Question about Kenmore Microwave Ovens
Trying to uninstall remove my kenmore over range microwave mode; # 564.8598410
3 Suggested Answers
MicrowaveSvc
  • 9098 Answers
SOURCE: Microwave Ovens
The installation manual will cover that. If you don't have yours, you should be able to order it via Sears parts online: http://www3.sears.com/ You will need your full model number to look it up.
Posted on Mar 04, 2007
scottowa
  • 87 Answers
SOURCE: Remove Kenmore Mod. # 5648598601 from wall.
A lot of those you can replace the bulb without taking it down. There should be screws at the top that lossen up the vent in the front. Remove the vent, might have to open the door and slide it to the left (a little latch) then you should see a filter that just comes out and behind that is the bulb. I would try that before taking it down Forgot to mention that in the other e-mail.
Posted on Mar 04, 2009
Kenmore microwave combination microwave turntable makes a loud sound like a bearing is going out. Can I fix it myself?
Is this an over-the-range (OTR) microwave oven? If so, it is easy to change that turntable motor. First unplug the microwave. Then remove the 6 to 8 screws that hold the bottom panel in place. It will tilt down, with the back being held by the wall bracket. Now you can easily get to the turntable motor. Remove the wires to it, and remove the 1 or 2 screws that hold it in place, and you can easily remove it. Before you can install the new motor, remove the glass try, and rotate the coupler so it lines up with the "D" shape of the shaft, push the motor up in place and replace the screws, then the wires to it, and finally re-fasten the bottom panel of the microwave.
Jan 12, 2015 | Kenmore Microwave Ovens
How to remove Kenmore Quicktouch micro hood
If it's like most above-the-range microwaves, there will be 2 or 3 screws holding it from above, inside the cabinet
While supporting the unit from below, remove screws.
The rear of the unit is supported by hooking onto a bracket that is screwed to the wall behind it.
The rear needs to be lifted, then the unit should pull away from the wall. Requires some muscle.
Mar 02, 2014 | Kenmore 66469 / 66462 / 66464 Microwave...
Kenmore 401.80082700 Over the range microwave just stopped working. WILL DO NOTHING! Is anyone home out there?
I would go ahead and replace the microwave oven the cost to repair will be higher than what you are thinking of getting.
Mar 23, 2012 | Kenmore Microwave Ovens
Microwave oven kenmore 401.80086700 need to know how to acess the fuse in it
If this an over the range microwave, there should be a couple screws on the door side of the control panel that you remove and the control panel will drop down so you can access the inside of the microwave.
Jun 20, 2010 | Kenmore 62702 Microwave Oven
I don't see how you remove it from the wall mount
do you have cabinets abofe the microwave. open and see if the brackets that hold it on are in there.
May 25, 2009 | Kenmore 63792 Microwave Oven
Mar 04, 2009 | Kenmore 80412 Microwave Oven
Kenmore microwave range hood model 665.61612100 manufactured 2001
The problem is likely on the control panel, which we repair nationwide for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This often can affect the exhaust fan operation, too. The lights and fan can be inopoerable or stuck on.
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Oct 13, 2007 | Kenmore 62622 Microwave Oven
Microwave Ovens
Mar 04, 2007 | Kenmore 62622 Microwave Oven
Microwave Ovens Logo
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
