Question about Hayward Pool Products Pool & Spa
Value position to heat pool
Bought a house with Hayward pool system. I think it is aquadyne and an air spa but not sure. The controls to turn spa on are valves and the heater is a Hayward that has standby spa and pool. I know how to heat spa and turn spa on but not sure how to heat pool. Do I just change settings on Hayward heater to pool or do I have to turn the valves as well?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 44 Answers
Turn the valves so ALL the water goes through the heater and back to the pool
Posted on Apr 20, 2014
Testimonial: "Ok I get that but which way do I turn the jandy valves to make that happen?"
  • Kev McCauley
    Kev McCauley Apr 21, 2014
    the pipe that is on the handle side of the valve is off, wich ever way the longer part of the handle is over is the line that is off,
  • 11 Answers
SOURCE: I have a Hayward H series spa/pool heater. It will not light.
IF stands for ignition failure, one possible cause is that the two sparker prongs are not spaced properly, i have seen this before several times. The correct distance for them to be spaced apart is the width of two quarters side by side... not like this....OO, the other way so the are flat. To access that you have to take out the heat exchanger, which requires unhooking high limit switches in the back, unhooking the pressure switch, thermostat wire, and plumbing...just remember where everything goes. Before you do that though check this simple thing...there are a number of brass orifices that shout gas to the burners, use a 7/16 wrench to take off the one that is to the extreme left, which is on the igniter side of the heater, inspect the orifice to see if there is blockage, like a spider web or something. If it is blocked, clean it out and also look down the burner itself to see if it is free of blockage. And because we all make simple mistakes.......make sure the gas is on.
Posted on Jan 08, 2009
  • 128 Answers
SOURCE: minimax pool heater cuts out at 91 degrees when remotely set for
Check the temp reading on the heater. It is probably set at 91...heater control should be set to 104
Posted on Aug 30, 2009
  • 366 Answers
SOURCE: MIni-Max 400 heater cycling
sounds like you may have a water chemistry problem more than a heater problem. High pH coupled with the heat of the exchanger in the heater will allow the calcium in the water to precipitate and scale the tubes of the exchanger. Make sure your water is balanced, pH 7.4-7.6. Water balance factors include pH, total alkalinity, calcium, TDS, and temperature. Use the langlier saturation index to determine your water balance. If your water is balanced, you may have a bad thermal governor. If you hear the heater water hammer and bang around and then shut off, you definitely have a scale buildup in the heat exchanger tubes. Hope this helps...
Posted on Sep 17, 2009
  • 5 Answers
SOURCE: I have Jandy RS4 system with 4-button poolside
Pull the cover off the control panel. You will probably find a button which would be accessible from outside the panel with a paper clip or pencil but is unlabeled. On the board itself by the button, in small letters it should say "reset". Push the button and see what happens.
Posted on Oct 09, 2009
  • 4 Answers
SOURCE: my hayward heater gives a LO error when trying to
One of your limits is not working or not wired up. An easy way to check the limits - Water pressure switch, Hi limits, air pressure switch all of which have 2 wires going to them. Unplug one item and connect the 2 wires together ( paper clip works fine ) Then retest, if problem does not go away remove paper clip and reconnect wires and move to the next limit. The limits are located in the black plastic header. Always make sure water is flowing through the heater at all times while checking the limits.
Posted on Mar 01, 2010
Water in the air lines
Swimming Pool and Hot Tub Spa Heater Operation ...
www.poolandspa.com/page811.htm
In a pool and spa heater, the burner is typically located in a heater's ... Heat loss, The natural drop in water temperature as heat is transferred to the surrounding air. ....Terminals 1 and 2 are the neutral and positive lines from the pilot generator ...
