Question about Kenmore Progressive Canister Vacuum Cleaner with SWIVEL STEERING SYSTEMTM Red Color 21714
How do I replace on/off switch for Kenmore 116.29229 vacuum
Can't figure out how to access the switch to the on/off power
Power button won't shut it off...have to unplug it.
Dawn, a local vacuum shop can change defective switch for you.
Mar 27, 2016 | Panasonic MC-UL915 Upright Vacuum Cleaner
Vacuum starts and stops when the hose assembly is moved.
Hello, it sounds like you make have a wire loose in your canister. The canister needs to be repair by a qualified repair person due to shock hardzards.
Oct 27, 2015 | Kenmore Canister Vacuum Cleaner,...
My henry hoover wont work
check main cable & power switch, mAY BE FAULTY
Feb 12, 2015 | Hoover Numatic Nacecare Henry HVR200A...
Why does my Kenmore intuition vacuum 31810 Red light stay on ?
Here's a couple options
http://www.ehow.com/way_5513470_kenmore-vacuum-troubleshooting.html
http://www.shopyourway.com/questions/1128413
Jul 28, 2014 | Kenmore Intuition 31810 Upright Bagged...
How do you access the motor and guts of an Aeruslux or Electrolux Canister Vacuum Cleaner
Hi, I can help. Flip the canister on it's back. Remove all crews. Should pull apart from there. If not check around body to see if it's clipped. You may have to pry the sides apart. That will give you access. Be careful and pay attention to where everything is. Good luck.
Jul 22, 2014 | Electrolux Band Aerus Lux Legacy Canister...
How to open the casing - kenmore intuition 116.312
Similar to your Kenmore upright is the canister. Here is a video clip by another with similar issue of trying to open the darn thing up. I hope this gets you closer to solving your problem with the vacuum. If not with a few Kenmore vacuum "search" in youtube I think you will find what you need.
PEACE
https://www.youtube.com/watch?v=s0aaoPzCAcM Kenmore 116 26212690 vacuum cleaner disassembly to motor
Jun 03, 2014 | Kenmore Intuition 31810 Upright Bagged...
How do I remove & replace carry handle?
Refer this issue directly to Electrolux for guidance in replacing the handele.
Jan 25, 2014 | Electrolux EL6988E Oxygen Canister HEPA...
The Kenmore air filter will not turn on.
Check the switch and make sure that it is getting power. You can also disconnect the connectors to the swiitch plug the unit back in and touch them together if that works then you know the switch is bad
Feb 14, 2009 | Kenmore EnviroSense 85501 Air Purifier
Kenmore Progressive Canister Vacuum Cleaner with SWIVEL STEERING SYSTEMTM Red Color 21714 Logo
41 people viewed this question
Top Kenmore Air Purifiers Experts
fordexpert
Are you a Kenmore Air Purifier Expert? Answer questions, earn points and help others
