Question about Intermatic Hardware & Accessories
Clicking and on off flashing when light should be on
Electronic 7-Day In-Wall Time Switch
  • Intermatic Master
  • 5,089 Answers
Show how to set the itermatic et821c
Following link has manual for Intermatic ET8100 series
Choose astronomic dawn-dusk timer -or- 7-day programming
http://waterheatertimer.org/Intermatic-ET-series-timers-and-manuals.html#ET8000
be sure to install two AAA batteries in compartment located on front just below the buttons.
Also reset the timer prior to programming ... and this will clear any conflicts or prior programming.
Timer default voltage is 120 volt AC. Choose 208-240-277 volt by moving selector switch located on back of timer.
Gene
Water Heater Timers Save Money
Jan 17, 2014 | Intermatic ET8215C- 7-Day Electronic...
Ei600 wc back light is off
Back light? Do you mean the display?
The battery-powered ST01C and Ei600 series timers have LCD display that does not light up.
The screen is not lit because that would deplete the CR2 12-volt battery.
The following link shows the timer with a lit display, but the lighting effect was photoshopped.
http://waterheatertimer.org/ST01C-program.html
Oct 11, 2012 | Intermatic EI600WC - In-Wall Decorator...
Where can I buy the Aube 7-Day Programmable 40-500w timer
You might be looking for T-1032 or T-1034 500watt timer
Identify model number on following link, and then google-search that specific model.
Link to instruction manual appears for each timer.
http://waterheatertimer.org/Aube-timers-and-manuals.html
Honeywell Aube in-wall timers can be used for single-pole or 3-way applications.
Look at instruction manual carefully for 3-way wiring.
Timer can be used for incandescent, halogen and CFL with minimum wattage requirement.
Since Aube timers have internal battery, they cannot be exposed to freezing temperatures or high temperatures.
Sep 28, 2011 | Aube Technologies Aube 7-Day Programmable...
I WOULD NEED SOMEONE TO TALK ME THROUGH IN PERSON , HOW TO PROGRAM THE TIMER FOR 8AM TURN OFF AND 8PM TURN LIGHT ON EVERY DAY OF THE YEAR - THE SAME TIME ...
If you want someone to talk to you, you will have to pay for phone help.
Here are the simplified instructions.
Press Mode to step thru various options, you only need to get to CLK.
Then set the hour, minute and day of the week first.
If you want the timer to go on & off at the same time for 7 days, you must program 7 times.
Good luck, Gary
Setting the Time of Day
Press MODE to go to the Clock (CLK) settings. The display will flash with 12:00 AM.
Press HOUR+ to stop the flashing.
Press HOUR+ and M+ to set the current time in hours and minutes.
Make sure that AM and PM settings are correct.
Note: The day of the week is shown at the bottom of the display. If you have not programmed the calendar settings,
be sure to also set the current day of the week while programming the current time. To do this, press DAY until the
correct day of the week is shown. The CLOCK settings are now complete.
Press MODE to go to the first PGM screen. See Fig.9
Use DAY, H+ and M+ buttons to set the days, hours and specific times that you would like the timer to turn ON.
(NOTE: Be sure the word ON is displayed when setting the ON time.)
Press NEXT ON/OFF to program an OFF time.
Repeat the same steps for all 7 ON/OFF operations, if required.
Aug 29, 2011 | Intermatic Inc. EJ500C Digital Wall Switch...
I do have and Intermatic ET724 timer and it has stopped working. I don't think it works with battery as it is attached to our bathroom light switch . any luck to fix it? or it is time for a new one??
That's a good old timer.
Grasslin ET724 in-wall timer is no longer available.
http://www.amazon.com/GRASSLIN-ET724-Grasslin-Et724-Electronic/dp/B000BHCFT6
There are several programmable timers on the market.
Intermatic EJ500 is simple to install and program. Works on battery but is for incandescent light only, not for fans.
http://www.amazon.com/Intermatic-EJ500C-Indoor-Digital-Switch/dp/B000E8VAIO
GE 15071 from Home Deport is inexpensive replacement and works with fans, lights.