[PDF]SERVICE & INSTALLATION MANUAL - Hayward
https://www.hayward-pool.com/.../UniversalH-seriesLowNOx-HxxxFDS...
heater and to all metal parts of swimming pool or spa, and to all electrical equipment,... stream of water (not air or air and water) is discharged. ...... Unplug the in-line quick connect on the red wire in the heater wire harness, and connect the.
Jan 13, 2016 | Pool & Spa
Is there a remote thermostat control for the hayward comfortzone? if so where can i get one of these?
its on the main board if using a system 3 wire use pool spa and common see which wires go to which on sytem board put pool temp at desired temp then same with spa temp if jandy system go to pins 1 and 2 on long plug on top of board then go to pool and com at heater if jandy turn heater all the way up RS sysyem will govern heat
Apr 01, 2014 | Hayward Pool & Spa
Aquadyne pool controls
You can as long as you don't exceed the power specs for the controller.
Aug 04, 2013 | Hayward Pool Products Pool & Spa
How do I turn on the heat and the spa in the pool?
You must first make sure the filter pump is on and running (primed). If you have a pool spa combo, you will need to turn on the heater by making the desired temperature higher than the current temperature. This is a call for heat. You must then move the suction and return valves to **** and return to the spa. This is accomplished either by moving the valves manually or by putting it into spa mode if you have a control system. You didn't say whether or not you have a manual or automatic system.
May 18, 2010 | Hayward H Series Pool & Spa Heater...
Heater reads spa water 15 degrees higher than it is
if a 3 wire system put pool at temp desired and spa at 104 if 2 wire to firemans switch run heater all the way up to 104 the system will control the temp
Feb 22, 2010 | Jandy AquaLink RS2/6 All Button Dual...
My filter and pump will not retain the prime after turning off. Its a pantera sand filter. I can hear an air hissing sound coming from the multi valve port
Either you have a bad spider gasket inside the multiport valve or a bad threaded fitting going into it. Check for leaks around the multiport and backwash line. You'll have to take apart the multiport valve to make sure the spider gasket is not damaged or out of place. Make sure to install the multiport valve in the same position. You can get a replacement gasket at most pool supply stores or online.
Oct 29, 2009 | Hayward Pool Products HAYWARD HEAT PUMP...
Turned the temp for the spa up to 100 but it heated the pool too!?!
If you have automatic valves that switch over to run the spa, make sure that the valves turn completely to where they are supposed to be. Normally it will be about 180 degrees from where they are when in pool mode. If you have to change the valves over manually, make sure they're in the proper position. The only time this can happen is if the valves are not in the right position allowing the heated water to return to the pool. The thermostat on the heater will heat the water to the prescribed temperature no matter how you have the valves set. So if you place it on spa mode, it will heat whichever body of water that is flowing through it to that temp. If you have an automation system, double check the valves. That is probably where your problem lies.
Oct 05, 2009 | Hayward H Series Pool & Spa Heater 400k...
Hayward filter problem
YOUR HANDLE IS NOT SEATING IN THE RIGHT POSITION THERE IS A SPROCKET UNDER HANDLE THAT MAY BE DAMAGED TRYSETTING HANDLE TO DIFFERENT POSITIONS SEVERAL TIMES IT MAY HAVE DEBRIS UNDER IT MAKE SURE PUMP IS OFF.TAKE HANDLE ASSEMBLY OFF AND CHECK SPOCKET
Aug 04, 2009 | Hayward SAND FILTER, PRO SERIES
Hayward pool heater Model CZ 250 will not ignite
if ignitor sparks i'd say its okay, more likely a gas valve problem.are you sure gas supply is on and purged of air?make sure gas valve(the one gas supply threads into) is in the on position
Jun 18, 2009 | Hayward H Series Pool & Spa Heater 400k...
Pool & Spa Logo
116 people viewed this question
Top Hayward Pool Products Pool & Spa Experts
Jay Finke
Jay Finke
ray gallant
Tom Chichester
Are you a Hayward Pool Products Pool and Spa Expert? Answer questions, earn points and help others
