Question about DeLonghi Coffee Makers & Espresso Machines
While Brewing Bin Full Lights Came On
My Delonghi Perfecta 5500 While Brewing Bin Full warning Lights Came On but tank is empty
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 51 Answers
Check the housing where the bin sits is clean and free of coffee and other debris
Posted on Jun 21, 2014
SOURCE: water does not get to main compartment
try priming the machine ( find the plastic gizmo that came with the machine for this purprose..can you get water from the steam nozzle?..there is an internal water filter that may become clogged if you aren't keeping the water tank clean.
Posted on Dec 16, 2007
EwingElect
  • 276 Answers
SOURCE: I desperately require an User Manual for a
try http://www.delonghi.com.au/support/instruction_manuals.asp?group=&mst=contain&ms=esam5500&dst=&ds=
Posted on May 26, 2010
  • 4 Answers
SOURCE: DeLonghi Perfecta ESAM5500 when trying to make a
Had this exact problem a few times on a cleaned well maintained milk jug top with an ESAM5500M. Delonghi 'repaired' it by sending a new milk jug frothing top.
It's caused by milk fat deposits, the frother part on the milk jug may look clean but deep inside it's not. I clean mine with pipe cleaners, detergent and hot water and still it wouldn't froth.
The problem re-occurs for me every 6 months or so. You could buy the milk fat remover solution to clean it. Personally I just boil the whole milk jug frother in detergent and the again in descaling solution, that's fixed this problem twice now, although I think it will eventually corrode the 'o' rings on the frother, still cheaper than buying a new frother part each time though.
If it still doesn't work after that, the only other reason for this problem I found mention of was caused by a broken rubber seal where the milk jug fits to the machine. It's most likely to be milk fat deposits inside the frother though.
Posted on Feb 08, 2011
SOURCE: the door to my DeLonghi
I hope you have solved this problem by now... The door not closing properly happens when coffee grounds build up in the middle of the machine. It tends not to get everything into the waist box. You need a chopstick to fish out the grounds from behind/under the central column of the machine. You'll find a lot of coffee packed in! Then the door will close.
Posted on Oct 22, 2011
edward_iskra
SOURCE: How do I descale my Delonghi Perfecta? Can't
The manual is no longer available at that link. It's better to post an answer than to simply point to a URL...
The answer:
1. Fill the tank with descaling solution (or a vinegar solution, which voids your warranty, but seems to work well...)
2. Power on.
3. Hit the P button (Program). The display changes; instead of the usual icons, you will see the "clean" icon, which looks like rain drops in a circle. (This is for rinsing the coffee drip spigots). Turn the selector wheel to switch to it an icon that looks like a bunch of dots between two vertical bars. This is the "descaling mode."
4. The bottom left button now says "Esc" next to it, and the bottom right is the OK. Hit OK to confirm you want to descale. Then dump the drip pan and put a large container under the WATER spigot (not the coffee drip spigots.) Your descaling solution will come out hot and hard. The machine may pause and re-heat at times, to make sure it's very hot. The solution is hot and acidic - BE CAREFUL! It will go through the entire tank, so use a big container, or be ready to switch it out - or put your machine over the edge of your sink for the job.
5. When the tank is empty, the machine will ask for a refill - this time give it clean water for a rinse. Hit the OK; the entire water tank will be used to rinse.
That's it!
Posted on Jun 03, 2012
Delonghi Perfecta 5500 just out of the box. The problem appeared when I plugged for firs time.
How to reset to factory default values
Caution: It will reset all menu settings and programmed
to the default values.
1. Press the "P" button to enter settings.
2. Turn the selector until "Default Values" shows.
3. Press the button to confirm.
4. The message "Confirm?" shows.
5. Press the button to confirm and exit
Dec 10, 2017 | DeLonghi Coffee Makers & Espresso Machines
DELONGHI ESAM 5500 WON'T MAKE CAPPUCCINO SAYS GRINDS TOO FINE, BUT WILL GRIND AND MAKE REGULAR COFFEE
have you tried cleaning it as described in your user manual,, can you hit the button for regular grind? there are alternatives, a coffee grinder if failry cheap at 10 dollars US,,
Jun 07, 2016 | DeLonghi Perfecta ESAM5500 Fully Automatic...
General warning coming up in heating cycle.Not working at all.
For DeLonghi Perfecta ESAM5500 Fully Automatic Bean to Cup Coffee Maker Team De-Brewerz.com says:
1. General Alarms should be taken care by authorised delonghi technician only. Please do not try to fix yourself as it is related to safety.
2. This error occures due to loose wirings, opened water circuit, failure of heating elements and last failure of PC board repalcement.
3. Please contact your nearest Delonghi authorised dealer for technical support.
4. You can claim the warranty if recently purchased through De-Brewerz.com . If you are in India then contact us at de.brewerz@gmail.com
Nov 03, 2014 | DeLonghi Perfecta ESAM5500 Fully Automatic...
My DeLonghi DEM10 wont power on any more - like fuse gone
The tank may be full. Your dehumidifier has a safety device that turns off the dehumidifier when the water tank is full. Usually the tank itself either presses against a switch or there's a device connected to the tank that triggers a switch when the tank is in place and full.
If you've emptied the tank and the unit doesn't run, inspect the place where the tank rests to see if there's a switch or mechanism that's not being activated. You may be able to turn it on with a simple flick of your finger.
Sep 03, 2009 | DeLonghi Dehumidifiers
Coffee Makers & Espresso Machines Logo
76 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
83bj60
Level 1 Expert
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
