Question about Nikon COOLPIX P330 12 Megapixel Digital Camera - Black
Top dial not working
The top dial on my camera suddenly stoped working, nothing in the settings helps and I have restarted it several times
    Sergeant:
  • 225 Answers
Connector fault maybe? means taking it apart to check.
Posted on May 25, 2014
Why is my manual Mode setting isn't working
The NIGHT SCENE and NIGHT+PORTRAIT scenes are meant to take time exposures of skylines and city streets by leaving the shutter open for several seconds. Therefore, it is necessary to stabilize the camera by bracing it against something solid or - ideally - by using a tripod or camera clamp.
so play around with the shutter speed and bring it to above 100
The procedure is as follows:
  1. Set the camera's Mode Dial to the M (Manual) shooting mode.
  2. Using the Control Dial(big wheel), set the shutter speed to 100.
  3. Holding +/- button and turning the control dail will change focal length.
  4. Play around a bit with this too utill you find right lighting for the image you need.
  5. Remember slower shutter speed needs long time to process the image
May 31, 2014 | Olympus EVOLT E-410 Digital Camera
My DSC-HX100V jog dial is not working, it was perfect, but now I can't change settings with the jog dial. I had the same problem with de DSC-HX1 several month ago, and we changed the part.
Someone know which is the problem , and how to fix it? ... I have the same problem here, I have one Sony HX200V , it was working properly , when I suddenly started to have problems with its dial jog, I am not able to change values of my camera , Could someone let me know which is the problem , and how it is fixed? since I am traveling in just 10 days :S and I really need my camera!!!
thanks in advance
Aug 08, 2011 | Sony Cyber-Shot DSC-HX100V Digital Camera
The sound is not recorded when filming, we have only had the camera just over a year....any ideas, or who can we call? Thank you. (Sanyo Xacti XA9)
Hi natalieaylet ,
Firstly i would recommend you to check if the microphone settings have been accidentally turned off , many times the sound is not recorded because of this issue.
Please don't let people experiment with your camera as they could do damage to your camera.
So where you felt there was a problem , you will have a big problem , as a result of experimentation.
If you feel that nothing works , even after changing the settings and restarting the camera, i would recommend you to dial the number provided on the user manual usually, which will help you with the nearest service center details so that you can get your problem fixed by an expert.
Hope this helps ...:)
May 11, 2011 | Sanyo Xacti VPC-CA9 Digital Camera
My flash quit working
You are correct in saying that the bulb needs to be replaced. Take the camera to any camera shop and they will replace it for you.
Apr 20, 2009 | Canon PowerShot SD1000 Digital Camera
Nikon D100: suddenly all the pictures are black
Ellen,
When shooting with the D100 do you have the dial on top of camera set to 'Auto'? If so, then most likely you have some how adjusted to the exposure compensation, so your photos are underexposing.
To reset your camera to the factory default settings:
Hold down the bracket and flash button for two
seconds.
These are the buttons marked with a green dot
Take a test photo and see if that works.
Mar 18, 2009 | Nikon D100 Digital Camera
Monitor screen went blank after changing resolution
Try unplugging the monitor and then restart, and then go back to default settings.
Jan 30, 2009 | Samsung 793S 17" CRT Monitor
Canon powershot A590 displayes lens error, restart camera.
I had this problem. Nothing was lodged between the body and lens, restarting multiple times did nothing, cleaning, torquing, twisting over several days - nothing.
So, figuring "what could it hurt?" I just smacked it on the heel of my hand a couple times. Now it works.
firm percussive maintenance saves the day once again.
Dec 27, 2008 | Canon PowerShot A590 IS Digital Camera
My L7i keypad won't work
you remove your mobile panel, clean the keypad and refix
Feb 28, 2008 | Motorola Mobility SLVR L7 Cellular Phone
Pink screen
Back to store or maker with it. Check out the makers Tech support site but this needs a new camera replacement.
May 16, 2007 | Kodak EasyShare C643 Digital Camera
Nikon COOLPIX P330 12 Megapixel Digital Camera - Black Logo
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
