Question about Vacuums
How do I access the on/off power switch to the canister
  • Vacuums Master
  • 1,338 Answers
Some models have the switch under a removable pedal which can be pried out. Some models require removal of the the top cover to access the switch.
Posted on Apr 19, 2014
Hoover s3670 opening the vacuum case
there are screws under the power switch and the cord recoil switch. the switches pry off lengthwise. once the switch covers are off you will see the rest of the screws. it was pretty straight forward from there.
Jan 02, 2012 | Hoover S3670 Bagged Canister Vacuum
Got a Filter Queen Majestic Limited Edition, the one with the high and low power switch, an I have to change the power cord. How can I open the main unit to reach that power cord? Thanks,
first remove the top cap under your handle.
Then, remove the three screws under the handle.
remove the rubber cover on the switch
undo the clamps on the side of the unit
lift off the chrome cover with the cord on it by the handle itself.
When you have the access there, change the filter inside the upper chamber as well.
Good luck
Nov 15, 2010 | Filter Queen Majestic Canister Vacuum
My Miele S548 does not turn on. I am suspecting power cord contact inside. I am pretty good at disassembling electrical equipments including TVs and laptops. Not being able to open the vacumm canister...
heya,
your exactly right. there is probably 2 or 3 screws your missing there.
now getting to these screws is easy. If you haven't already, remove the top filter and the bag door lid.
Assuming you have taken the screw out holding the black control panel out already... you want to remove the black panel with your on/off switch and the cord rewind. Once you have the panel off there are a couple of screws there that are holding you back. once removed, you should have full access to the underneath with the motor and cord rewinder there.
Good luck,
Mark
Nov 11, 2010 | Miele S548 Bagged Canister Vacuum
How do I replace the belt on my Kenmore canister vacuum?
Turn the power brush over so the bottom faces up. On the bottom there are two access screws. Remove the two screws and then the top cover can be removed from the base. With the top cover off you can access the belt. You can get a replacement belt for your model here:
Kenmore Progressive Replacement Belt
Nov 17, 2009 | Kenmore 25512/ 25513 Progressive Canister...
Central Vac will not turn on.
These problems are nearly exclusively caused by a bad circut board and replacing it is the fix. Bad boards can cause many different effects so its nearly impossible to be sure. The 9v signal wire is not enough to short out an entire unit so it is unlikely the hose. If it is a direct connect system and you are pulling power from the 110 somehow that would cause main unit problems but that is unlikely at best. Sounds like a failed board to me.
Best of Luck
Jun 04, 2009 | Easy Flo EF1400 Central System Vacuum
Switch is not working I want to change it but I cannot access it.
THE LONG PLASTIC STRIPS DOWN THE SIDES HAS A TRACK IN IT. YOU MUST OPEN THE DOOR AND PULL (SLIDING) THE STRIPS OFF THE TRACK LONG WAYS AND THE TOP HALF WILL SEPERATE FROM THE BOTTOM HALF. BEWARE THE WIRING INSIDE IS JUST LONG ENOUGH AND CAN DISCONNECT EASY. IM PRETTY SURE YOU HAVE TO DO THIS TO GET TO THE BOARD INSIDE.
Mar 04, 2009 | Electrolux UltraLux 2000 Bagged Canister...
4.3 amp Kenmore canister vacuum power switch has failed
You did not give the complete model number, but you can go to sears.com, click on parts and put in you model number. You will get links to click on, click on the cannister one and you get a picture breakdown and a parts list, you can also order after choosing the part you need.
Aug 09, 2008 | Kenmore 22812 Bagged Canister Vacuum
Eleectrolux canister sweeper power switch
There should be screws holding the handle asembly on to the top. One near the from, another by the handle, then slide the door near the back, there are 2 more screws there. with the handle off, you can get to the switch. Hopefully you can fina a replacement, alot of parts for the older Electrolux is No Longer Available.
Feb 12, 2008 | Electrolux Guardian Bagged Canister Vacuum
Majestic filter queen not working
could be power switch or power cord, happens alot
Nov 13, 2007 | Filter Queen Majestic Canister Vacuum
Vacuums Logo
22 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
