Question about Schwinn Cycling
Adjusting bicycle hand brakes
The handbrakes on my bicycle need to be tightened as the bike will not stop.
Http://youtu.be/hg6s596PPRY
Posted on Oct 11, 2014
randy54156
  • 55 Answers
SOURCE: Bicycles Brakes Tightening
Are the brakes center pull or side pull?
Center pull would have a nut directly in the center of the brake. Now go to the brake lever on your handle bars and tighten the turn screw where the cable handle is. Keep turning the nut till your brakes grip.
If you have side pull brakes. Then where the cable meets the breaks. Their is a nut that the cable slides through. Loosen the nut and firmly pull the cable till its tight and retighten the nut.
Posted on Nov 08, 2008
  • 9 Answers
SOURCE: Rear Disc brake is rubbingke
I had the same problem with my Hope mono-mini.
I took it into a shop and the guy showed my ruffly what to do.
On the side that the disk is rubbing you need to put a spacer on the bolt between the brake mount and the bike's mount.
If done correctly (or understood what i meant) it will pull the pad away from the disk a little bit and it will stop rubbing.
Hope it helps
Ed
Posted on Feb 01, 2009
  • 71 Answers
SOURCE: rear bicycle wheel won't turn. Brakes are siezed.
Find the arm that hold the cable. Loosen it to the desired tension.please comment if it does not work for you! I can help! Good Luck!
Posted on Jun 11, 2009
  • 1138 Answers
SOURCE: adjust rear hand brake on Mongoose 20 inch bicycle
Here is the perfect site for you:http://www.bikeguide.org/how-to/brakes/brakes.php They're called gyro brakes by the way.
Posted on Aug 28, 2009
  • 484 Answers
SOURCE: how do you adjust bicycle hand brakes
There are two techniques:
The first involves the adjusting barrels and lock nuts on the brake levers, but i prefer to loosen the cable in the brake arm and pull it tighter and reclamp it there.
Hope this helps, feel free to email for further help,
matt
Allrotor13b@gmail.com
Posted on Sep 20, 2009
Handbrake adjustment citroen nemo
Remove the boot around the hand brake or pull it back to expose the adjustment nut and locking nut on the threaded cable end, turn it clockwise to tighten the handbrake cables.
Aug 09, 2016 | Citroen Cars & Trucks
How do I adjust the handbrake on 2003 Kia Carnival
I have not checked a kia carnival but worked on most kia cars. There are two hand brake adjustments. One is at the hand brake lever. open up the hand brake cover and look for the nut adjuster where the end of the hand brake cable is attached to. Tighten up that nut until you find a comfortable hand brake position and the brakes locks.
the other adjustment is found at the rear brake drums. you have to remove the tires and tighten the adjusting nut behind the brake plates. there is a small hole, usually covered with a rubberized plug. remove that plug and adjust the brake with a flat screwdriver.
Oct 26, 2014 | Kia Carnival Cars & Trucks
How to adjust handbrake on2001 mondeo
General advice:All handbrakes rise adjust from under the car,very rare behind the handle lever.Worning:Handbrake adjustment need to balance so u need to know if each back wheel brakes even,in order to see that u may have to jack the car and count the rising clicks on handbrake lever to see at what point the wheel stops (u must rotate the wheel by hand (and maybe ask for a friend to brake),with quite some force.Inspect also the interior component (in the back drum if apply,if on disc there is no need)Empiric :by driving at low speed on even road and handbrake hard,the marks of each wheel on the road must start +/- at the same point.Warning:This is dangerous manouver,the car may drift,do not steer while braking,if not shure,better take it to a dino test.Tip:if u tune eack whell at the max brake open position,the handbrake balance,and from there u can adjust the hight of the lever rise by loosing or tighten the cable.Hope u deal it.Cheers.
