Question about Nikon COOLPIX L100 Digital Camera
How to turn off the flash ligh in Nikon COOLPIX L27
How to turn off the flash ligh?
praky16
  • 744 Answers
SOURCE: flash on Nikon Coolpix s200 camera not working
hi try to reset ur camera...To do such reset, turn on the camera and hold the menu button down for longer than 5 seconds. A message should hopefully come up on your LCD asking if you want to reset the camera. Select Yes...
thank u!!!
rate me!!
Posted on Jun 28, 2009
SOURCE: flash doesn't work on nikon coolpix l12
I actually just fooled around with mine because it was doing the same thing. It will only flash in the scene mode, but not the normal quickshot mode. i noticed under the camera symbol on the screen said BSS and i went into the menu and clicked on BSS and turned it off b/c it was on and that worked finally.maybe u can try it, if its the same situation.
Posted on Aug 07, 2009
BillB-SA
  • 2761 Answers
SOURCE: My Nikon COOLPIX S51 Will not turn on.
Your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced, or the camera may have a problem that requires professional repair.
Posted on Nov 08, 2009
  • 11967 Answers
SOURCE: Somehow the flash got turned on. How do I turn it
Press the button with the picture of a lightning bolt...watch the screen and when a lightning bolt with a line through it appears, your flash is off.
Posted on Dec 24, 2009
tbreeze47
  • 3083 Answers
SOURCE: Nikon Coolpix battery will not charge
The battery could be near the end of it's useful life. Try another one to make sure it's the battery and not the camera.
Posted on Mar 31, 2010
Testimonial: "Thanks but I thought the battery would last more than a year"
Camera is dead , battery is fine , nothing turns on
Nikon Coolpix S8200 Troubleshooting - iFixit
https://www.ifixit.com/Wiki/Nikon_Coolpix_s8200_Troubleshooting
iFixitThe Nikon Coolpix S8200 model was released in August of 2011 with a ... Flash won't work, but light bulb is fine; Flash is enabled but still won't go off. Camera won't turn onĀ¶. You have tried turning on your camera and nothing is happening. ... Once a green light turns on, it is telling you that your battery is fully charged.
Coolpix S4000 won't turn on? - ePHOTOzine
https://www.ephotozine.com/.../coolpix-s4000-won-t-turn-on--97474
Jun 4, 2012 - Still won't power up mine so I am giving Nikon a call in the morning to see if they can figure out .... started up with both batteries all fine & dandy
Problem with Nikon Coolpix P510: Nikon Coolpix Talk F
Jan 08, 2016 | Nikon Coolpix S6700 20.1 Megapixel Compact...
Says card media protected will not let me delete
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Oct 11, 2014 | Nikon Coolpix L27 16.4 MP, 5x Opt, SD Card...
How can i do a hard reset on coolpix l27 ?
Turn on the camera and press the Menu button. Use the multi-function buttons to scroll to the tab with the symbol that looks like an ope-end wrench. Scroll to "Reset All" and press the OK button and confirm that you want to reset the camera.
Aug 25, 2014 | Nikon COOLPIX Cameras
I have a nikon coolpix l27, every time I try to take a pic it switches off!
Are you sure the battery is still ok? As soon as de capacity of a battery is not enough the camera's tend to shut down. PLease also check if the contacts of the battery and from the camera in the battery compartment are clean and shining.
Nov 03, 2013 | Cameras
How do you turn the flash off on a Nikon Coolpix 7600 Digital Camera
Press cursor-up to bring up the flash menu. Select the lightning bolt in a circle to turn off the flash.
May 01, 2012 | Nikon Coolpix 7600 Digital Camera
Simple problem: how di i turn the flash off on the nikon coolpix
Press the flash button (Up on the multiselector). This gets you a menu with five choices: Auto, Auto with red-eye reduction, Off, Fill flash, and Slow sync. Select the one you want (eventually, you're going to want to turn the flash back on) and press OK.
Mar 03, 2010 | Nikon Coolpix S51c Digital Camera
Nikon CoolPix Flash Problem
This happened to me too!
Turn the dial to setup, push the menu button & select reset all. This will restore the defaults & let you use the flash again.
Feb 13, 2008 | Nikon Coolpix 7600 Digital Camera
Nikon COOLPIX L100 Digital Camera Logo
82 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
