Question about Garden
Eng stalls or runs rough under load
Eng starts runs for short or long time when ac cuts in eng runs rough somtimes stalls sometimes picks up and keeps running have changed fuel filter cant find any broken fuel lines
  • 50 Answers
You may have a stuck float or a blocked jet. Remove line from the carburetor and check to see if you have gas flow from the line. When opening the petcock, you should see gas coming from the gas line, if not, check the petcock. If you are not that handy with machines, it's recommended you bring the lawn mower to a certified mechanic. But if you are, the next step would be to remove carburetor and disassemble the float housing. Check to make sure that there is nothing in the float housing (the bowl) that would keep it from working, careful you don't lose or bend the needle. If that is fine, you may want to use a can of compressed air to blow out the jets. Once you have cleared all the holes and cleaned out the bowl, re-install the carburetor and give it a shot. My recommendation to keep this from happening again, is to first put gas stabilizer in tank, and second, when putting mower away for the winter, close petcock and run mower until it dies from lack of gas. Good luck!
Posted on Apr 20, 2014
  • 86 Answers
SOURCE: Briggs & Stratton engine on Murray lawn mower
I always replace the air filter if its a paper element, and even if its a foam element I replace it rather than clean it. That said, engine stumbling is rarely and air flow problem - but it could be, so having a new filter assures no air restrictions.
I would drop the carbuerator bowl. On the bottom of the carb, near where the fuel line comes into the engine, should be a nut. Removing this nut allows the bowl to drop off the carb. Some engines the bowl screws off, you will have to look at the bowl. Often the bowl has sediment or sludge buildup inside. Cleaning the bottom of the bowl can prevent that sludge/sediment from plugging the intake tube. Even on newer mower models this is a common problem, the gas line tubing interior breaks down and the inside of the tubing can start degrading - ending up in the bowl as sludge.
After cleaning the bowl, I would add one ounce of fuel line cleaner to a full tank of fuel and run the entire tank of fuel. This will clean any deposits or "varnish" from the interior carb parts. Doing this and the first step will assure your carb is clean and functioning.
If that doesn't help, then I would look at the spacing between the magneto and coil assembly. If you want to do that I'd like you to write down all the model numbers and serial numbers on the engine nameplate, that way I can give you specific directions.
Hope this helps,
Gregg
Posted on Mar 29, 2009
jj505
  • 195 Answers
SOURCE: Have a Briggs & Stratton lawn mower engine, 4.5
Is Blade new or causeing vibration .Chge blade,
Please rate Thank you jj505
Posted on Mar 30, 2009
#1 Taper
  • 1041 Answers
SOURCE: Engine only runs with choke full on. Dies when off full choke.
Hi Dave, it sounds crazy, but try this. Check your gas cap. It could be clogged, causing a vacuum to occur in the tank, and therefore not allowing the carb. to take on gas. It usually take 10-15 min. for this to occur. The next time you run the mower and it starts to stall out, loosen the gas cap and see if it begins to run again. If it does, then you know that the gas cap is clogged.
Jim
Posted on Jun 05, 2009
  • 32 Answers
SOURCE: Mower idles rough and stalls at times. Also blows
look by the carboreter and there is a little screw with a spring. turn the screw a half turn and try to start it, then try another half turn, and keep expirementing.
Posted on Jun 13, 2009
  • 41 Answers
SOURCE: Briggs & Stratton 4.5 hp running rough...too much fuel
Hi did you squeze excess oil from filter so it can **** air in??
Posted on Aug 04, 2009
97 park ave ultra is hesitatating when I start using the gas as I start an incline mostly but sometimes just randomly an it's getting worse
Engine Stalling Due to Mass Air Flow/Crankshift Position ...
repairpal.com > Problems > Buick > Park Avenue
Buick Park Avenue Engine Stalling Due to Mass Air Flow/Crankshift Position Sensor Failure. This is a verified ... 1997 Buick Park Avenue- 3.8L V6160,000Visitor. Engine stalls ... car runs then stalls and won't start for thirty minutes. Upvote (36).
Buick stuttering Questions & Answers - Fixya
www.fixya.com > Forum > Tags > stuttering
94 Buick Park Avenue that stutters under a light load I have a 94 Buick Park Avenuethat ... Buick Century 97 runs rough and stutters when cold and gas applie Engine runs rough ... I have a 1994 buick lesabre it starts ok but stutters and stalls.
Oct 30, 2015 | Cars & Trucks
Have oc60 diesel eng runs for a while then drops in revs sometime picks back up somtimes stalls then restart
Possible low coolant in AC unit. Sounds like the comressor (A/C) is putting a load on the engine when the the coolant is returning to be compressed after it becomes saturated. Possible air dryer or A/C condensor problem, also.
Apr 17, 2014 | Garden
Stalls after start up, Stalls when braking, then runs fine after a few minutes
Check the ECU engine temperature sensor. If it thinks the engine is hot, it will struggle to run when cold.
Mar 06, 2014 | Volkswagen Beetle Cars & Trucks
My 1996 monte carlo has started cutting out, stalling and i did not run out of gas
what size engine? any repairs lately to the engine? when does it stall? freeway speeds, around town or at lights?
Jan 24, 2013 | 2003 Chevrolet Monte Carlo
2005 caravan stalls when at stoping
Check the compression, all cylinders should be about 125 lbs, If some are off you may have bent some valves when the timing belt broke, the pistons
will hit the valves & bend them, If so, it is best to replace the head
I did this before no fun.
Good luck.
Feb 22, 2012 | 2005 Dodge Caravan
03 windstar cuts out when a/c is turned on
hi
2003 Ford Windstar-this may the idleing amount is too much so which may makes it to idle rough. that means too much of fuel going inside the engine.
Engine stalls- this is because the when the car is off and when AC is on the AC runs in battery. When you try starting the car the starter motor takes power from the battery. it doesnt have enough battery power t o starts thats why it stalls.
Jul 09, 2010 | 2003 Ford Windstar
1996 jeep cherokee sport 4.0 L it will stall
it looks like your engine is having an over rich fuel mixture maybe, thatswhy when you press the pedal to the floor it starts becouse you allow lots of air to help clean the mixture while cranking, also you should have black smoke in the tailpipe until it cleans up and runs fine, i think youre having a leak in one our more injectors you should check them first for proper seal under pressure these is done in an injector test machine, second it may be a defective map sensor these trucks some times have a bad map and dont give a MIL (malfunction indacator lamp) and last but more rare to be is a blocked fuel pressure regulator chek fuel pressure it should be between 38 and 45 psi and it shoul hold these pressure when you turn off the engine if pressure drops fast its injector seal problems or fuel pump check
Dec 10, 2009 | 1996 Jeep Grand Cherokee
Rough, shaky hot or cold starts on W202+short pwr loss mins later
Check the cable near the abs modulator. Some C180, C200 have short circuit from broken insulators
Apr 24, 2009 | 1998 Mercedes-Benz C-Class
RUNS ROUGH STALLS CHECK ENG LIGHT ON
The plug is located at the bottom of the steering column.The fault seems to be the mass air meter though.
Nov 26, 2008 | 1994 Volkswagen Golf
Engine running rough at idle and missfiring when stepping on the gas
either the timing belt is going and that rarely fixes itself.... or buy a couple bottles of gasline antifreeze and put it in your gas tank....other possibility is coil pack.... start the motor up at night and see if you see any arcing from the ignition.
Robert
Sep 28, 2008 | 1994 Plymouth Voyager
Garden Logo
62 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
