Hi
Appreciate your advice to resolve this problem. I have recently bought a hands free kit. Once plug into the hands free jack of my walkie talkie, I can used the hands free kit without any problem. But now the problem is that after removing the hands free kit from the jack, the speaker on my walkie talkie will not turn back on...... How do I go about to get the speaker mode switch on again.
Thanks
It would seem that this is a problem with the contact/switch of your Motorola T5700. When a headset, ear piece or external speaker is plugged in, an internal switch transfers the connection from the speaker to the external. This is better illustrated in the image below.
Initially, you can try an electronic contact cleaner. If that doesn't work, you may have to open the unit and manually scrape off any corrosion from the contacts/terminals or slightly bent it to improve contact.
Hope this be of some help/idea. Pls post back how things turn up or should you need addition al information.
Good luck and kind regards.
