Question about Nikon COOLPIX L5 Digital Camera
When i push the power button on my nikon coolpix L5 the lens comes out and the screen flashes on then off
When the problem started I pushed the power button on and the green light would turn on for a second but the lens wouldnt come out and nothing on the screen, then i tried to clear the dust changed the batteries, and smacked it a couple times lightly, now when i push the power button the lens pops out the screen on the back flashes on for a split second then nothing, the little green light shut off after about 10 seconds but the lens stay out
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 131 Answers
Sounds like grit in the lens mechanism..... but is it worth enough to get it serviced?
Posted on May 25, 2014
  • 5 Answers
SOURCE: Nikson Coolpix L5 Camera will not power up.
i had someone with the same camera have a problem like yours but it wouldnt turn off and the only way to power the camera on was pressing the power and blue play button. i called nicon and they said try a reset all in the setup menu but this didnt work. i then played for a little longer with it and found if i gentally twisted the body of the camera it would turn on and off as per it should. so i removed the back of the camera ( coution very small screws) and found that the blur control ribbon cable for the top control board had come loose.take something non conductive and not sharp and carfully push the ribbon cable back into is socket. once i had done this everything worked ok.
a few other words of caution while doing this keep track of where the screws come from as they are different lenghts.do not have the batterys in the camera as the flash caps will be charged and if you touch the wrong thing ZAP you could get a nice supprise. and finally when repacing the back of the camera make sure the selector switch for movie , scene and camera is connected right otherwise you will have to remove the back again and fix this issue
i hope this works for you
Posted on May 14, 2009
ericbrunswic
  • 88 Answers
SOURCE: Nikon coolpix s210 Not taking pictures
It sounds like you should try a new set of batteries in the camera. I have a similar camera and the flash is the first to go when the batteries are dying.
I hope this helps,
Eric
Posted on Jan 19, 2009
97F350diesel
  • 1326 Answers
SOURCE: I cannot activate Nikon Coolpix S210 (problem with ON/OFF button)
had a similar issue with my Pentax, it would power on and power back off. Tried playing with it for a while and it never recovered. Chances are its time to replace it. These new electronics are jam packed with lots of mini moving parts and are prone to excessive wear over time. they're are no servicable parts inside them unfortunately. I would try ebay for a reasonable replacement camera.
Posted on Aug 06, 2009
dlundmark
  • 797 Answers
SOURCE: Push on button. Camera turns on, lens pops out.
Most of these kinds of errors come as a result of some kind of impact, sand or dirt exposure, possible water damage, or some other problem with the lens.
There is a possibility that the lens is off track.
Try pulling or pushing (not too hard either way) and see if it may be off track and return it to the correct setting.
Since it is not working anyway, try the above a few times and then test the camera to work right.
I have fixed more than one with similar (off track problems) and they worked good after wards.
Worth a try.
If nothing works, I suggest to sell it (include all that you have with the sale) on a site such as Ebay as parts, or as is repair. It should bring something like $20.00 to $50.00. The LCD is worth something over $15.00 alone. The other parts of the camera has value to those who repair cameras.
Posted on Oct 19, 2009
bullet_okarn
  • 108 Answers
SOURCE: nikon coolpix s210: when i push the
the lens motor that drives the lens too & froth must be changed to get it working properly again, u need to go to the local service center, the will help you out. u can give me your location & i can help u with the nearest service center.
Posted on Apr 08, 2010
My Coolpix L320 was working fine, then all of a sudden got stuck with the lens zoomed all the way out and a message on the screen that says, "Turn the camera off, remove the lens cap, and turn the cam
after changing the battery and gently push back on the lens it should automatically close if not then check around it it must be something stuck in between it
Jan 18, 2015 | Nikon Coolpix L320 Black Digital Camera...
While shutting down after downloading pictures, I
Try going to this page at the Nikon site, and work from there. You might find your answer if you start here:
http://www.nikon.com/about/news/2004/0128_03.htm
Good luck,
-a.
Apr 01, 2010 | Nikon Coolpix 3200 Digital Camera
CoolPix L 18 Problem
It probably can be fixed if you can get to them. Most cameras' lens assemblies are replaced as a unit when they go bad, it's just not cost effective to spend the time to tediously take them apart, repair the problem, and reassemble. You sound pretty mechanically inclined to have fixed the gears, so I would say you could probably pull this off if you try. Good luck, it's not what most people should try at home!
Mar 26, 2010 | Nikon COOLPIX L18 Digital Camera
Nikon Coolpix L5 - 3-4 years old
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Sep 26, 2009 | Nikon COOLPIX L5 Digital Camera
"Lens Error" message in Nikon Coolpix L5
There are a few different things it could be though most likely the lens itself is out of alignment. There are methods you can try to "click" it back into place. First off how long have you owned the camera?
Thanks,
Lee
Sep 14, 2009 | Nikon COOLPIX L5 Digital Camera
Can't access the flash menu on the Coolpix L5.
Carol, did you ever figure this out? I can't access the flash menu either. Email me if you have a solution - jbcleere@yahoo.com
Apr 12, 2009 | Nikon COOLPIX L5 Digital Camera
Jan 10, 2009 | Nikon COOLPIX L5 Digital Camera
Coolpix l5 - SD card won't seat
The Nikon are very good about placing a sd symbol on the door of the memory compartment. The trick is to align the dog ear side of the memory stick with the picture on the door the push down until the stick bottoms out in the slot it should then lock in to place. Conversely to remove it push down again until it un locks.
Dec 07, 2008 | Nikon COOLPIX L5 Digital Camera
Nikon COOLPIX L5 Digital Camera Logo
90 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
