Question about Ovens
Jkp54 ge profile double electric wall oven wont heat no error codes
Hi have a ge profile double wall oven electric with convection on top model jkp54. no error codes and the clock, timer, non-"oven" buttons on the control panel are working. Oven had been working fine till now. disconnected all power checked connections and reconnected. no change. Assuming its some sort of thermal fuse or switch(es).. what would be most probable causes? Thanks
  • glen todzia
    glen todzia Apr 18, 2014
    Just learned a few more details about the above problem. Wife thinks the oven may have shut down on its own after the last time she used it and when she went to use it the following day thought she saw an F1 code flash briefly but no other beeping was associated with it and no codes have appeared since.
SOURCE: top oven doesn't heat.
We had this same problem in our lower oven and found the solution the night before Thanksgiving. With 26 people coming for dinner, I desperately need both ovens. (Turn off the breaker for the oven before you do this.)
My husband took the control panel off of the upper oven and found a wiring diagram. In the text, it said there was a manual reset for each oven in the access panel for each one. He opened the access panel for the lower oven and found the reset button in the middle of that area. He said it was a black circle with a red button in the middle. After reseting, we turned the breaker back on and everything works great!!
Posted on Nov 27, 2008
aborcass
  • 2651 Answers
SOURCE: GE Profile -Installed wall oven - won't heat
brand new??? under a year old??? if so you have a warr call for service, but it sounds like an ignitor isssue, brand new , perhapsgot damaged in shipping 1-800-ge-cares
Posted on Mar 30, 2008
SOURCE: Whirlpool Double Oven RBD305PDB7 - Upper Oven Won't Heat
I have the single oven of this style and I had to replace the thermocouple (part number 4450934) on the back of the oven three times (used the cleaning cycle three times). After using the cleaning cycle, the oven would not heat so each time I had to pull the oven out from the wall to access the back so I could change the part. Once a new part was put on the back of the oven, it worked fine. To pull the oven out, open the oven door and look down by the doors hinges. On each side you will see a screw that's holding the side molding on. Remove the screws and then the molding. That will give you access to the screws that hold the oven into the framing around the oven. Remove the screws and then you can pull the oven out to access the back to change the thermocouple. The oven is heavy so you may want some help to get out. It is not a one man job, maybe a one man and wife job. It is heavy. I hope this helps. Better late than never.
Posted on Nov 24, 2008
  • 492 Answers
SOURCE: My GE Oven heating element and timer clock went
Try unplugging the oven and let sit for 10 min. This will reset the curcuit board and reboot the electronics. You may have to pull out the stove o get to the cord.
Posted on Apr 30, 2009
SOURCE: GE JTP56 double oven controls OK top OK bottom no heat
have you inserted the business card as described in the solutions?
Posted on Jun 28, 2009
Hi have a ge profile double wall oven electric with convection on top model jkp54. Keypad has stopped functioning hence oven does not work. The only exception is that when the clock button is pressed the...
do u have the manual for this oven , there must be a reset somewhere in the manual , the best answer here is to goto there website and start there to find out if this is a known issue with these models and if it is an easy fix , that is the best place to start .good luck
May 19, 2014 | Ovens
I have a GE microwave/convection oven that the lower oven wont heat, fan comes on top microwave works but the oven wont heat
First reset your breaker, then check your wiring in the back of the oven. You may have just a wire loose.
Feb 24, 2013 | GE Profile JT965 Electric Double Oven
F9 error code while using the convection baking function
This is a lock switch error code. Check wiring to door lock switch (the wire harness may be connected wrong). Check for stuck lock switch. If the switch cannot be re adjusted, it must be replaced.
Jul 30, 2009 | GE Ovens
Jun 26, 2009 | GE Profile JTP56 Electric Double Oven
Top oven doesn't heat.
Nov 23, 2008 | GE Profile JTP56 Electric Double Oven
Mar 29, 2008 | GE Profile JTP56 Electric Double Oven
Creda convection oven wont heat up
my ge profile double electric oven, bottome convection wont heat up
Feb 19, 2008 | Ovens
Ovens Logo
134 people viewed this question
Top Ovens Experts
ashburton
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
