Question about Microsoft Computers & Internet
Network cable not properly plugged in or may be broken
Wireless keeps not connecting and I get the above message or wireless network connector disabled
    Novelist:
  • 187 Answers
Which OS do you have? XP, Vista, 7, etc. you must have a wireless adapter in your PC to use wireless and it must be enabled.
if not wireless, then you must have an ethernet slot with cable(CAT5) inserted from internet modem/router. if you have a laptop then you have wireless available. there is a key on keyboard to turn wireless on. you have to have your Network assigned to the wireless internet provider too. if you have cable(cat5) connected to a modem or router/modem connection, and you see an ethernet icon in your lower right corner window(looks like a little computer display), then you have an ethernet connection. if not then either the cable is bad or the modem/router is not producing a connection to pc. thats alot i know but i have little knowledge about your internet connection on your pc. you have not given that to me to use
Posted on Dec 27, 2015
jmassengill
  • 345 Answers
SOURCE: Wireless Connection Good but PC Often Can't Access Internet Sites
I would scan the computer for viruses.
Posted on Nov 09, 2008
abhvp
  • 148 Answers
SOURCE: 0 configuration (wireless) no internet connection
Reconfigure your wireless configuration in this laptop and then try connecting it.
Posted on May 07, 2009
  • 59 Answers
SOURCE: wireless internet is not connecting
dear,
Pl check with your modem wirless port is active or not samething in to your laptop and desktop.
after connection pl give your modem ip range and search for wirless device.
Regards,
Ravindra Shah
Posted on May 22, 2009
jennifer720
  • 830 Answers
SOURCE: I installed Windows 7 Home Premium 32 bit on my
You need to setup your new homegroup settings on your Windows 7 PC. Once you set this up you can copy to all your windows XP computers. This will put all the computers in sync. You can find the homegroup by going to the start menu and searching for homegroup. Please let me know if you have questions.
Posted on Oct 23, 2009
  • 707 Answers
SOURCE: I installed WinXP on an
http://partner.atheros.com/Drivers.aspx
IF IT HELPS PLEASE GIVE GOOD RATING...THANKS AND GOOD LUCK
Posted on Oct 15, 2010
I keep getting an error message indicating that my wireless device is disabled. It's a HP mini. for work serial CNF0260923. HP MIni 210 - 1076NR
If you get that message, believe it.
You will have to enable it either through the software switch or a little switch that some computer manufacturers place on the computer case.
The first thing you can do is open your network connections and see if you can see the wireless connections. If it says disabled, you might be able to right-click on it and enable it.
You can also look in the control panel to see if the HP wireless assistant can be accessed through there (or possibly through the programs list).
Mar 24, 2011 | HP Mini 1000 Netbook
Trying to get wireless
there are some options that might help u: 1. check to see whether wireless adapter is on; 2. if wireless adapter is on, check on drivers whether wireless driver is installed (check in device manager in control panel); 3. check your network connection, check the connection is "disabled". If yes, right-click to enable it. 4. if the above is not your issues, then try this: right-click the wireless network connection to check the available wireless networks, select one of the network, type WEP key and connect it straight away.
Nov 20, 2010 | Computers & Internet
When I try to run the Dell Wireless Configuration Utility from the control panel I get the following error message:"The wireless network adapter could not be accessed. This application may have diminished...
Well Sir in this case i will advice you to disable the Dell Wireless Configuration Utility and instead use windows utility for a successful connection.
For disabling dell configuration utility follow these steps:-
1)Open dell Wlan utility , it will have five tabs at the top labeled wireless networks , link status , site monitor , diagnostics and information.
2)Click on wireless networks tab and uncheck the first option which says , "Let this tool manage your wireless network" then click ok or apply at the bottom right-hand side corner of the screen.
To Enable Windows Utility for Windows XP follow these steps:-
1)Open the Control Panel from the Start Menu.
2)From Control Panel click on network and internet connections and then open network connections from there.
3)Right-click Wireless Network Connection and choose Properties.
4)
Click on the Wireless Networks tab and if unchecked , then check the box for Use Windows to configure my wireless network settings. Then click OK.
5)Right-click on Wireless Network Connection, Select View Available Wireless Networks.
