Blower wont turn on
I just instilled a new control center and every thing work expect my blower dosn''t turn on
    Sergeant:
  • 340 Answers
Wired wrong. or you replaced a good control in a unit that has a bad motor.
Posted on Jun 19, 2009
2005 equinox blower motor wont work
not sure which module you replaced but there are two of them the resistor/module and the hvac control module
Nov 14, 2013 | 2005 Chevrolet Equinox
The heat in my 96 mazda protege dosn't work
With the ignition and fan switches turned on check for power at fan motor.If you have power at the motor then wiggle and maybe pull on the blower motor resistor and if fan comes on just fix the connection.But when you check for power at the blower motor and don't have power then check the fan relay if it does'nt click when you turn it on then its faulty.
Oct 29, 2012 | 1996 Mazda Protege
My new wind shield wiper motor wont work
Voltage may be dropping through corrosion or resistance in the wiring.
Sep 08, 2017 | Cars & Trucks
I bought the fast lane R/C FA-005 Helicopter and right out of the box, the controller wont connect to the copter. It says in the book to give it full throttle then back down to none, , It has connected...
If the controler light is flashing try new batteries.the light should stay on. Also try and make sure your not around any thing that would give off electrical interferance
Aug 10, 2011 | Fast Lane Toys
Heater does not work
Check heater fuse.
If fuse good - could be a failure of the blower fan motor or blower control switch.
If fuse bad - bad blower fan motor could have blown the fuse.
DO: check fuse, then blower motor.
Pricing: new blower motor: Duralast PM270 $43.99
new heater control switch: Duralast SW229 $46.99 (without
A/C).
I'd expect your blower resistor to be good - when they fail, the blower only will work on HIGH setting.
Oct 23, 2010 | 1993 Dodge Caravan
2005 gmc sierra blower wont turn on
Check the fuse first thing. If the fuse it good then either the blower motor speed control switch, blower motor resistor pack, or the blower motor itself is bad. Normally the speed control switch rarely goes bad. If some of the speeds did not work prior to total failure then the resistor pack is bad. If that is not the case then apply 12 volts directly to the blower motor to see if it is good. If it runs suspect the resistor pack as the culprit.
Jul 15, 2010 | 2005 GMC Sierra
Our heater, and a/c are both out. Have no sound of a fan. We have a 2001 Grand Marqui
If you have Digital controls first check your fuses. Then if they are OK the blower controller is bad. This part is under the hood in the ductwork.
It sticks out of the firewall and usually is behind the engine where a heater hose comes out of the intake manifold. It has 2 screws and 1 electric connector. The only good thing about the whole deal is "When you can get the electric connector off the old part you can attach it to the new part to see if it works".
You can turn on the blower and the fan will work if the controller was the problem. You do not need to start the engine. Then you finish the repair. Most likely the heater hose will have to be moved temporarily and then you can get to the screws and switch the parts.
My best price was $20 at a Salvage yard. Expect much more for a new part and usually $50 for most used parts.
Jan 18, 2010 | 2000 Mercury Grand Marquis
Fan blower fuse location on a ford f150 year 2000
FUSE #105 40A** Climate Control Front Blower, THIS FUSE IS LOCATED IN THE UNDERHOOD POWER DISTRIBUTIOPN BOX
Oct 14, 2009 | 2000 Ford F150 Flareside SuperCab
Furnace
could be bad control out of the box it does happen recheck you have the motor terminals correct is the motor getting voltage?
Jun 19, 2009 | Bryant 463AAC008BA Air Conditioner
A/c fans wont blow
If the fuse is blown for the blower then there is a short, that is not an answer, go to the blower and check to see that the blower motor connector has 12 volts to it when the blower is set to high speed on control, if it does then u need a new blower motor, if it doesn't then the control switch is defective or the blower motor speed control resistor is defective.
May 13, 2009 | 2000 Mercedes-Benz S-Class
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
