Question about Samsung 40" AudioBar w/ Wireless Subwoofer HW-E450
Samsung HW-E450 subwoofer not auto linking
My samsung HW-E450 soundbar with was working fine for about 3 months. But, now it is not auto linking with the subwoofer. It flashes the message "check subwoofer". I have to reset the subwoofer and link it manually. But, only works until the unit is turned off. Next time, same issue. I am using Anylink with HDMA ARC connection and it turns on with the TV. I even tried turning off Anylink. Problem didnt go away. What is possibly wrong with my system?
SOURCE: We bought a Samsung Soundbar x810 but the
Purchased a x810 & everything tests out fine except TV signal sounds from cable box. We have the Comcast cable box connected to the 50" Samsung Plasma TV hooked up to Samsung x810 Soundbar all using HDMI cables. But we are not getting cable shows sound through Soundbar. Please advise
Posted on Dec 31, 2009
SOURCE: System turns off by itself
My unit said "protection", "goodbye" so I opened it up and found a capacitor to one of the speakers had blown, right by the fan. It's a 35 cent part and a simple solder job. The hardest part was getting the face plate off the dvd tray so I could get to the circuit board.
Posted on Oct 28, 2010
taran_2005
  • 10515 Answers
SOURCE: Samsung HT-Z310 Theater System. The system was
Try unplugging the unit for 60 minutes, then plug back in and try it again. This will reset the processor and hopefully the unit will operate normally. Check all the speaker wiring for shorts, make sure they're also not touching the chassis of the receiver, or are not otherwise pinched or frayed. If all looks well, try disconnecting all the speakers and cycle the power off, then on again.
If it power up, try connecting the speakers one at a time until one of them shuts the receiver down. Check this speaker with a multi-meter and make sure it is reading between 4-8 ohms.
If not, the speaker may be blown and is causing the receiver to see a short and therefore power down. The "Protection" will stay lit because of a short inside the unit, and is protecting the rest of the components for further damage. It will automatically disappear once the condition is fixed.
Honestly though, if this is happening already, I would exchange the system as soon as possible or if you have an upgrade option, see if you can get a Philips, or Samsung system as they have better reliability in general based on what I've seen and read.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Nov 14, 2010
jdvillanueva
  • 2098 Answers
SOURCE: I have a HT-TZ315 Samsung
Hi guythomas,
Protect is an error code for short and overload. To isolate where the fault came from use only the DVD player(built-in) while disconnected all inputs(PS3, TV etc.). If the symptom didn't appear, high chance that it came from bad cable connectors from your inputs. You have to change the inputs with a new cables, old cable may have an internal shorts due to frequent bending or pulling which trigger the protect error code.
If the symptom still there after disconnecting the inputs from the unit, disconnect now the speaker while playing again the unit(play it without the speaker's connected). If the symptom didn't appear, the trouble is in the speaker loaded to the unit. You have to isolate them one-by-one by connecting it one at a time. Note : turn off the unit before connecting the speakers.
If the symptom still there, the fault is in the unit itself. This is caused by either faulty power supply which is gone to out-of regulation due to faulty parts(mostly the electrolytic capacitor) or the audio Output circuitry. This is quite technical and need to check by a qualified technician, I would advice you to send it to repair shop to troubleshoot the problem.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Posted on Mar 23, 2011
  • 294 Answers
SOURCE: Samsung home cinema wont turn on
Sounds like it's stuck in it's power saving mode. If you've tried reset, checked all the connections, and kicked out the plug for a Cold Reboot and it's still no go, open the back, spit in it 3 times and hit it with a rock - or take it to a TECH because you've already done ALL that you are capable of, or you'd already know that.
Posted on Jan 25, 2014
When i turn the bar off it automaticly comes back on right away
Samsung HW-F450 2.1 Channel 280-Watt Soundbar
www.amazon.com/Samsung-HW-F450-Channel...Sou...
Amazon.com, Inc.5) If you use sound share to connect samsung tv to sound bar, it uses bluetooth. I dont know if ... The subwoofer is wireless though it requires power connection.
Amazon.com: Samsung HW-J550 2.1 Channel 320 Watt ...
www.amazon.com/Samsung-HW...Channel...Soundba...
Amazon.com, Inc.
Rating: 4.5 - ‎104 reviews
Sony HT-CT370 2.1 Channel 300W Sound Bar with Wireless Subwoofer, Bluetooth, ...Samsung HW-J650 4.1 Channel 320 Watt Wireless Audio Soundbar (2015 ... 2.1-channel sound system with 320 watts of total power. .... bar away from the TV, there's not gonna be a lag or cutting off of the signal. .... Right To Your Door.
Samsung HW F450 Sound bar Problems with arc connec ...
? 5:25
https://www.youtube.com/watch?v=e46odUZ71tE
Aug 4, 2013 - Uploaded by DUGLESSM
Samsung HW F450 Sound Bar hdmi hook up. ... How to connectSound Bar to TV, Blu-Ray Player, DVD ...
Question about new Samsung HW-F450 setu
Jan 05, 2016 | Samsung HW-F450 2.1-Channel Soundbar...
Does the Samsung UN50f6300af smart led tv support the Samsung Wireless audio soundbar HW-H450?
Because your TV is not Bluetooth-enabled and you are trying to connect it to a Bluetooth-enabled soundbar via Bluetooth. There are other ways to connect your TV to the soundbar:
1. analog AUDIO OUT (L/R) of your TV to the AUX IN on the soundbar (use a 3.5 mm.-to-RCA audio cable).
2. Optical OUT on your TV to Optical IN on the soundbar.
3. HDMI port to HDMI port (this may not work if your TV is not ARC compliant you have to try).
You get better sound quality with option 2.or 3. (if this one works for your TV)
Here is the link to download the soundbar's User Manual for help with the connections:
http://downloadcenter.samsung.com/content/UM/201411/20141114104022428/HW-H450-ZA-1114_Bookmark.pdf
Jan 05, 2015 | Samsung 2.1 Dolby Digital Wireless...
Hi, I have a hwh450 soundbar, I cannot get any volume to TVs, the tv is telefuken
Here is a link to your product description. When you get to the web page, click on the "Manual" tab to read the user's manual to find out how you can connect your soundbar to your TV.
HW H450 Wireless Audio Soundbar Samsung Home Audio
Jan 04, 2015 | Samsung 2.1 Dolby Digital Wireless...
Samsung HW-FM45C 280W Soundbar with Wireless Subwoofer and HDMI Cable Samsung Users Manuals
Samsung HW-FM45C Crystal Surround Air Track (Active Speaker System) User Manual:
copy and paste this link in your internet browser to see:
http://downloadcenter.samsung.com/content/UM/201410/20141007150930882/[HW-FM45C-FM45-ZA]AH68-02647A-08ENG-1006.pdf
Nov 17, 2013 | Cell Phones
The blue light still continues to flash
Push in and hold the switch on the back of the subwoofer until the light starts blinking fast. Then, with the soundbar power turned off, hold the mute button on the remote. "ID SET" should show up on the display. Then turn on the soundbar, and the subwoofer should link to it.
Oct 31, 2013 | Samsung 40" AudioBar w/ Wireless Subwoofer...
How can I do the factory reset on my hw-e450 samsung soundbar .
Go to your phone's app menu, then click on settings, then click on your privacy tab, then scroll to the bottom and click on the factory data reset tab and follow the instructions....
I hope this works....
May 15, 2013 | Cell Phones
Samsung 40" AudioBar w/ Wireless Subwoofer HW-E450 Logo
82 people viewed this question
Top Samsung Audio Players & Recorders Experts
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
