Question about Handpresso Auto Ese Portable Espresso Maker For The Car
Why isn't it working?
The handpresso auto starts heating then stops suddenly after a few seconds. It is only a couple of months old & has only been used for 2 weeks
    Top Expert:
  • Handpresso Master
  • 34,193 Answers
The heating element may be protected by a thermal fuse which is opening up, then resetting after cooling down.
Posted on Apr 08, 2016
Why as my AMETEK SUPERVAC 240V AC 5.7" 2 Stage Vacuum Motor just stopped working no warning help?
If it's only a few months old it will still be covered by the manufacturers guarantee.
Aug 02, 2014 | Ametek LAMB 117507-00 Vacuum Motor/blower...
Panasonic heat pump
Sounds like that's the relay clicking to run the blower motor .Check on your unit outside and see if the compressor is short cycling ,meaning it would run ,stop ,run ,stop .
If that's the case you have a bad install .
Maybe unit is shutting off on low pressure meaning no refrigerant. If that's the case you have a leak in the system that need to be fixed
Jun 01, 2017 | Heating & Cooling
No hot water from kitchen tap
The hot side of the faucet is most likely plugged with something that came up thru the water system. The average thankless waterheater requires at least 1/2 to 3/4 gpm flow rate for the unit to sense flow and turn on. If there is not enough flow it will not fire and heat the water. Not sure about this particular unit but a few require at least one full gallon per minute flow. So chances are that if you fix the faucet, you fix the hot water issue at the same time
Jan 09, 2014 | Rinnai Water Heaters
Delay in Auto shifting from 2nd to 3rd gear
Check your ignition coils. One of mine was bad and when I replaced it, the shifting issue stopped.
Apr 22, 2013 | 1997 Nissan Maxima
All of a sudden, my 18 year old Kenmore gas dryer is not producing hot air. The motor is working & the barrel is revolving. What can I do short of spending $500-$600 for a new comparable Kenmore gas...
It sounds like your heating element has given up the ghost and broken OR you have a bad thermostat that isn't telling the heating element to work. I would suggest you find the tag on your dryer with the model number on it and then go to www.searsparts.com and look it up and find the heating element and thermostat and decide if you want to spend that much.
NOTE: Usually, on older models, I always recommend that my client replace both so that I don't have to come back again in a few months to change the other. They seem to both fail close to each other.
Jun 18, 2011 | Kenmore Dryers
I have an alba tv 42" flat screen, and suddenly it
depends on model but this is common problem with the cheap flat screens people are buying now
price should be in the mid 100s for part plus labor to install
Mar 13, 2011 | Televison & Video
The mower is 3 months old worked fine untill yesterday
the problem is either u have trash in the bowl of the carb or the float in the carb is stuck. either way u need to have someone look at it.
Aug 12, 2009 | Mtd 22" Yard Machine Push Mower
NI-A57SR steam Iron suddenly not functioning
I had the same problem, when I took it apart, I noticed the theromstat points needed sanding. Just a reminder, make sure to write down the order of wire leads before disconnecting. By the way to test if the heating element is working connect white lead to the second connection from the left and black lead to the far right. Place your iron flat down on a wet cloth ( so that you won't burn your surface). You can also use an electrical tester. If heating element does not work though, it is time to buy a new iron.
Dec 31, 2008 | Panasonic NI-A57SR Iron with Auto Shut-off
Old Frigidaire apartment size (24'0 top dryer stopped working.
check the breaker i know the washer works so how come the dryer works on 220volts if one side is out the washer will work but not the dryer if that is not it check the door switch the unit also has a thermal fuse that could be out there is no reset button
Nov 30, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Handpresso Auto Ese Portable Espresso Maker For The Car Logo
87 people viewed this question
Top Handpresso Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Handpresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
