Question about Gaggia Expresso Machine
Saeco aroma dead
Does not work
I have a saeco aroma coffee machine that will not turn on.. This machine has only two thermostats and no reset button visible. Could there be one inside the boiler or should I keep looking?
The Saeco Brand is under the Philips umbrella of companies. The Aroma line is not considered user serviceable beyond descaling and cleaning. However, most devices that heat water tend to have a fusible link somewhere in the power circuit. If you're already poking around inside, trace the power connection (obviously with the machine unplugged) through to the heating elements, sensors, etc. You might find a small "bit" that looks scorched or burnt.
Otherwise, it might be good to contact Saeco and see if there's an authorized repair center near you. The Aroma is definitely pricey enough not to just dump and replace like an old Mr. Coffee.
Jan 04, 2017 | Saeco Coffee Makers & Espresso Machines
No steam on saeco aroma redesign
Hi
That is probably you steam thermostat. Its a 127c thermostat.
Oct 27, 2009 | Saeco Aroma Espresso Machine
Saeco how to reset
called saeco helpdesk and with their assistance found the reset button inside the machine (open the top with a screwdriver). there are three termostates. on the middle one there is a button. when you push it you hear a metallic sound. then you have to close everything and put it on again.
how to avoid this problem: it is important that there comes no air into the heater. So you have to watch the water supply carefully and leave the air out from time to time.
Sep 16, 2009 | Saeco Aroma Espresso Machine
How to clean the saeco aroma ??
Buy an espresso machine descaling agent (they come in packets, and you can get them all over the internet), and follow the instructions that come with it. Do NOT use vinegar like you might use on a drip machine.
Feb 09, 2009 | Saeco Aroma Espresso Machine
My Saeco Aroma Expresso machine has water leaks
I think you have to replace the gasket in the machine where the portafiller fits on the machine.
Make sure your filter is clean before you replace any gasket.
/Mirran
Aug 22, 2008 | Saeco Aroma Espresso Machine
Saeco aroma won't turn on, I tryed different plugs where appliances work.
Try to reset the thermostat.
Take off the water tank, now you will see two screw, one in each corner. Take off the top, now you will see the boiler.
There are one thermostat with a pin in the middle, push down this.
Put the top on again and the screw.
Hope this will help you.
Jul 15, 2008 | Saeco Aroma Espresso Machine
Coffee Makers & Espresso Machines Logo
18 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