Oct 24, 2013 | Cars & Trucks
Brakes need to be tighten
The wound steel cable that connects your brake lever to the brake pads can be adjusted via a screw or nut at the top of the brake pad assembly. Simply loosen the assembly and gently tug the wire end toward the front of the bike tire to tighten brake grip; tug it backward to loosen. Tighten the screw partially to hold the cable in place, test the brakes with the brake lever, and adjust again if necessary before fully tightening. It may help to put the bike on a stand or hold it so that you can spin the wheel, check that the brakes are adjusted so that the pads do not rub the wheel. You can do the same thing with the rear brakes. You will need a small tool to loosen and tighten the brake pad assembly; your household toolbox should have something :)
While you are adjusting the brake tension you should also check the brake pads for signs of wear. If your bicycle brakes squeal, show uneven wear or are perfectly smooth, go to a shop and get a new set! Regular brake maintenance is very important for bike safety.
May 19, 2011 | Cycling
How do I adjust the brakes
This brake mechanism has a Lock/Adjuster nut which holds the brake arms together but it is also to adjust them too.....Just hold the brake unit with hand and break the nut loose....loose enough that you can move each brake pad arm seperately but not to loose.....Then squeeze the arms inward until the pads almost touch the rim then tighten back up...this action moves the pads closer to the rim to stop better faster.....Hope this helps..........Metalpoet..........
Apr 05, 2011 | Pacific International Pacific Exploit...
How do i adjust the handbrake
TO ADJUST HAND BRAKE YOU HAVE TO REMOVE THE CONSOLE.TO ADJUST HANDBRAKE CABLE.ONCE CONSOLE REMOVE YOU WILL SEE A LOCKNUT.LOOSEN LOCK NUT WHILE HOLDING THE ADJUSTING NUT WITH A WRENCH TIGHTEN THE ADJUSTING NUT UNTIL THE DESIRED TRAVEL IS ATTAINED.THEN TIGHTEN THE LOCKNUT.
Oct 01, 2010 | 2001 Kia Rio
Hand brakes are loose and need to be tightened so they will stop the bike. How do I tighten the hand brakes?
loosen the anchor bolt the hold both brake shoes against the wheel rim pull the cable tight and tighten the anchor bolt
Aug 07, 2010 | Huffy Disney Princess 16 in. Girls Bicycle
How do you adjust the hand brake? I can get them
The bolt that attaches the brake to the bike needs to be tightened/adjusted
Nov 23, 2009 | Dynacraft Girls 16" Barbie Bike
The housing of my brakes on the handle bars is loose and keeps moving. how do i tighten it so that it stops moving when i apply pressure on it and/or squeeze the brake lever??
If the screw is all the way tight and still slipping ... try to find a fatter part of the handle bar to mount the grip to. You will probably will not find any such that is convenient for you to continue to use the brake ... remove the grip, wrap some electrical tape around the handle bar, reattach the grip. Tighten it and give it a try.
I hope this works for you
a
Oct 12, 2009 | GMC Denali Road Bike
How do i adjust the brakes on a schwinn stingray low rider bicycle? the front brakes dont grip the wheel enough to stop and the rear is rubbing on one side. thanks
Let us start with the rear. The brake arms will have a small screw located on them near the pivot. You can screw these in to adjust the relation of the pad to the rim. You can also (if that didn't take care of it) remove the brake arm and move the spring's pin to the next hole to make sure it properly clears itself.
The front can be tightened on the brake levers with the adjustment barrel, or, if that is already fully turned out, turn it all the way back in and release the cable at the brake itself and retighten it when you have adequately adjusted the brake there.
Check out Parktool.com's repair help page (located at the top right hand of their homepage) for excellent detailed and illustrated help in bike maintenance.
Hope this helps a little,
matt
Sep 19, 2009 | Schwinn Stingray Chopper Youth Bicycle...
Cycling Logo
57 people viewed this question
Top Schwinn Cycling Experts
Michial Gueffroy
Tony
michael
michael
Are you a Schwinn Cycling Expert? Answer questions, earn points and help others
