Question about Linksys Wireless-G Broadband Router
I think there may be a problem with my router. I connect the internet cord directly to my computer and i am able to access my comcast broadband connection. however once I plug the cord back into the router i cannot access the internet
  • 3,267 Answers
Check the ADSL led is constant or not? Reset the modem and check your DNS settings, also check if you can enter the router by typing:192.168.1.1: and see the settings of your router...................sodeep
Posted on Jun 19, 2009
I Need Installer For My D-Link DIR-600 Wireless Router
There are ways to configure router:
1. Is by using Installer using a CD came with it or
2. Access routers Graphical User Interface (GUI) through Internet browser. Just type in on the address bar the IP address of your router. For dlink it has a default IP of 192.168.1.0.
Note:
Before accessing router configuration make sure that the yellow cord (ethernet cable) is connected directly from the router to your computer.
Sep 14, 2013 | D-Link Dlink Dir-600 Wireless Router...
Can't access internet, says I am connected but then says no internet connection
I think you should try to reset and reconfigure the Linksys router and see if that works.
If your Linksys router is old then you can also upgrade firmware on the router.
Connect your computer directly to the modem and make sure that you can access Internet directly through the modem.
Connect the modem and computer to the router. Open the setup page of the router and change the settings manually.
Try this website to setup your Linksys router manually.
I can also suggest you a Fiverr Gig where you can pay only $5 and get support for your Linksys router.
Jun 11, 2012 | Linksys Wireless-G Broadband Router
I need a simple set-up manual for model # WRT54GS router
Your Internet service provider is comcast cable company.
You need to open the setup page of the router and change the Internet connection settings manually.
Connect the computer to the router and modem to the router.
Open the setup page of the router using 192.168.1.1
Click on MAC address clone. Enable it and click save settings.
Power cycle the router and your main computer will be online.
Then you can change the wireless settings manually.
Click Linksys router setup steps
Jan 04, 2012 | Linksys Wireless-G Broadband Router
I can't connect to the internet
First make sure that you have the router connected properly, meaning you have the ethernet cord from the modem or directly from the wall going into the router portion that says "internet". Try to do a direct connection from your computer to the router to test connectivity. If no conectivity, check the lights to ensure that there is not any traffic broadcasting. If the lights are steady or are off, then there is no connectiviy. Make sure that you are able to access the router interface by connecting directly from the computer to the router. If you are unaware how to do so, click this link and it will give you step by step instructions:
http://support.microsoft.com/kb/331950
Nov 30, 2009 | Microsoft Broadband Networking MN-500...
Moved router to connect directly to the Comcast modem that also provides VOIP. Comcast activated modem and internet works when computer is connected directly to Comcast modem. Router does not connect to...
Your ISP should have given you the following information...
Static IP, Internet IP Address, Subnet Mask, Gateway, Static DNS 1-3.
With that information at hand, follow tis link to the router user manual and go to Page 11 of the manual to go through the step by step process of setting the router up for an internet connection.
http://downloads.linksysbycisco.com/downloads/WRT54GX2v2_ug,1.pdf
Nov 26, 2009 | Linksys WRT54GX2 Wireless-G Broadband...
Setting Up a Wireless Network
You can still use your existing Linksys router with your cable modem. In fact the router your have is designed to work with DSL/Cable Broadband connections.
1. Make sure to properly connec the devices in your network. Modem will be connected to the Internet port of the router. Then, laptop will be connected to one of the 4 Ethernet ports of the router. For initial setup of your router with modem, you need to hardwire laptop to the router.
2. Press and hold reset at the back of the router for about 15 seconds.
3. After 15 seconds turn off the router and then turn off the modem. Wait for a minute.
4. Power on modem and wait for the lights to be ready.
5. When modem lights are on, turn on router.
6. There should be 4 lights on. Power should be steady green. Internet, WLAN and Ethernet port.
7. Checked if you have Internet connectivity on your laptop while it is wired to the router.
8. If Internet is working, disconnect laptop from wired connection to the router and check available wireless network that laptop can detect.
9. The default wireless network name that the Linksys router broadcasts is "linksys". Connect to it which is an unsecured wireless network.
10. Once you are successfully connected, check Internet.
Hope this helps!
Nov 16, 2008 | Linksys Wireless-G Broadband Router
Wireless G and Comcast cable internet
Im not sure about the monopoly thing?
But it must the settings that is causing a problem.
If I understand you concern correctly your computer is connecting to the router wirelessly, is that right?
and can you get online if the computer is wired directly to the router?
Jul 21, 2008 | Linksys Wireless-G Broadband Router
Linksys router not performing
has it worked before? if yes, try to power cycle everything. turn off everyhting then turn on the modem first, then the router, then the computer/s.
if you have power cycled everything already and you still can't access the internet using the router,
- access the router's setup page by logging to http://192.168.1.1 (leave the username blank and the default password is "admin")
- if you're using a cable connection, set the connection type to "automatic configuration - dhcp" and enable the mac address clone
- if you're using a dsl connection and you have a username and password from your isp, set the connection type to "pppoe" then enter the complete username (ex. username@comcast.net) and password given by your isp.
- check the "status" tab of the router and see if there's an internet ip and dns, if so, you should be able to connect to the internet
hope this'll help you.
ciao!
Jun 20, 2008 | Linksys Wireless-G Broadband Router
Became new customer to comcast-got the bundle package, internet,phone,cable. Voice overlay modem to accomodate internet and phone lines. Did not use their wireless router-using exsiting router D-Link model...
Hi jad123,
I am sorry to learn about the problems you are experiencing with your service.
I will be happy to reach out to my contacts to assist you in resolving this issue. Please feel free to contact me so that I can get more information from you.
Thanks in advance!
Mark C.
Comcast Executive Offices
We_Can_Help@cable.comcast.com
Apr 10, 2008 | Computers & Internet
Linksys Wireless-G Broadband Router Logo
95 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
