Question about Mr Christmas Gold Label Royal Marquee 75th Anniversary Carousel Music
Carousel won't turn - Mr Christmas Gold Label Royal Marquee 75th Anniversary Carousel Music
Kodak 850 Carousel Projector tray won't advance
The Carousel 850 is 40-45 years old. The symptoms you describe indicate the timing is off. Timing is an "adjust & test"..... try a SMALL adjustment and then test it.... adjust again & test again. Repeat until you get smooth tray action. See the attached illustration:
May 16, 2013 | Kodak CAROUSEL 850 KODAK
Carousel will not turn
Could be a broken/loose carousel belt. take the cover off and look near the back of the unit and make sure that both belts are on there respective pulleys.
Jan 02, 2013 | Sony MegaStorage CDP-CX355 300-Disc CD...
MR. CHRISTMAS CAROUSEL WON'T TURN
I realize this post is way old, but wanted to thank LtJim for his description on how to take it apart.
It turns out the reason mine was not spinning is that one of the plastic mechanisms that make the horses go up and down (located under the main piece that comes off with LtJim's directions) had partially broken and that horse would go all the way to the bottom and then the carousel would stop spinning.. There was no way to fix the plastic, but by holding the horse up with zip ties hidden under the top got the thing to work again. Thanks again!
Dec 12, 2012 | Toys
I have a Haier microwave and tonight after heating some food, I went to close the door and upon closing it, the carousel started turning and it won't shut off.
It sounds like one of the door switches has become defective, each must be disconnected on the one side and tested with a digital meter using the ohms scale.
Jun 07, 2012 | Haier Microwave Ovens
My Kodak Carousel 650H has a stuck slide and the tray won't move. The stuck slide is lined up with the "gate index." I tried releasing the tray but only one side of the tray releases. The...
Two steps.
1) Look down into the center of the carousel. There should be a round, flat silver knob with an elongated notch in it. Take a coin (US 5-cent piece or similar) and use it to turn the knob. This releases the catch on the metal plate under the projector. You should then be able to lift the carousel off. Be careful: some slides will fall out as the slot is not aligned with the carousel body properly once you do this.
2) Make sure the locking ring on top of the carousel is in place (or else take out all your slides. Turn the carousel over and gently rotate the metal plate covering the bottom of the carousel into position. You will hear/feel a "click" when it's in place.
The projector may have jammed because there are two slides stuck in the viewing slot--check for this before you put the carousel back on the projector. If it jams a lot the metal plate under the carousel may be bent.
Jul 17, 2011 | Kodak Carousel 4600 Slide Projector
Carousel quit turning and light won't come on.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 ;;'
Jun 28, 2011 | Magic Chef MCO160UQ Microwave Oven
2550L carousel won' t rotate when I push the button. Need to get the cartridges out to put in a newer one that I bought.
This is usually caused by generic toner cartridges. The only way to turn the carousel is to take the top cover off and then manipulate the solenoide on the top right hand side of the printer. This allows the carousel to turn to where you want it.
Jun 09, 2011 | HP LaserJet 2550L Printer
Microwave lights, clock, and everything works except when you press start, it just counts down like its cooking, but the microwave is actually not on. No hum as usual or plate rotating. It just counts...
Hi, one of the most common reasons why the turntable won't rotate is that the microwave isn't clean. The turntable guide and carousel can get sticky, preventing the turntable from properly moving. If you have built-on food particles or liquids, fill a bowl with 2 or 3 cups of water and 1 tsp. of liquid detergent and lemon. Run the microwave for about 3 minutes. Clean the microwave with a cloth, including the base of the turntable, guide, carousel grooves and microwave base. Your microwave turntable won't rotate if the grooves on the base of the turntable do not sit right on the carousel. Also, check the position of the turntable guide. Place the guide directly under the turntable. Remove the turntable, and then reposition it into the carousel grooves.
Motor The carousel motor is located beneath the base plate of the microwave. If the carousel isn't turning at all, check the motor. Disconnect the microwave from the power source, and remove the turntable, guide and base plate. Try turning the motor to see if it's just stuck. If it doesn't turn freely after a few seconds, examine the motor to see if it's burned out or corroded. Use an ohmmeter to see if the motor has continuity. If not, you must replace the motor.
Bushings The drive bushings are plastic components that sit underneath the cooking plate. Remove the plate, and examine the bushings. Use a magnifying glass if necessary to see if any debris is caught in the plastic. Clean the bushings, and reinsert the plate. Turn the microwave on to see if it rotates. If the bushings are extremely worn or if some of the plastic is broken off, you need to replace it, which is a complicated repair for consumers. Contact a service technician for assistance.
May 07, 2011 | Amana Radarange Microwave Oven
We have a Gemmy airblown carousel with four figures inside. It will only partially inflate. We have unzipped everything and untwisted everything. The bottom inflates and part of the top but nothing in...
mine is doing the same it gets twisted cutting off the air supply. I unwind it and lubed it but it continues to happen. there seems to be some sort of spring on the inside at the based. i'm thinking of cutting the tie straps and seeing whats inside...
Nov 29, 2010 | Carousel Airblown Inflatable Christmas...
You can order a new carousel from Capresso. It's $90, though:
http://www.capresso.com/pdf/order-ultima.pdf
Make sure the lever is up when turning the carousel, and keep the button at the back of the machine depressed while screwing the carousel onto the unit (and while taking it off the unit). I think the positioning of the button point at the beginning of the carousel replacement process is also important:
http://capresso.com/pdf/inst_esp_ultima.pdf
Mar 28, 2009 | Jura Capresso Ultima 121 Espresso Machine
Mr Christmas Gold Label Royal Marquee 75th Anniversary Carousel Music Logo
164 people viewed this question
Top Mr Christmas Home Experts
Donni Steen
Tom Chichester
Are you a Mr Christmas Home Expert? Answer questions, earn points and help others
