Question about Maytag Neptune MAH5500B Front Load Washer
My flashes nd and there is still water in the tub
  • 6,784 Answers
Check the following areas to address this issue further. in most cases, this will be a failed pump.
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
Posted on Jun 19, 2009
Maytag MAH8700 pumps the water out of the tub but then tries repeated to keep pumping water and will not progess to spin cycle. It will do this and then sometimes (not all) display the nd error code.
Edit your posting to add Make and Model#
Check your manual for troubleshooting tips or search online for your make and model# to find a manual.
Contact the company of your product or a local appliance shop to ask them.
May 12, 2015 | Washing Machines
Why is water leaking back into tub
the issue is ur water inlet valve has no filter nd has trap some filtrate,,,it neesd to loose the four srews , clean replace nd eventually replace the filter which uve misplaced
Jul 09, 2014 | LG WM-2277HW Front Load Washer
Samsung washer ND code and not drain and spin
Sounds like control Board isn't sending voltage to pump. Most likely a control issue.
Nov 03, 2017 | Samsung Washing Machines
Water wont drain from tub error code nd
Leave a comment if you need more help.
Thanks for using Fixya.
Oct 07, 2012 | Washing Machines
What does flashing nd mean
Hello, and thank you for using this service. I'll be helping you with your problem today.
"nd" means "no drain" and because the tub isn't draining, the washer will not open the door for safety reasons. You'll need to pull the washer out, unplug the washer, and remove the back panel of the washer. Then disconnect the drain hose from the drain pump and remove the drain pump. Remove any blockages you find in the pump itself and you should be good to go again. If not, then the drain pump will just need to be replaced.
Be sure to be ready with a wet vac or a log of towels when you disconnect the hoses from the pump because all the water in the tub will come out.
tanks
Jun 20, 2012 | Maytag Washing Machines
My amana front load washer has Nd flashing and won't open door? What does Nd stand for?
The ND error code means NO DRAIN, why it comes up is because the computer thinks that within the normal times it takes to drain the water from the tub it hasnt drained in that time.
Things that will cause it to not drain in the normal time is oversudsing becuase too much detergent was added.
Or something such as lint in the drain pump filter screen restricting the water flow into the pump
Gene
Aug 17, 2011 | Amana Washing Machines
I have a code "nd" that i can not get to clear. it won't allow the machine to spin out some water that is remaining in the tub. How do i clear this code?
Is there any water in the Tub with the ND (No Drain) error code? See the Last part of this post http://www.fixya.com/support/t2209123-code_nd_fav6800aww_serial_number_10
We deal with a stuck pressure switch. You can go into Service Mode and see with no water in the wash Tub do you not make the proper pressure switch transitions as seen on page 16 of the Service Manual. My WAG is a stuck pressure switch with the info supplied
FAV6800A/FAV9800A Service Manual for reference. Sears Parts Direct for reference.
D*ick
Aug 09, 2010 | Maytag Neptune FAV6800AW Top Load Washer
What does "nd" mean on my neptune washer
Hello tana_carney4,
Your in the FAV6800AW forum so I’ll assume your machine type is a FAV6800AW or FAV9800AW. I’m an owner of the FAV6800AW with some hands on experience with the machine.
The ND error code equals No Drain. The microprocessor on the Control Board keeps track of the time needed to receive a Low/Mid Level fill indication from the pressure switch at the start of a tub drain cycle. If that time elapses and the pressure switch is signaling that the tub has watering remaining then you trigger the ND error code. Is the tub empty or is there standing water in the tub with the ND error code?
If the wash tub is empty and you fail out of the wash cycle with the ND error code then I feel you have pressure switch failure, the pressure switch is signaling the Control Board incorrectly. We need to go into Service Mode “Board Input Test “ and check if the pressure switch is signaling a -1 with an empty tub (no water). If rhe pressure is signaling a -1 with an empty tub then the pressure switch is false signaling “Stuck Pressure Switch” you will error out in the wash cycle with the ND error code and the Pressure Switch will have to be replaced.
If the wash tub has standing water in the tub with a ND error code to the console we need to check for a failed drain motor, a drain pump impeller jam/clog. We would go into Service Mode turn the drain pump and listen. Do we hear the drain pump turn on? If so will it pump out 5 gallons of water in about 25 seconds or less as my working FAV6800AW will do? Further troubleshooting will require a DVM to verify that 120VAC is applied to the drain pump, If we have 120VAC at the drain pump motor connections and we don’t hear it turn on we would need to remove the drain pump and check for failed motor or jammed impeller. If the drain pump turns on but we have slow drain out of the drain pump we could would need to remove the drain line from the Sump Cap to the inlet of the drain pump and check for restrictions and possible impeller damage to the drain pump.
The question is do you just want know what the ND error code is?
Do you want to DIY the repair? If not then it would be time to call in a repair service.
Here is the FAV6800A/ FAV9800A Service Manual link.
If your machine type is not a FAV6800AW or FAV9800AW then please disregard my post.
Rich aka dh1200s
Nov 18, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Won't finish cycle, water still in tub, code nd
check the following to address this issue.
2. Water Pump
Jun 19, 2009 | Maytag Neptune MAH5500B Front Load Washer
Error "nd" trouble
Nd, means no drain... a blockage in the drain line from the tub. Access from the back panel, you can remove the hose from the machine and check for blockages... this would be on the tub side of the hose... take the hose loose from the machine and check for blockage at the tub. squeeze the hose to check for blockage within.
take the hose loose at the pump to check for blockage there as well... watch out for water ...be ready to mop... let me know how you do..
May 26, 2009 | Maytag MAH2400A Compact Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
97 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
