Question about Philips 42TA648BX 42 in. LCD TV
Blinking color on screen no picture
Sound works. but no picture on any input. Just continuous blinking colors, I have tried a reset.
    Top Expert:
  • Philips Master
  • 74,136 Answers
Sounds like a panel fault. Contact the authorized service center for Philips to confirm.
Gopakumar Gopalan Google
Posted on Apr 18, 2014
I have a Mits WS-65511 that the picture lighting started to to fade in and out. We still have sound but the picture is not the right color, fussy and lighting is dim. I did reset the TV, no difference. I...
Three basic color picture tubes in tv are getting weak in performance and requires more current to work properly. There is Screen voltage settings that needs adjustment for each picture tube in tv.
Let me know are you familiar with electronics stuff repair and willing to work in live tv?
Thanks.
Jul 03, 2011 | Mitsubishi WS-55513 55" Rear Projection...
My problem is: samsung hl-p5063w. I have a new lamp and it works fine. The fans work all right. The color wheel works well. But no picture, only the screen is black. Low light without image. The timer...
I'm not a tech person, but from what I have learned it sounds like your digital board (input) connections. Try diffrent connections to see if you get a picture.
If you are using a coax cable for your input, try the rca type input. If you still get no picture after trying diffrent inouts, it may just be the digital input board. Again Im not a TV specialist, just sort of informed from the net.
Apr 20, 2011 | Samsung HL-P5063W 50" Rear Projection HDTV
My sony flat screen works but when I turned it on the colors are blue and purple. Picture not clear but sound is ok. Colors are off.
Press "Input Select" on the remote control and select "TV Mode."
Press "Menu."
Press "Enter" to select "Picture."Use the arrow buttons to select
"Picture Setting."
Press "Enter."Use the arrow buttons to select "Color."
Press "Enter."
Use the left and right arrow buttons to adjust the color settings. When you are pleased with the color setting, press the "Exit" button on your remote to exit the menu screen.
Hoped this helped
Mar 18, 2011 | Televison & Video
I suddenly lost the color on the screen and no manual adjustments seem to work to restore it.
I'm assuming that you have tried all the color temperatures, the full color setting, the full tint range and the correct input/colorstream to no avail. The only thing left that you can do then is to try to reset it - Menu, Picture, Reset button on the remote.
If even this has failed then the defect is in the tuner - you will have to call a repairman to replace it.
Oct 15, 2010 | Toshiba TW40X81 40" Rear Projection...
Green light blinks continuously, printer will not print. Has always worked well until now. Cartridges are in place, printer has paper, is connected to power and to computer. Is there a reset?
One or both print head are defective.Open cover put out color cartridge then close cover.If blinking stops replace color cartridge.If blinking continues put out black cartridge and put in color.If blinking stops replace black cartridge, if not stop replace both cartridges.
Sep 29, 2009 | HP DeskJet 3650 InkJet Printer
TV makes humming noise, lamp light is blinking, does not turn on
Your color wheel needs to be changed. Mine just did the same thing. I changed mine, and the buzzing sound went away, however now my picture washes out with light or yellow colors. The darks look green and purple also.
Mar 28, 2009 | Samsung HL-R6167W 61" HDTV
Sony KV-36FS12 Lost Green
Hi!
Five blinks means - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
Please rate this solution as FixYa if found useful.
Thanks
Rylee
Feb 28, 2009 | Sony FD Trinitron WEGA KV-36HS420 36" TV
Static picture or flashing colors pictures wd-52525
HEY AWOOD,THIS SYMPTOM IS DUE TO POWER CAPACITORS GOING BAD IN THE POWER SUPPLY AND THESE CAPS CAN CAUSE A COUPLE DIFFERENT SYMPTOMS,YOURS SEEMS TO BE THE MOST COMMON.IF YOU'RE TECHY ENOUGH YOU CAN REMOVE THE BACK AND GET ACCESS TO THE TWO PLUGS ON THE LITE ENGINE TO TEST (WITH A VOLTMETER) THE 5 VOLT SUPPLY ON I BELIEVE PLUG J19 PINS 1 AND 3.IF LOW THEN REPLACE 6 CAPACITORS ON POWER BD. YOU SHOULD BE ABLE TO SEE IF THEY ARE BAD JUST BY A VISUAL INSPECTION.GOOD LUCK JOE TV
Sep 19, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Philips 42TA648BX 42 in. LCD TV Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
