Question about Bose SoundDock iPod Digital Music system (Black) with Monster iCarplay Wireless Plus Bundle (SOUNDDOCKICARPLAY) Docking Station
Bose sound dock doesn't work at all
Tried 2 different ipods. both are running and playing on the ipod window but nothing on the bose. tried multiple house electrical outlets. the bose appears not to have any power. checked all the converter box connections. is there a fuse or something in the unit that could be blown?
    Sniper:
  • 71 Answers
If this is the original SoundDock, the power supply in back is 4 pronged and a pin could be broken. If it makes a quiet thumping sound, then just make sure the power supply is not plugged in upside down (it's easy enough to do).
If this is the SoundDock II or the SoundDock portable, it's hard to say why this would happen, so you should call Bose on that one. There should be an indicator light that tells you when it has power..
Posted on Jun 21, 2009
Just so you know: I have a brand new sounddock and couldn't get it to work at all with my new ipod touch! After fooling around with it half a day, I finally took off the new protective cover devise on my ipod and presto, it works beautifully. I wasn't getting a good connection. Duh!
Posted on Aug 23, 2009
  • 17 Answers
This is what happened with mine:
The Bose power supply plug (the business end that goes into the unit itself, has a small copper pin in the center of the round "tube". If that gets bent, or the alignment is off, so it doesn't enter the very small hole in the center of the power port in the unit, it wont turn on. UNPLUG THE POWER CABLE FROM THE WALL, then use a small screwdriver or bobby pin to straighten that center pin out. Plug everything back in and see if it works.
Posted on Dec 26, 2011
I had the same issue. After checking the pins and replacing the battery on the remote, I simply removed and replaced the batter on the Bose SoundDock unit. For some reason, the Bose SoundDock didn't detect the battery. After reseating the battery, the remote now works.
Posted on Feb 21, 2010
When we play our iPod on the Bose system, the sound isn't in stereo. It kinda sounds like a karaoke machine. It used to work just fine. What could have happened? What can I do to fix it?
Maggie, you haven't stated which Bose system you have but the generally if the pop vocals are virtually inaudible and and it sound hollow then your ipod connector is damaged and one of the audio pins is not making contact. I have repaired hundreds of systems and you can spot it straight away. Assuming it is a Sounddock then the most inexpensive best is to 'buy and try' a docking connector from www.invebo.com. You can do it yourself click here to see the guide video. (Buy and try means that you are guaranteed a refund if it doesn't fix your problem)
Mar 05, 2012 | Bose SoundDock digital music system...
My Bose system does not want to play any of our different sized I pods as it does not recognise that there is an I pod there. It used to work perfectly. Cant believe that the docking bit is bent as it is...
different ipod generations have different shapes for their chargers i mean the angle of the ipod is different when u buy an ipod it comes with a white piece that has an eccentric hole in the middle put this down b4 putting the ipod in it may work now but u may have broken the usb access port for the bose
Oct 04, 2009 | Bose SoundDock digital music system...
Bose SoundDock burned out two of my iPods - a Nano and a classic.
um ur sounddock might require that u place the white docking piece that came with ur ipod to be place b4 the ipod is docked if not u may ruin the dock and the ipod usb port this is done because different generation ipods(nana and touch and ...) have different shapes so the entrance for docks may require to be eleveated or reduce in gradient basically if the dock isnt made for the specific ipod or u dont know just put the white piece in
Bose Sound Dock remote control - only volume works
My remote worked perfectly until I changed the battery. The original battery was CL 2032 and I replaced it with DL 2032. After replacing the battery, only the volume control works. The off button will only fade the sound while the button is depressed. Release the button, and the volume returns to the original level and the unit remains On.
None of the other buttons work.
If you've found a solution, please post it here.
Oct 03, 2009 | Bose SoundDock® (Black) Docking Station...
Bose sound dock - no sound comes through it but my ipod works with the ear plugs so it's not my ipod
I had this problem for the pat two days. Believe it or not I took my Ipod touch of the dock. Shut the power off to the Ipod to reset it. Also the power to the docking station. turned everything back on. Put the Ipod back into the docking station and heard the beep.. and hit play and it was working again. Not sure but shutting Ipod off does act like a reset.
Jul 19, 2009 | Bose SoundDock digital music system...
No sound from my 30GB ipod in the car and Bose sound dock
It sounds like an issue with the internal motherboard and possibly the audio jack. I'd reccomend taking it into a local apple store to have them fix it or contacting them via their support website here. Also you may want to consider their price quotes vs purchasing a new one when you talk to them.
May 24, 2009 | Apple iPod MA446LL/A MP3 Player
Wont play through my bose system anymore
the apple ipod are very delicate and it seems that docks are very harsh on the internal workings IE: motherboard of the ipod. it not just the touch, it's all ipods.
My suggestion is to check the headphone jack and if you get sound, don;t play your ipod on the dock at all. Your dock has probably done some damage to the audio circuit on the board.
If you get sound through the headphone jack save your ipods life and just use it through the jack.
I have replaced numerous motherboards on ipods played on docks. they just don;t handle the charging and playing very well whether it's heat or just the wrong voltage I am not sure.
But my first question to a customer is have you played it on a dock.
I would stay away from the dock
Apr 30, 2009 | Apple iPod touch
No sound from Bose SoundDock
I had this problem on my SoundDock. My iPod would charge on the dock just fine and when I played my iPod on the dock, it would look like it was playing, but have no sound. Since my Bose was out of warranty, this is what I did to fix it. #1 Unplug the adapter. #2 Unscrew the four large screws on the bottom of the speaker and the three small screws under the dock. #3 You'll see one long ribbon connection and one very short one. Check to see if the ribbon connector coming from the front of the speaker system came loose from the green board. You'll only be able to see 1/2 an inch of it sticking out, and it's not easy to plug it back in, but it's possible. Just take your time. #4 Carefully put everything back together being very careful not to let the ribbon fall out of the plug again. #5 Make sure to plug in the DC adapter the correct way. There's a very subtle difference, but there is a difference. There are four prongs - two are square and two have slightly rounded corners. If it's not plugged in the correct way, the dock will have a static clicking sound. On my adapter, the words "DC power" are on the top of the plug.
Jan 14, 2009 | Bose SoundDock digital music system...
Bose Sounddock problem
I had the same issue, it just stopped working today for no reason. Since it's out of Warranty and Bose charges too much to fix it, I took the bottom off, cleaned all the contacts, applied some dialectric silicone compound to the contacts, put it back together... and it works great!
Sep 17, 2008 | Bose SoundDock digital music system...
Gen 3 nano and bose docking station
Have you tried another iPod on it?? I suspect that if you do, that one won't work either. If it's a Bose SoundDock then they are well known for having problems with the iPod connector getting loose. Try with another iPod. If results are the same, take your SoundDock back. Bose should exchange it straight away.
Aug 06, 2008 | Apple iPod nano 3rd Generation
Open Questions:
See all Bose SoundDock iPod Digital Music system (Black) Questions
Bose SoundDock iPod Digital Music system (Black) with Monster iCarplay Wireless Plus Bundle (SOUNDDOCKICARPLAY) Docking Station Logo
8,591 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
