Question about InFocus ScreenPlay 4805 Multimedia Projector
Projector lights up, but only half of the picture is clear, the other half is obscured, there is a (yellowish) line in about the middle. Left side of that line is projected but behind a dark veil.
We found the problem after a shift of venue. The projector was taken down from its mounting, stored and then put up in the new place. It was also mounted when building alterations were happening and then cleaned out with compressed air.
  • 1 more comment
  • mickeym99 Apr 17, 2014
    Hi Leonie Rousselot, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
    Was there anything on the projector bulb itself?
  • Leonie Rousselot
    Leonie Rousselot Apr 17, 2014
    no, there was nothing on the bulb, even tried out another bulb.
  • Leonie Rousselot
    Leonie Rousselot Apr 18, 2014
    Thank you all for your efforts. We tried overscan, tracking, phase, horizontal position and vertical position, but all those things only moved within the projected field but still has this overlaying dark veil that doesn't move, about half the screen, vertical.
SOURCE: Faded Black Strip on Side of Projection
I had a similar problem with my InFocus LP600 although my black stripe was straight up and down. I am guessing this is caused when the unit is bumped or dropped. This is not an easy fix unless you have a lot of experience with small tools and parts and you may need an extra set of hands. I found some tiny alignment screws under the lamp cover and hidden beneath a peel-off 0.5" x 2" black plastic strip. The screws are located between the bulb assembly and the main projection lens and are oriented 90 degrees apart around the light projection path. The trick is in getting the projector to temporarily function with the lamp cover off -- it has an interlock tab on one edge that pushes on a microswitch when closed. We turned the projector upside down but raised on some slats for heat dissipation, gently held the interlock switch in with a small screw driver, and plugged in the power cord. After pushing the power switch to get the image, I adjusted the tiny screw that is angled towards the front of the projector and the stripe dissapeared! Since your stripe is angled, you may need to adjust both alignment screws. The screw heads are very tiny torx bit types but I was able to use a 3/64" (.05") allen (hex) wrench that came in a set of cheap jewelers type tools that are widely available. Be very careful while operating the unit with the lamp cover off as there are very hot surfaces and exposed wiring.
Posted on Dec 05, 2007
SOURCE: White vertical line on left side of screen
I had a smililar problem after taking it apart i realised that i had screwed my mount skrews into the video main board and cracked it along with a few soldered wires, if you havent done any physical dammage to it try a firmware upgrade
Posted on Mar 06, 2008
SOURCE: infocus lite pro 720
Sounds like the LCD inside is dying and you're losing pixels. Bummer.
Posted on Sep 26, 2008
projdoc
  • 2237 Answers
SOURCE: upside down images
the projector will project 4 image configurations: front, rear, ceiling front, and ceiling rear. go into the menu, under settings, and change it from ceiling to front.
Posted on Jan 11, 2010
projdoc
  • 2237 Answers
SOURCE: The projector was previously ceiling mounted and
there are 4 projection choices: front, rear, ceiling front, ceiling rear. go into the menu, settings, and select front.
Posted on Jan 15, 2010
It maybe a filter problem go through the steps you took when installing the new bulb and check all then test.
Thanks J
Feb 03, 2008 | Toshiba TLP S30 Multimedia Projector
Viewsonic PJ1173 displays yellowish pictures, dont know wat to do
I presume that the problem started in the middle of the picture and has gradually got larger as time goes on.
It is most likely the blue organic polariser/filter glass plate that passes the blue light into the blue lcd panel.
If you were to take the cover off ( with the power disconnected) and check inside the optics area, you may see the filter burnt from long use on high brightness levels.
Either try and get a replacement polariser or buy a second hand PJ1173 cheaply on ebay and replace that part.
Mar 23, 2011 | ViewSonic PJ1173 Projector
Yellowish green picture hitachi cp x328
one of your primary colors are missing could be due to the cable (ck pin if bent) or ck the pin on the projector.
Jun 01, 2010 | Hitachi CP-X328 Multimedia Projector
X2 projector A somewhat irregular vertical line has appeared near the middle. A slight rainbow affect at the line, right of the line gets progresively darker. The blank screen is normal. The projector is...
this projector does not have lcd's. it has a colorwheel and a light tunnel. the light tunnel has probably collapsed and needs to be replaced if you have distortion in the middle of the display. if it were to one side or the other or a the top or bottom it may have been adjustable. But wiith it being in the middle, I'd have to say you needed a new light tunnel.
Mar 12, 2010 | InFocus SP-LAMP-018 Projector Lamp for X2,...
Dark in middle , clear in upper and middle left corner
your light tunnel has collapsed and needs replacing. you can get the part and do it yourself, or you'll have to send it in to an infocus authorized service center. try av solutions in ny. they're pretty good.
Nov 02, 2009 | InFocus ScreenPlay 4805 Multimedia...
Partial bit of the projection obscured
the light tunnel has collapsed and needs to be replaced.
Oct 16, 2009 | BenQ MP620 Multimedia Projector
I have a InFocus 4805. Half the picture is darker
Your light tunnel may have collapsed. This is made up of 4 tiny rectangular mirrors glued together to make a tunnel.
Sep 26, 2009 | InFocus ScreenPlay 4805 Multimedia...
Partial picture
Your light pipe has collapsed
Aug 22, 2008 | InFocus LP 600 Multimedia Projector
Lp70+ display shows a solid black vertical line
the light tunnel is either collapsing and blocking the light going through it (and needs replacement) or the vertical/hoizontal adjustment of the tunnel. if you take the lamp out and move the colorwheel (with a pencil eraser) to the clear section, you should be able to see a square through it. if part of the square is blocking the middle, the tunnel needs replacing.
by the way, on some projectors the light tunnel is called an integrator rod.
Jun 17, 2008 | InFocus LP70+ Multimedia Projector
InFocus ScreenPlay 4805 Multimedia Projector Logo
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
