Question about Kent Moore J-41676 Front Output Shaft Brg Inst Adapter
Output shaft gasket for front differential is leaking badly on 1995 jeep Cherokee
What is the part number for this
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,455 Answers
You can also find whatever you need, for your Jeep, by searching the online catalog at rockauto.com
Just select your make, year and model. A dropdown list will show detailed parts from every major system on your vehicle. The transmission output shaft gasket seals are listed there.
Posted on Apr 18, 2014
    Sergeant:
  • 322 Answers
The napa part number for the pinion seal for the front differential is 15788
Was told drive shaft was worn out needs rebuilt or new any 1 here of this
Rebuilding them consists of new U joints and maybe balanced. If it was so loose the the u joints wallowed out the keepers, Then yes, they would also need replaced. Cut off and welded on. That isn't a common problem, but I have had to replace a few. Not just on jeeps.
Feb 05, 2016 | 1999 Jeep Grand Cherokee
How do i fix a front differential leak on a 2009 jeep grand cherokee srt8
Sounds like the seal around the drive shaft yolk or the differential cover plate seal is bad depends on the leak you have...try somestop leak from auto parts store...7.99-10.00
Jan 03, 2015 | Vehicle Parts & Accessories
Output shaft bearing
Leaking by axles or input shaft (driveshaft),if it is the pinion change the seal, make a dot mark with a punch on the nut and the pinion before removing the yoke to tight it at the same place, unless you do that you will burn the bearing it hapen to me one time
Apr 18, 2014 | 1995 Jeep Grand Cherokee
95 Jeep Grand Cherokee front end feels like it's fighting either side either way I turn cv shafts are <10k on them...it feels like the front spider gear is stuck
Not familiar with the ZJ, but does it have a locking differential? Do they use limited slip additive in ZJ diff? If so, then its probably due for a fluid change and new additive.
Nov 05, 2013 | 1995 Jeep Grand Cherokee
Jeep cherokee rear differential
First replace the seal and case cover gasket, then top up diff oil, test to see if noisy is eliminated , because since the oil is leaking it might be running dry.
Sep 15, 2013 | Cars & Trucks
Differential gasket
Rear cover gasket is easy. Unbolt, drain, clean and replace gasket; fill with proper gear oil. Pinion seal on the front of the differential, different matter. If its the pinion seal leaking, take it to a shop with experienced techs.
Aug 11, 2012 | 1995 Jeep Grand Cherokee
Just wondering is the drive shaft is located in or around the differential- my jeep was smoking with a foul odor coming from underneath the vehicle and I was told by 2 mechanics that I need to replace the...
I own an 02' Jeep Liberty. It is either the differential, or the drive shaft.
Is it the front or rear driveshaft? Does the Jeep drive? If the driveshaft
was bad, it wouldn't move, so I'm assuming he's screwing you,since driveshafts don't smoke.LOL. If your front or rearend lube has come all
out or very low, you could get smoking from the diffs,especially if the fluid hit's your exhaust. look under the jeep, to see if any fluid is leaking
from the front or rear driveshafts?good luck.
Mar 29, 2010 | 1996 Jeep Grand Cherokee
Kent Moore J-41676 Front Output Shaft Brg Inst Adapter Logo
77 people viewed this question
Top Kent Moore Science & Laboratory Experts
ray gallant
Andrew Taylor
Andrew Taylor
S J Parkin
S J Parkin
Are you a Kent Moore Science and Laboratory Expert? Answer questions, earn points and help others
