Question about Toshiba TDP-T45U DLP Projector
Broken color wheel
Were can i get a new one?
  • 555 Answers
Hello my friend, Try to find a store that specialize  LCD projector and accessories. Also you can browse to the internet to find new one in your LCD projector. you can log or visit www.google.com and you can search their.
Posted on Jun 19, 2009
Makes noise around light and will not come on.
yes a broken color wheel can prevent a set from powering up but a broken lamp could also shatter and have pieces near the color wheel.
Aug 07, 2012 | Zenith Z52SZ80 TV
Replaced the balast, tv not longer turns on and off but now it has a kind of pulsing picture. Am I looking at a new bulb? a new color wheel ? or some other surprise that I haven't heard about?
Lamp is possible especially if the ballast was bad--it powers the lamp.
Color wheel will usually display some issues--high pitched whine or fan like noise---with the lamp removed look where it faces--color wheel is there--any broken or missing pieces and it is the problem---
The wheel is directly connected to the set---set will detect if wheel not moving or moving too slow etc and almost instantly turn the lamp OFF.
Apr 30, 2012 | Samsung HL-67A510 67" DLP HDTV
It not bringing out color.it showing black and white
HI,
I will need some clarification as to the model number of your projector to best help you but in general if you have a DLP type projector & suddenly lose all color to your image then the color wheel has failed by burning out or breaking. The color wheel sits directly in front of the projection lamp & if you take your lamp out you can use a flashlight & point it in towards the spot where the light comes out of the lamp & look at the color wheel. The color wheel has 4 to 6 different color pieces called segments like yellow, red, blue & a clear segment. You will be able to see if the color wheel is broken.
If it is you need to have the unit serviced. If you're handy you may be able to order a new color wheel. They are usually around $100. There can be other causes as well but the wheel is the first place to investigate. Please let me know if this was helpful.
Thanks & good luck,
Jim
Apr 14, 2011 | Acer Office Equipment & Supplies
OK, following your advice of March 9th I got a new lamp from Mitsubishi and replaced it tonigh in my Mitsubishi rear projection model WD-62725 TV. The old lamp was clearly broken. However I have...
hi,
That sound may from the color wheel. Open the angine, open block front of lamp.
open cover of color wheel and grap it.
mas_baz_23.jpg Rotate color wheel manualy , listen it. If hear fristing sound, means color wheel is bad. Replace it too.
mas_baz_24.jpg Good luck.
Mar 24, 2011 | Televison & Video
Broken color wheel
Something between 150-200$. In my opinion it won't worth it. Go and get yourself a brand new one...
Mar 01, 2010 | InFocus ScreenPlay 4805 Multimedia...
Color wheel failed. Can I fix it myself??
If you contact Optoma and they have the part available then, yes you can fix it yourself. You have to be good at taking things apart and remembering how they go back together. Changing the color wheel assembly is not that hard.
Oct 27, 2009 | Optoma EP739 Multimedia Projector
Black and white picture only
The color wheel is not the problem. If the spinning color wheel is impaired in its RPMs it will cause picture distortion, not black and white picture. If the color wheel looses any of its color fins, like if it is broken, there will be a loud vibrating noise inside the tv which you did not mention. Also if the color wheel is broken and doesn't spin, the tv will not start up.
The likely problem is on the digital control board or the power supply and should be referred to a local repair shop for repair.
There is an outside chance that you will receive color if you experiment with using all of the different input ports to see if you can find one that will bring back color.
Apr 29, 2009 | Samsung HLN617W 61" Rear Projection HDTV
I heard a pop and now the projector only shows black and white.
The color wheel has failed in youtr projector. There are 4 pieces of glass in the color wheel which fit togeter in a "pie" formation and they are red, blue, yellow & clear. This wheel is spun by a motor. The glass is glued to the motor's hub, and, when it fails the glass segments are thown off the hub. This gives you a B&W picture because all of the light is allowed to shine through the optics all of the time. Replace the color wheel with Toshiba part no: 23125963. It will be about $65. No soldering is involved, just use care with the ribbon cable to the motor. You will need a no. 2 phillips screwdriver and a set of jeweles screwdrivers to do this.
Nov 25, 2008 | Toshiba TDP-T45U DLP Projector
Color wheel 267888
no the color wheels usually have a segment break off. they are very fragile. try and look on the TRITRONICS website
Feb 19, 2008 | RCA HD50LPW164 50" Rear Projection HDTV
3 blinking lights no visual...just bought new color wheel
recheck those plugs from color wheel to dmd bd, when was the last time you replaced the lamp?
Oct 18, 2007 | Samsung HLN617W 61" Rear Projection HDTV
Toshiba TDP-T45U DLP Projector Logo
160 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
