Question about Brother SE-270D Computerized Sewing Machine
Bottom thread problems
I can't seem to pull up the bottom thread. I checked how I threaded the upper and bottom threads and everything seems right, I am not sure what I am doing wrong!
  • 208 Answers
Make sure that the needle is inserted with its flat side to the back and that the machine is threaded correctly, particularly the take-up lever.
Make sure that you turn the handwheel counter-clockwise (hand on top turning towards you).
Posted on Jun 19, 2009
When I finish to sew the end of string does not lacks it self and when you pull the bottom of the string everything opens
If the upper thread is looping on the bottom of the fabric as you sew, the upper tension is too loose. It could be threaded incorrectly, the upper thread may not be seated in the tension disk properly (be sure to RAISE the presser foot BEFORE threading the upper thread), or the upper thread tension is set too loose.
If you have checked everything and it is still looping underneath, the bobbin tension may be too loose or the bobbincase needs replacement.
Sewing Machine Thread Bunching Up Here Why
Oh You Crafty Gal Sewing Lesson 10 How to Fix Tension on Your Sewing...
Understanding Thread Tension Threads
Dec 20, 2015 | Janome Sewing Machines
My bottom thread is a real mess when I sew. The
I would suggest to replace the bobbin case,
make sure the needle is not in backwards
make sure the needle is not bent
Jul 29, 2010 | Brother BC-1000 Computerized Sewing...
My bottom thread is all messed up i have a rose
Check that it is threaded correctly (both top and bottom) making sure that the upper thread is in the takeup lever. What the needle as you slowly turn the handwheel counter clockwise (toward you) and the needle point touches the fabric (make sure presser foot is down). Is the thread still relatively taunt? If it is loose, the upper thread tension unit does not have enough tension. Check the areas where the thread goes and make sure you remove any loose threads or fluff which could be inhibiting the tension discs from closing over the thread. If the tension unit still is not tightening enough, the tension unit may need to be replaced or the circuit board replaced. If everything is ok in the upper thread area, now look at the bobbin area. With no fabric, watch as the needle enters the bobbin area. Does it go down and the upper thread catch the bobbin thread and pulls it to the surface? Check for anything preventing the bobbin thread from being pulled up to the surface through the needle plate. If you have still not been able to resolve the problem suggest you take take it to an authorized husqvarna viking dealer for service. You can locate a dealer near you by visiting the husqvarna viking website and clicking on the Dealer link on the left-hand side of the page - http://www.husqvarnaviking.com
Good luck.
Jan 26, 2010 | Husqvarna Viking 1
The bottom thread gets all knotted up when I sew... everything locks up and there is a mess of thread on the underside of what I'm trying to sew. help?
The tension in the top thread is controlled by a dial, and the tension in the bottom thread is controlled by a small screw on a spring on the bobbin. The tensions are supposed to be exactly equal in order to make the stitch perfectly in the middle of the cloth. Uneven tension will pull the stitch up or down from there. You can tug on each thread to feel how much tension there is. Often the bottom will get too much tension by just inserting the bobbin upside down. Leave the bobbin door open, and watch the operation. The top thread is pulled down around the bobbin. See if it is getting caught on anything?
Dec 18, 2009 | Singer 3116 Simple
Good Morning: My wife has a Husquvarna Viking 320 Electronic Sew Easy. I have tried to re-work the bobin and the thread through the needle. When she stiches the hem on a pair of blue jeans it stiches...
since you are doing jeans it can be on either side so lets start for the beginning, rethread the top thread making sure that the thread went through the upper tension, second remove the bobbin and make sure to thread it through the lower tension(there is a spot on the bobbin case for the thread to go through for there to be tension on the bottom) if the thread on the bottom pulls really easy by hand like there is no resistance then take it to a local dealer and have him adjust it if it feels like there is a pull do the same with the upper thread put the foot down and try to pull the upper thread(don't break a needle) if it has tension adjust the upper thread tension tighter
Oct 19, 2009 | Sewing Machines
Bobbin unravelling on prolectrix 8 stitch sewing machine
did you put the bobbin thread in the tensioner? that would be the cut in the side of the bobbin case to pull the thread under the tensioner. if not it will cause problems. but if the top thread is looking good then the top thread is the problem, thread the machine with the presser foot up to let the thread into the tensioner, if it looks good on the top and not the bottom it is the upper thread if it looks good on the bottom and not the top it is the lower thread
Jul 29, 2009 | Sewing Machines
Machine locking up after first stitch
Well I'm assuming this is not a 905 Serger. Here are some tips for bobbin problems on a Viking sewing machine:
Check that it is threaded correctly (both top and bottom) making sure that the upper thread is in the takeup lever. Watch the needle as you slowly turn the handwheel counter clockwise (toward you) and the needle point touches the fabric (make sure presser foot is down). Is the thread still relatively taunt? If it is loose, the upper thread tension unit does not have enough tension. Check the areas where the thread goes and make sure you remove any loose threads or fluff which could be inhibiting the tension discs from closing over the thread. If the tension unit still is not tightening enough, the tension unit may need to be replaced or the circuit board replaced. If everything is ok in the upper thread area, now look at the bobbin area. With no fabric, watch as the needle enters the bobbin area. Does it go down and the upper thread catch the bobbin thread and pulls it to the surface? Check for anything preventing the bobbin thread from being pulled up to the surface through the needle plate. If you have still not been able to resolve the problem suggest you take it to an authorized husqvarna viking dealer for service. You can locate a dealer near you by visiting the husqvarna viking website and clicking on the Dealer link on the left-hand side of the page - http://www.husqvarnaviking.com
Good luck.
Jun 29, 2009 | Husqvarna Huskylock Computerized 905
BOTTOM THREAD KNOTTING UP
Good luck.
Sep 16, 2008 | Husqvarna Freesia 425
Brother nx 600 bottom thread pulls out
Either the upper tension is loose or the lower tension is tight. Tighten the upper tension because it has numbers to refer to.
sewman7
Jul 12, 2008 | Sewing Machines
Brother SE-270D Computerized Sewing Machine Logo
80 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
