Question about HP LaserJet 2840 All-In-One Printer
Thanks Nalin. I did just that to in my System Preferences. to no avail. The issue came out of nowhere which is why i would not think it 'a bad version of an updated driver is causing the problem'. Any other suggestions welcome. Thanks
    Guru:
  • 224 Answers
Ok go to add remove programs in control panel and then reomve only the printer drivers.
you will find one hp entry that says leaserjet 2400 or something like that remove this and then insert the printer installation cd exit out of the autorun screen.
click on start and click on my computer.
right click on your cd/dvd drive and select open then
go into a folder called "util"
then go into a folder called "ccc"
there would be a file called l1 uninstallation.
double click that.
what it does is it will remove your printer drivers that have any faults and then once you restart your computer then re insert the installation cd once again and run the autorun part of the cd and click on the option that says add a device and now check im sure this will resolve your issue.
now if you dont wanna do this try this click on start and open control panel
go into the printers and faxes folder
click on add a printer
Click on next
select local printer attached to this computer.
uncheck the box that woul say "automatically detect my plug and play printer"
click on next and in the drop down list select your usb or your wireless port.
click on next
under manufacturer select hp
under printers select deskjet 990c
click on next
enter a printer name and click on next click on next again click on next
the click on ok and click on finish now print from this printer icon that is just installed and you should not face anymore issues
Posted on Jun 19, 2009
I was driveing down road car died out of nowhere and will not start have spark at plugs. think it is a fuel issue
Do you hear the fuel pump when you turn the key? Might be a bad pump. You can try banging on the fuel tank with a rubber mallet as this will often get the pump going, but if that works, you will want to replace the fuel pump ASAP.
Mar 11, 2014 | 1988 Chrysler New Yorker
Just replaced cylinder heads thinking that was the issue and still not turning over. battery brand new. new oil, new fluids, over half a tank of gas. car in perfect condition and this happened out of...
you need 3 element to internal combustion , air , fuel ,fire,. then is there any fire, any engine code, MAF defect, ignition module or coils, bad fuel , fuel pressure because there is no prime from fuel pump relay, and so on
Aug 12, 2013 | 1998 Oldsmobile Cutlass
Advent modena m202 can#t find webcam & wifi on & in my laptop think it may have been uninstalled how can l re-install them been trying everything but to no avail thanks
restart HOLD the keys CTRL or FN + f11 or f12 depend of your mark, model. and go to restore factory default
God bless you
Jul 23, 2013 | Computers & Internet
My fifth avenue runs real good then just stalls
If you still have the lean burn ignition system, it has probably gone bad. Chrysler dealers used to sell a kit that included a new distributor and module to fix this problem and get rid of the lean burn system. They are probably still available online or ebay.
Mar 31, 2010 | 1985 Chrysler Fifth Avenue
The connection works but the unit is nowhere to be found
Belkin may have a firmware upgrade available that may help.
Do you have UPNP installed (windows xp/vista) in the network components and this is usually required to see any UPNP devices on your network.
can you access the device from its default IP ?
In your browser, type “192.168.2.1” then press "Enter"
Aug 07, 2009 | Belkin (F5D7230-4) Router (587009)
Forect Star Passion HD v1.5 (formerly 1.4)
have a fortec star ultra cloned to a pansat2700a. How can I get new loader and files for my reciever. Tanks bigb
Oct 16, 2008 | Fortec Star Lifetime ULTRA
Need parts for Magic Chef Horizontal Furnace aprox. 20 years old. in a warehouse Model # G83-150D-5 Sr# e-22284BDB Stamp # 331378026 Need pamphlet with part list. Thanks, Nalin Parekh @617 504...
If over 20 years od parts are obsolite, but can be interchange with todays controls.. Download this information from the co's website! Thank-you-very-much!
Aug 27, 2008 | Heating & Cooling
Bosch Dryer venting
i think you will find that one of these caps should be off and preferably connected to a vent hose to go outside the house. the reason they are blowing off is that the air has nowhere to go
Jun 26, 2007 | Bosch Axxis WTA 3510 Electric Dryer
HP LaserJet 2840 All-In-One Printer Logo
51 people viewed this question
Seeker5211
Seeker5211
