Question about Greenworks 1700 PSI 1.4 GPM Electric Pressure Washer 51012
Greenworks parts high pressure connection pipe kit
On page 25 under trouble shooting for greenworks 1700 it states that you can turn nozzle tip to a high or low pressure position. how is that done?
The owners manual was badly written by someone in China whose English is a second language. The output pressure is set at the factory. The only thing the consumer can do is change the spray pattern by changing the nozzle. 0 for pinpoint, 25 for small fan spray pattern, 40 for large fan spray pattern, and Soap for dispersal.
Jul 08, 2016 | Greenworks 1700 PSI 1.4 GPM Electric...
I have a model 51012 washer..I need replacement nozzles. where can I get them? thanks.
Go to their website and check out support. Some outfits will only sell parts thru their "authorized" dealers.
Jul 19, 2015 | Greenworks 1700 PSI 1.4 GPM Electric...
How do I remove the original hose and connect thwe replacement
Hi Mark
Where the hose attaches to the machine, you'll likely have a "collar" that you will be able to turn
Slide that sucker away from where the hose comes to it and you'll free up the connection.
-Steve
May 02, 2015 | Greenworks 1700 PSI 1.4 GPM Electric...
I need to replace the high pressure hose on my Greenworks 1700 because the one I have has developed a hole after being in storage/no use for a few months. I purchased a replacement hose at Lowe&a
Search Fixya with your question as it was answered last June.
If less than a year old contact the manufacturer. My hose burst (different brand); turns out they got a bad batch of hoses and they replaced the whole unit at no cost.
Sep 13, 2014 | Greenworks 1700 PSI 1.4 GPM Electric...
High pressure connection pipe kit
Lowes and Home Depot stock common connector fittings. Paint supply stores might have more selection.
Apr 17, 2014 | Garden
Install replacement high pressure hose
If you are replacing the hose because it burst you might contact the manufacturer. Mine, of a different brand, burst and they sent me a new pressure washer saying that it was very difficult to install a new hose. They had a lot of problems with hoses from China.
Apr 09, 2014 | Greenworks 1700 PSI 1.4 GPM Electric...
How do you take the hose reel off on a greenworks 1700 psi pressure washer?
There should be a clip that holds it in place, see link.
http://www.ppe-pressure-washer-parts.com/greenworks-51012-pressure-washer-parts
Jan 12, 2014 | Greenworks 1700 PSI 1.4 GPM Electric...
Greenworks 1700 PSI 1.4 GPM Electric Pressure Washer 51012 Logo
99 people viewed this question
Top Greenworks Garden Experts
Ed60062
Level 1 Expert
Marc Taylor
richie46
Are you a Greenworks Garden Expert? Answer questions, earn points and help others