6)
This will lists all the available wireless networks in range. Select your network from the list and click Connect.
7)If you are connecting to a secured wireless network, you will be prompted for a Network key. Type the Network key(which is the password for the wireless network) and then click connect.
8)Your network list should now display your connection status. If you are connected and your router is setup for internet access, you are ready to connect to the Internet wireless.
This Link will guide you through the steps:-
http://kb.netgear.com/app/answers/detail/a_id/111/kw/wireless%20zero%20configuration/r_id/100109
Nov 24, 2009 | Computers & Internet
I was online when I ''lost'' my internet connection. When I run the cursor over the broadcom symbol, the message says''network 2 radio disabled''
I think you have a wireless enable/disable switch, the rightmost in the row above your keyboard, you must have accidentally pressed it. Press it again to turn the wireless network card on, it should come up and connect in a couple of moments.
Oct 30, 2009 | HP Pavilion ze2000 Notebook
Cannot connect MacBook to DIR-615 router
Is your wireless network secured ?
If you are trying to connect to the secured wireless network, make sure that the network that you are typing is correct.
If you are not sure about the network key
then check the network key on the router.
You said that MAC is able to connect to the neighbor's wireless network.
Make sure that the Wireless MAC filter on your router is disabled.
Click here to know more about network key
Oct 06, 2009 | D-Link DIR-615 Wireless Router
My computer when connected to wireless network keeps showing the message "Windows cannot confugure wireless network." It becomes difficult to get it to work.
You may want to disable the built-in utility of the network adapter and let the wireless zero configuration of Windows take up the task of managing the wireless network.
Jun 08, 2009 | IBM ThinkPad T40 2373 Notebook
Unable to activate wireless lan
TRY GOING TO START, START SEARCH TYPE WIRELSS DEVICE
LOOKE IN DEVICE MANAGE FOR WIRELESS FOLDER
INPUT DEVICES
AS SO CHECK THE FOLLOWING FOLDERS ALLOWING COMMUNICATION BETWEEN THE LABTOP AND THE WIRELESS DEVICE AND THE COMPUTER.
NETWORKING AND SHARING FOLDER
PROBLEMS AND REPORTING
SECURITY FOLDER
SYNC CENTER IF YOU HAVE ONE
WINDOWS DEFENDER
WINDOWS FIREWALL
THE LAST 2 PROGRAMS IN THE LIST ABOVE CAN STOP THE DEVICE FROM WORKING.
YOU WANT MORE HELP I WILL HELP YOU IF YOU HAVE THE SITE CONTACT RODGANDYSR@GMAIL
ROD
May 12, 2009 | IBM TP R51 - P M715 1.5GHZ 256MB 40GB...
My HP mini laptop will not connect to my wireless network.
check you wireless router settings if the wireless is enable on the router then , if this is done disable the firewall on your wireless laptop and if you cannot still connect to the wireless uninstalled and reinstalled your wireless driver software.
Adeyiga Shitu
Apr 17, 2009 | HP MINI 2133 NOTEBOOK PC - 1.6GHZ PC...
How to fix intermittent wireless signal with Dell Inspiron 1501
It's the Wireless Zero Configuration service that's doing it. Every 10 minutes or so, the WZC service goes out and tries to look for wireless networks. During this time, it can sometimes disconnect from your wireless network. Usually its brief, merely a few seconds, but long enough to kick you out of games, messaging clients, etc.
There is no easy way to resolve this other than stopping the WZC service after startup and successful connection to your wireless. Unfortunately, if you disable this service altogether, your computer will never connect to any wireless and when looking at the Wireless networks list, it'll mention the WZC service is disabled.
You will also need to re-enable this service everytime you take your PC to places where you'll be connecting to other wireless networks. To stop this service, follow these steps:
  1. Go to Start -> Run -> and type "services.msc" (without quotes)
  2. Scroll to the very bottom of the list
  3. Right click on the Wireless Zero Configuration and choose stop
Once it stops, continue working with your wireless network. If you no longer have disconnection problems every 10 minutes roughly, you've solved your problem. Repeat the above steps after every reboot as the service will be re-enabled after the computer restarts.
Mar 05, 2009 | Belkin Wireless Pre-N (F5D8230-4) Router...
Computers & Internet Logo
55 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
