Question about Garden
Have oc60 diesel eng runs for a while then drops in revs sometime picks back up somtimes stalls then restart
Start eng runs fine running a ac pack when ac kicks in sometimes it drops in revs and stalls sometimes it picks up and keeps running have changed fuel filter cant see any leaks if ac is not used it runs fine
  • 64 Answers
Possible low coolant in AC unit. Sounds like the comressor (A/C) is putting a load on the engine when the the coolant is returning to be compressed after it becomes saturated. Possible air dryer or A/C condensor problem, also.
Posted on Apr 29, 2014
  • 12 Answers
SOURCE: 22hp intek eng stalls when hot starts and runs
you have an overheating problem with your motor then. take it to the shop and have them check it.
Posted on Jun 30, 2009
  • 55 Answers
SOURCE: I have trouble with my Masport mower to keep it
you have a carberator problem. it needs to be rebuilt. first try drain gas and put new gas.
Posted on Dec 06, 2009
  • 1114 Answers
SOURCE: I have a murray 4hp that runs 15 sec per prime then stalls.
First. try using Carb Cleaner from spray can to clean carb throat, and putting Carb Cleaner in fuel tank.
If this does not work-
Removal of Carb is probably needed. Sounds like Carb is clogged and needs to be cleaned.
If this is a Briggs engine and the Carb sits on top of the fuel tank, can be that the pick up tube from tank to carb is clogged.
Posted on Jul 12, 2009
  • 18 Answers
SOURCE: kohler magnum 18 engine starts cold fine. the
01 Sounds like it is running out of fuel because it wants you to choke it to get more fuel.
02 Might have a restriction in a fuel line. Disconnect at carb and see if there is a good flow of fuel.
03 Loosen the fuel tank cap and see if the same thing happens. Cap might not be venting.
04 Any black smoke from muffler?
Posted on Apr 18, 2010
SOURCE: I have a honda convertable mover HRT2162TDA
Perhaps its on the engine - of the lawn mower
Posted on Mar 08, 2011
Eng stalls or runs rough under load
you may have a stuck float or a blocked jet. Remove line from the carburetor and check to see if you have gas flow from the line. When opening the petcock, you should see gas coming from the gas line, if not, check the petcock. If you are not that handy with machines, it's recommended you bring the lawn mower to a certified mechanic. But if you are, the next step would be to remove carburetor and disassemble the float housing. Check to make sure that there is nothing in the float housing (the bowl) that would keep it from working, careful you don't lose or bend the needle. If that is fine, you may want to use a can of compressed air to blow out the jets. Once you have cleared all the holes and cleaned out the bowl, re-install the carburetor and give it a shot. My recommendation to keep this from happening again, is to first put gas stabilizer in tank, and second, when putting mower away for the winter, close petcock and run mower until it dies from lack of gas. Good luck!
Apr 17, 2014 | Garden
1990 Buick Park Ave.
clean the idler on the intake and also clean the throttle sensor, it would also be best to change the air filter and clean the maf sensor. Idler does more than just idle vehicle it controls low revs, and drop down from reves. throttle sensor tell ecu what air to add to the fuel. and the MAF tells ecu how much air is coming into the intake. also check for broken cracked vacuum lines.
Jul 17, 2017 | Cars & Trucks
1992 chev lumina 3.1 eng. cuts off intermittently. sometimes when driving down the highway and others when idling around a carry-out resturant. Put in neutral and it starts back up. I have replaced the...
DO you have any engine codes still remaining? IF car restarts right away its gonna be tricky finding out what is dropping out. Engine codes are the best clue to start the hunt for problem. From experience however, I have had a few of these come in for same symptom. There are two wires that run from Ignition module/coil pack to the crank sensor, insulation falls off and they melt to each other or to hot engine, intermittent short disruption of signal, hence car stalls whenever wherever and restarts right away.
May 11, 2011 | 1992 Chevrolet Lumina
Jeep liberty 2002 3.7when starting cold starts-stalls unitl hot
Check the temperature sensor feeding the ECU and O2 sensor.
Apr 12, 2010 | 2002 Jeep Liberty
Stalling
does it have a fuel pump? It could be going bad.. if not, it could be a bad battery...but since it looks like a 2008 its doubtful and could be just loose or dirty connections in the battery circuit.
Sep 14, 2009 | 2007 Yamaha V Star 1100 Classic
My !995 Cherolet Truck Turbo Diesel will stall going down the road or just idling but will always restart. Changed glow plugs, fuel filter, air filter. Service Engine light will come on and it will run...
Pick up a copy of Haynes Diesel Engine Repair Manual, Part # 10330, at your local auto parts store. It has an excellent diagnostic section, check page 1-44. It's a must have for a diyer with a diesel motor. It costs about $20.
Jun 25, 2009 | 1995 Chevrolet C/K 2500
Isuzu trooper engine stops while driving
If its the 3.0 diesel it could be the rail oil pressure sensor starting to pack up .
Jan 21, 2009 | 1999 Isuzu Trooper
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
