Question about Hotpoint Dryers
Hot Point dryer DLB 1550 BALWH not drying clothes
  • Hotpoint Master
  • 3,247 Answers
There are several reasons for dryer not drying clothers.
It might help to go through the guide on this website. Hotpoin Dryers are rebadged GE appliance. So should be same.
IF you find a particular area or part that might need replacement then go to this page for parts availabiity
http://www.appliancepartspros.com/parts-for-ge-dlb1550bal.html
http://www.appliancerepair.net/clothes-dryer-repair.html
Posted on Apr 24, 2014
Dryer drying to hot
Check the fan is running, and the filter is clean
Dec 28, 2012 | Bosch Nexxt 500 Dryer
Hot Point Dryer won't dry, gets hot on top.
An educated guess would be either the lint tube or the tube that exhausts the air outside is blocked with lint----no airflow or greatly reduced flow will cause this symptom.
Nov 06, 2012 | Hotpoint Dryers
Model # DLB 1550 BRL WH Runs, but no heat
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jan 02, 2011 | Hotpoint Dryers
Dryer control doesn't move on less dry more dry setting and will not shut off when clothes are dry.
If clothes are hot then try dryer on timed dry. If timer does not move then timer is most likely bad . Replace. If timer moves on timed dry it is not getting hot enough to click the cycling thermostat.(If clothes are overly hot above 160 then the cycling therm. is stuck Replace.
Oct 29, 2010 | Dryers
My dryer runs and gets hot but cloths don't dry.
Your problem may be attributed to a clogged exhaust system (e.g.: clogged inside the dryer's vent, flexible vent behind dryer clogged and/or clogged inside wall, etc.).
Feb 22, 2010 | Whirlpool GEW9250 Electric Dryer
Long time to dry clothes
The dryer has one of its rows of heaters open. Open up the dryer and check the coils behind the drum. read more
Mar 09, 2009 | Hotpoint NVL333EY Electric Dryer
Hotpoint bwd129 washer dryer won't dry my clothes.
my Hotpoint dry will not dry my clothes. It will run for hours and the clothes still haven't dry just felt hot.
Oct 05, 2008 | Washing Machines
Drying problem
poss a blocked filter or intermittant pump fault or your water valve that supplies your condenser
Mar 03, 2008 | Washing Machines
Clothes not drying
A couple of possibilities to check. First, is the lint trap empty? If so, then the symptoms point to hot air bypassing the drum. Look for broken or misaligned plastic ducting inside the dryer itself. Check the exhaust air for moisture, as that is a better indicator than temperature. Don't forget that towels hold an enormous amount of water, & can be extremely long in drying, especially if not spun enough.
Jul 10, 2007 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
128 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