Needs no battery. Uses electric circuit to operate clock.
http://waterheatertimer.org/GE-timers-and-manuals.html#15071
More timers:
http://waterheatertimer.org/Programmable.html
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you via e-mail while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 20, 2011 | Intermatic ET724-A-CS - 24Hr. and/or 7-Day...
I am an electrician and my client wants me to reprogram the digital timer (Intermatic) I don't know the model # but it looks like the one on the previous page. Probably the most popular digital wall timer...
Below are links to digital timers to help identify your timer.
Manuals for each timer appear on page.
Programming takes patience, which might be why your customer wants you to do it.
And these 1-year warranty timers go bad, and then timer will not reprogram, which may be another reason why customer wants you to do it.
Intermatic EJ500 and ST01C are battery operated, and will not program if battery is low.
Aube has rechargeable battery that is not replaceable, and this timer will not program if battery is bad.
Other timers shown below have clocks that operate on 120V circuit and require white neutral before display lights up.
Generally each programming is same: You set current time. Some timers you set daylight savings time. Some timers are 7-day, and some offer dusk-to-dawn. For 7-day, you set event1 ON and then event1 OFF for up to 7 programs. You choose the days for each event to operate. Before programming, make a schedule so there are no overlaps or conflicts in programming.
With Intermatic EJ500 and ST01C, event1 is the ON event and event2 is the OFF event, up to 40 events.
Add a comment if you hit trouble spot when programming.
Also fixya offers live phone support for a price.
Intermatic EJ500 with 7-day or dusk-to-dawn
Programming remains in memory forever, so you may only have to re-enter current time.
http://waterheatertimer.org/Flipdown.html
Intermatic ST01C with 7-day or dusk-to-dawn
Intermatic EI500 7-day
http://waterheatertimer.org/Programmable.html#EI500
Aube timers are either dusk-to-dawn or 7-day
http://waterheatertimer.org/Aube-timers.html
Utilitec 0192773 with 7-day and astro dusk to dawn
http://waterheatertimer.org/Program-wire-Utilitec-0192773.html
Utilitec 0141224
http://waterheatertimer.org/Program-wire-Utilitec-0141224.html
GE 15071 - 15086 in-wall timers: one has daylight savings time
Woods 59018 in-wall
http://waterheatertimer.org/Woods-timers-and-manuals.html
Tork SS720 in wall:
http://waterheatertimer.org/Tork-consumer-timers-and-manuals.html
Dec 17, 2010 | Intermatic Inc. ST01C Digital In-Wall...
Utilitech 7 day timer, just wired it in and when I manually turn on the lights that they are hooked up to they flash repeatedly and timer makes clicking noise?
Try switching the red and black wires
I think your wiring is wrong
Did you replace a switch that has 3 screws, a 3-way switch?
Utilitec timer can only replace switch that has 2 screws, a single on-off switch.
For 3-way switch, you need Aube T1032 or T1034 (sunrise-sunset)
I just bought a couple of the Utilitec timers but haven't had chance to wire them up for testing
When I tested ST01C & EJ500 timers, discovered that wrong wiring causes lights to blink
If you need to see instructions larger:
Instruction sheet offers no troubleshooting steps
There is no website that claims Utilitec timers
These timers are made in China
Oct 09, 2010 | Intermatic Inc. ST01C Digital In-Wall...
Bought an intermatic model EI600 wall switch timer to use with gfl outsidelights. black green, blue and red wires from the back. Went black to black, green to ground, red tored and blue to white in...
That is a three way timer. There is no wire that the white wire gets hooked to. The black is the hot, the blue sends power to the device, and the red goes to a switch that connects it to the blue wire essentially. Here is a PDF of the directions, including wiring diagrams.
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/ei600c%20-%20english.ashx
Mar 06, 2010 | Intermatic EI600WC - In-Wall Decorator...
Hardware & Accessories Logo
Top Intermatic Hardware & Accessories Experts
Gene Haynes
Jay Finke
Jay Finke
Steve
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
