot of tension on pulley and turn the case up wright where you can see hole where rope comes out, turn pulley untill you see end of rope through hole. fish rope out with a pair of tweezers or a pair of themostats
Feb 06, 2010 | Polaris New Genuine Polaris Snowmobile...
Polaris 500 sportmans and the 4x4 does not work in reverse
On mine the override button has to be pushed
Jan 03, 2010 | Polaris ATV
2006 polaris sportman 500 HO overheating problem HELP!!!!!!
Check that the electric fan motor comes on ,and check the radiator for mud and debris u may also need new oil and filter change,All of these things could make it run hot 1 more thing roll it in neutral 2 make sure breaks arent hanging up.
Dec 18, 2009 | Polaris ATV
2005 Sportman 500. Cannot start. No electrical
Check the ignition switch and the 20 amp inline circuit breaker.
Oct 27, 2009 | Polaris ATV
Pullrope broke on weedeater 550 how do i get it apart to fix it
ther eshoul dbe some bolt holding the pullcord/recoil assenbly to the flywheel/motor. you need to locate and find these bolts first. let me know when you have this apart. you have to unwind the rope and pull it completley out, then buy a new pullcord rope(other rope will just fray and break agai) slip it thru the holes tie a knot wind up the spring and carefu;lly place it back on were it came. let me know if you run into any trouble.
Apr 23, 2009 | Poulan Pe550 Gas Edger
Homelite Consumer Products Tiller Attachment Logo
23 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
